Old Dec 17, 2008, 01:51 PM
ally1405 is offline
Find More Posts by ally1405
Joined Nov 2008
Originally Posted by Pat Daily
I use a 10x3.8 APC or a 9x4.7 APC slow flyer.
I ordered the electrifly 10x4.5 props. Hopefully these aren't too much. It's hard to judge without a watt meter. One more question I had was whether or not you all use 3 drops of thin ca per side on each hinge. This seems like alot of ca, and I don't want it to be too stiff. I appreciate the help.
ally1405 is offline Find More Posts by ally1405
Old Dec 17, 2008, 02:43 PM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
I use one drop. The 10x4.7 prop will work in warmer weather--I like the 10x3.8 for cooler weather so I don't overdraw the battery. The plane has an excess of power anyhow.
Pat Daily is offline Find More Posts by Pat Daily
Old Jan 06, 2009, 04:38 AM
twinflandres is offline
Find More Posts by twinflandres
Brussel
Joined Nov 2005
Hi guys,
Do you think the recommended rimefire could turn a 10*4 wood prop ??
Thank you
Rémi
twinflandres is offline Find More Posts by twinflandres
Old Jan 06, 2009, 09:14 AM
Pat Daily's Avatar
Joined Mar 2001
I am sure the Rimfire could turn a 10x4 wood prop. The APC slow flyer props are what I use. The DVII will often nose over on landing--my guess is a wood prop would not last too long before you break it in a landing.
Old Jan 06, 2009, 05:37 PM
Rodl is offline
Find More Posts by Rodl
Salisbury N.C.
Joined Apr 2008
You will break the motor mount and/or the firewall before you break a 10-4 wooden prop with this plane.
Rodl is offline Find More Posts by Rodl
Old Jan 06, 2009, 05:44 PM
Zero3803 is offline
Find More Posts by Zero3803
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
Originally Posted by twinflandres
Hi guys,
Thank you
Rémi
I used a xoar 10x4 and it worked great, but after nosing over half a dozen times I switched back to apc.
Zero3803 is offline Find More Posts by Zero3803
Old Jan 06, 2009, 08:54 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
I finally broke down and ordered one of these today and I'm really looking forward to flying it but I'm worried about it nosing over on landing. I hope they don't do that on pavement too?
raz is offline Find More Posts by raz
Old Jan 08, 2009, 10:15 AM
Canamflyer is offline
Find More Posts by Canamflyer
Joined Oct 2007
They will only nose over on grass (taller grass). Asphalt or concrete runways are fine as is packed dirt and short grass.
B-T-W, I used a motor from BPHobbies in mine. Motor and ESC combined were 1/2 of the RimFire alone from GP.
I like this plane alot and I'm now looking to get an Allied partner to fly with it.
Canamflyer is offline Find More Posts by Canamflyer
Old Jan 13, 2009, 07:55 AM
flyboy49Mo is offline
Find More Posts by flyboy49Mo
Joined Sep 2007
Mines on the way.I noticed the Rimfire has three piont mounting.Most of the motors I own have four point mounting. I guess I have to make a motor mount.Right? Thanks for all the great help so far.
flyboy49Mo is offline Find More Posts by flyboy49Mo
Old Jan 13, 2009, 04:07 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Flyboy, if you need a mount give me a call(PM). I had a bunch laser cut and sell them for $1.50.They will be on our web site in few weeks when we launch with a new host.This is one installed on my Camel.
Scott
Old Jan 13, 2009, 08:12 PM
Rodl is offline
Salisbury N.C.
Joined Apr 2008
The plane comes with a supplied ply motor mount.
Old Jan 13, 2009, 08:13 PM
Rodl is offline
Salisbury N.C.
Joined Apr 2008
For the Rimfire...sorry I left that out.
Old Jan 18, 2009, 07:41 PM
deerdad is offline
Find More Posts by deerdad
deerdad's Avatar
Gill, MA
Joined Apr 2006
I also picked up this plane and I am in the process of getting the recomended system for it. As far as the props go, I went to ballance the GP prop (10x4.5)
and it is so far off that just for a test, I glued a small washer to the heavy side of the hub and it still won't ballance. The blades are level but the hole is off center. Would I be better off going with another brand of prop or try picking up another GP 10x4.5 ? If I go with the APC 10x3.8 is that going to hurt its performance in a big way or what ? Remember, evrything else is what was recomended.
Greg
deerdad is offline Find More Posts by deerdad
Old Jan 22, 2009, 06:28 AM
Dennis48 is offline
Find More Posts by Dennis48
Chilliwack, BC, Canada
Joined Nov 2008
Greg
I use APC 10x4.7 props and am very happy with both the performance and the ease of balancing. Using a Top Flite magnetic balancer, the ones I've tried have usually needed only a quick spray of clear coat on one blade and some have balanced fine right out of the bag.
Dennis
Dennis48 is offline Find More Posts by Dennis48
Old Jan 22, 2009, 07:24 AM
frdeluca1 is offline
Find More Posts by frdeluca1
United States, MA, Wareham
Joined Dec 2002
Mount
Scott
Scott:
Can you tell me how to go about buying one of these mounts for my Scorpion S 2215 22 motor which I intend to use on this plane. The Scorpion has a four hole mount pattern, which as best as I can tell, is on a 5/8 inch bolt circle.
Frank
frdeluca1 is offline Find More Posts by frdeluca1
Article Great Planes, Electrifly Fokker Dr-1 ARF Parkflyer Review Michael Heer Parkflyers 505 May 15, 2016 07:55 PM
Found Great Planes ElectriFly Fokker DVII shovelheadfreak Aircraft - Electric - Airplanes (FS/W) 4 Jan 11, 2007 07:24 PM
New Product **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Product Announcements 0 Aug 31, 2006 01:30 PM
Discussion **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Jim T. Graham Product Announcements 4 Aug 18, 2006 09:50 PM
New Product Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Scale Kit/Scratch Built 0 Aug 15, 2006 05:47 PM
