Old Nov 15, 2006, 03:54 AM
Epanek is offline
Find More Posts by Epanek
Joined Nov 2006
Power Switch for 4 in 1
Has anyone put a power switch on their 4 in 1? how would you go about doing this? Every other speed controller I've had has a separate power switch which is much more convenient than unplugging the battery all the time.
What amperage switch would you need to use to switch the battery power into the 4 in 1 or is there a way to switch the unit on and off right on the circuit board?
Epanek is offline Find More Posts by Epanek
Old Nov 15, 2006, 04:09 AM
Xptical is offline
Find More Posts by Xptical
Your user title is suggestive,
Xptical's Avatar
Warner Robins, GA
Joined Apr 2006
I think a switch is a bit overkill for these helis.
However, if I were to do it, I'd use a simple 2-way switch and solder it between the battery connector and the 4-in-1. Just clip the red wire and solder the switch in.
You could also wire the switch between the 4-in-1 and the motor if you are worried about accidentally triggering the throttle.
Xptical is offline Find More Posts by Xptical
Old Nov 15, 2006, 06:07 AM
TachyonDriver is offline
Find More Posts by TachyonDriver
21st Century Space Cowboy
TachyonDriver's Avatar
Chipping, Lancs, UK
Joined Oct 2006
Yes, buy a Hirobo XRB SR Lama
TachyonDriver is offline Find More Posts by TachyonDriver
Old Nov 15, 2006, 12:32 PM
swatson144 is offline
Find More Posts by swatson144
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
I've seen this question a couple times. If you read the manual on the esc with switches almost every one will tell you you must unplug the battery to keep it from getting drained. They generally don't stop the consumption of power but only minimalize it. so if you forget to unplug you may be replacing your pack if Lipo (many sad stories of this). I'd be interested in seeing a single ESC with an on/off switch vice "safety" or "arming" switch, as I can think of none. The XRB may be one I have no experience with them.
It is generally considered unsafe to use a switch any way, as they can easily be inadvertantly turned on. There are some uses like in scale models where they are an additional safety while fitting the final section of fuz and carrying to the line etc, though most just make a way to get at the plugs easily with the body ready to fly.
Steve
swatson144 is offline Find More Posts by swatson144
Old Nov 15, 2006, 01:23 PM
Epanek is offline
Joined Nov 2006
Thanks for all the replies guys. I was actually refering to ESC's on RC cars, all the ones I've had came with a power on off switch, I just found it strange this heli doesn't have one.
If I did put a switch on the main power lead what would be a safe amperage switch to use?
Old Nov 15, 2006, 03:12 PM
Xptical is offline
Xptical's Avatar
Warner Robins, GA
Joined Apr 2006
Depends on the heli. Look at the mah rating of your batt and then the rated discharge rate. A 3-Cell, 1000mah battery with 20C discharge would produce a maximum of 20 amps.
Right?
Power options for a Bud Nosen 1/4 scale Citabria dr.E Scale Kit/Scratch Built 17 Mar 13, 2012 02:38 PM
Question Recommendation for 4-in-1 Gyro evebill8 Coaxial Helicopters 0 Aug 22, 2007 12:09 AM
Discussion Lama V2 - switch the BCX 4 in 1 HoverDown3K Coaxial Helicopters 1 May 24, 2006 02:10 PM
For Sale F/S 4-in-1 Box and transmitter for 4ch Micro heli! dacaur Aircraft - Electric - Helis (FS/W) 7 May 31, 2005 01:05 AM
If anyone needs a replacment 4-in-1 for walkera (or other, i have the tx too)... dacaur Micro Helis 1 May 30, 2005 11:46 PM
