Old Jul 16, 2001, 03:51 AM
Moogee is offline
Find More Posts by Moogee
Mugi Pilot
Moogee's Avatar
United Kingdom, Scotland, Edinburgh
Joined May 2000
Multi engines - why are the engines angled outwards on full size?
I was looking for a subject for my next project - fancied a twin but then noticed in most of the three view drawings of planes, from above, the wing engines usually seem to be angled outwards - or point towards the wing tips.
It's very noticable on the Grumman Mohawk and to some extent the Sparviero and Junkers 52.
Why is this?
Is it perhaps because they've used contrarotating props - and therefore you'd have right sidethrust on one and left sidethrust on the other?
Cheers, Morgan
Moogee is offline Find More Posts by Moogee
Old Jul 16, 2001, 03:59 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Mugiman,
I think it's to do with stability in the event of single-engined flight being neccesary. A twin on one motor alone will try to turn (& maybe spin in), whereas angling both motors outwards wil tend to forestall this event, by lessening the turn-in tendency.
I think that's right......
tim
tim hooper is offline Find More Posts by tim hooper
Old Jul 16, 2001, 04:15 AM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Hello Morgan,
Yep - Tim is right.
The one engine running ( if the other fails )would pull the 'plane towards the dead-engine side.
You ask Tic ! Hehehe.
The out-thrust will help to alleviate this.
By the way, just what are you thinking of now ?
Not more multi's ?
Keven.
keven64 is offline Find More Posts by keven64
Old Jul 16, 2001, 04:52 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
You will sometimes see more offset on one side than the other ... this is to take account of prop. torque. And on 4 engined aircraft the outers may be angled out more than the inners. Another trick is to use twin fins that are angled ... so if one engine stops the propwash on the other fin provides a correcting yaw action.
Bill Glover is offline Find More Posts by Bill Glover
Old Jul 16, 2001, 06:24 AM
Moogee is offline
Mugi Pilot
Moogee's Avatar
Joined May 2000
Ah, the old engine failure chestnut.
I had forgotten they build aeroplanes with mishaps in mind. That does seem to make sense to me now.
Keven, just looking thru my Jane's big book of planes looking for something a bit easier than that Blohm & Voss p.170.
However, I'm settled on that as a project and it should roll off the line this week.
Incidentally then, if one were building a very scale multi - with 100% reliable electrics, thus not needing the offset, surely it would be better to mount them longitudinally and foresake this minor scale touch for the minutely increased thrust in the direction of flight?
Old Jul 16, 2001, 06:40 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
This is one subject that always fascinated me. The weird part, however, is that on the Short Sunderland they had strongly offset engines until the Mark V's when they straightened them back up.
ChrisP is offline Find More Posts by ChrisP
Old Jul 16, 2001, 06:50 AM
Joined Nov 2000
Perhaps the engines became more reliable?
I remember reading that Sunderland aircrew regularly used differential throttling when evading fighters ... much to the manufacturer's horror (the airframe had not been designed with such stresses in mind!).
Old Jul 16, 2001, 06:53 AM
Joined Nov 2000
Yes, apart from the normal requirement for a little right sidethrust somewhere in the setup.
Old Jul 16, 2001, 06:57 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Bill
The Mk V's had Wright Cyclones instead of Bristol Hercules sleeve valve engines, so you may be right on the reliability aspect. Actually if I had the choice I would be more inclined to favour the big Bristols.
Old Jul 16, 2001, 08:01 AM
Mark Haigh is offline
Find More Posts by Mark Haigh
Mark Haigh's Avatar
Barnsley, Great Britain (UK)
Joined Dec 2000
Moogee. An unrelated topic, but as requested previously the OS grid ref. to my flying site: SE:36742 09076. If you stick this in Autoroute - entrance is via Far Field Lane.
Mark Haigh is offline Find More Posts by Mark Haigh
Old Jul 16, 2001, 08:13 AM
Moogee is offline
Mugi Pilot
Moogee's Avatar
Joined May 2000
thanks Mark, I read you were trying to test that new Star Jet - would love to see that go - when were you going to try it?
I'm ready to fly my new plane but for my Jeti ESC in other topic.
Old Jul 16, 2001, 08:22 AM
Joined Nov 2000
er, yes, me too!
Why are engines mounted foreward? Daravon Modeling Science 7 Oct 21, 2005 01:36 PM
why are there 3 wires on ricky's motor? tom4 Motorcycles 3 Jul 15, 2005 06:04 AM
Why are Ecilpse 7 TX on sale at the moment ? Purple Baron Radios 4 Jan 04, 2005 02:17 AM
GWS Islander, DC-3, P-38, B-17, C-130 Multi-engines projects GWS4CEO Vendor Talk 56 Apr 21, 2002 02:40 PM
