Old Sep 03, 2002, 07:03 AM
Moogee is offline
Find More Posts by Moogee
Mugi Pilot
Moogee's Avatar
United Kingdom, Scotland, Edinburgh
Joined May 2000
Is a jedelski flying wing possible?
I only ask because I tried to make one for my EDF50 unit and on every attempt to fly it nosed in straight from launch.
Then I looked at it for a while and it hit me... DOH.
In my effort, the LE to 1/3rd chord must be acting as the wing, and the 1/3 to TE section like a huge down elevon....
With a jedelski you need something to hold the incidence of the wing... typically a stabiliser.
Can this be achieved by increasing the reflex (by adding up elevon as the neutral point) or is it just intrinsically not a good idea to try a jedelski flying wing?
I can imagine that increased sweep angle may help - are there any designs that do work?
Morgan
PS it was a correx plane, of course, but since then it's been found that a mini mugi is hot on an EDF50
Moogee is offline Find More Posts by Moogee
Old Sep 03, 2002, 07:28 AM
Sture Smidt is offline
Find More Posts by Sture Smidt
Sture Smidt's Avatar
Norge, Østfold, Moss
Joined Jan 2001
Jedelsky
Hi,
I have toyed with this idea for a while. Try the following. Make elevons full span with a chord 20% of the full chord. Reflex the elevons to lie flat when the leading edge touches the table as a starting point. The aspect ratio (span/chord ratio) should be less than 6 and preferrably less than 5.
Elevator travel should be 10-12 degrees and aileron travel 10 degrees. Make sure that full aileron travel is possible both sides when the elevator is full up or down.
On a rectangular plan form with no sweep back the CG should be at 15% chord as a starting point.
Make a light hand launch glider at 1/2 scale, say, to explore CG, reflex and handling.
Good luck!
Sture
Sture Smidt is offline Find More Posts by Sture Smidt
Old Sep 03, 2002, 11:15 PM
Terry Lyttle is offline
Find More Posts by Terry Lyttle
Keremeos, BC, Canada
Joined Dec 1996
Sure!
I have actually LOST a couple of f/f Jedelsky wings, they fly fine. Once you get the dynamics right, just enlarge. The f/ftests should include high and low speed flight, highly banked launches, catapulting, etc. Have fun with it, and experiment! However, don't change ANY MORE THAN ONE trim at a time; as soon as you change elevon setting AND c/g, you learn nothing.
Terry Lyttle is offline Find More Posts by Terry Lyttle
Old Sep 04, 2002, 12:03 AM
schoey is offline
Find More Posts by schoey
schoey's Avatar
Newcastle, Australia
Joined Nov 2000
Morgan
What size was the mugi on an EDF50? I've got a pile of correx, mugi building experience and an EDF50 sitting here.
I'm halfway through building another mugi at the moment, this one is going to have a MEGA 5T strapped to the back.
Grant
schoey is offline Find More Posts by schoey
Old Sep 04, 2002, 02:11 AM
omega blood is offline
Find More Posts by omega blood
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
What's a jedelski flying wing ? Or a jedelski for that matter?
omega blood is offline Find More Posts by omega blood
Old Sep 04, 2002, 04:13 AM
Moogee is offline
Mugi Pilot
Moogee's Avatar
Joined May 2000
Sture - thanks for those suggestions!
Schoey - the Mugi was 60cm span - the builder was Steve Wrona of Eflight Models. Don't know much more about it but he says it was awesome!
Omega Blood - I don't know anything about the theory of Jedelski wings but I think it is a term applied to a wing that has two flat surfaces (typically sheet material) that meet at the highest point of the wing; as per this hugely exaggerated and very crude diagram.
Old Sep 04, 2002, 05:35 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
I think that the real definition of a Jedelski wing is where the first third of the aerofoil is shaped balsa in a sort of Clark Y section and the rear two thirds flat balsa sheet. All kept in shape by triangular ribs on the bottom. This results in a highly cambered, thin aerofoil.
I don't think that a flate plate wing with a break in it counts as Jedelski construction.
If I remember right from reading Aeromodeller a zillion years ago, well at least in the 60's, the idea came from Eric Jedelski.
ChrisP is offline Find More Posts by ChrisP
Old Sep 04, 2002, 05:56 AM
Moogee is offline
Mugi Pilot
Moogee's Avatar
Joined May 2000
Thanks, Chris.
I should have stated that I was making a semi-informed guess.
My previous correx 'Jedelskis' have not required the triangular ribs. I simply hold the angle with tape along the fold.
For lightweight models the wings don't flex much and I've even gone up to a spd400 at 700mm span with no ribs.
They do flex on 'impact' though and with one of my slowflyers I cartwheeled for a landing and it was quite amusing to see the correx wing compress and then 'springboard' the plane about 2 feet vertically.
Old Sep 04, 2002, 02:44 PM
Joined Jan 2002
What would be the advantages or flying characteristics of this type of air foil ?
Old Sep 04, 2002, 11:35 PM
Joined Dec 1996
Why Jedelsky
Seems that the configuration follows the MAC with simpler construction. Mean Aerodynamic Chord is the line in all airfoils that ultimately describes its shape and most of its characteristics. If you look at MAC as a hint about what to expect from a wing, you will see that Jedelsky will be fairly fast, fly inverted not worth squat, but physically will build in 1/4 the time of any other wing.
Also in the 60s, some Brighter Light experimented with "Skinny Lifters", sheet wings steamed to MAC to prove the lift characteristics of various airfoils; typical freeflighter, too much time on his hands...
Old Sep 05, 2002, 06:16 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Jedelski is easy to build. You used to be able to buy the profiled front portions from your friendly hobby shop.
As a high cambered, thin aerofoil it's best used in 'one speed' models such as free flight gliders. If you drive them too fast you will get pitch changes due to significant centre of presure movements.
Jedelski came about in the 60's as an easy way of building wings for towline gliders.
Old Sep 05, 2002, 06:27 AM
Joined Jan 2001
Fenix 400
I use the Jedelsky section on my Fenix 400. Its a S400 machine with very nice flying characteristics. The speed range is reasonable and the landing/stall habits are nice.
See www.komtek.no/fly/fly.htm and click on S-Models.
Sture
Old Sep 05, 2002, 06:36 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
It works for me. The biggest problem I had was with yaw stability. I ended up putting a fair amount of twist in the elevons and adding winglets. It flies fine now. It's mainly based on Az Chuck's So Slo 2 design.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Sep 05, 2002, 06:49 AM
Joined Jan 2001
Fenix 400
The Fenix 400. Plans are available.
Old Sep 05, 2002, 10:36 PM
Joined Dec 1996
Jedelsky
I ain't so sure on this one-speed thing. I know that A1 gliders look for an ultimate l/d ratio, and that is how I flew most of my stuff. However, I was browsing through an old Model Builder, and there was a photo of a sloper that had a speed envelope that went from walking to 70mph; not much limit there!
Working on the info in that article, I chose Jedelsky for my F89 sloper, still under construction; I will find out for myself if there is a "best" speed for that type of wing or not. Gotta say that building that wing was not a big part of my evening, including aileron hinging (old fashioned zigzag).
Discussion How to make the noisiest flying wing possible Accu157 Flying Wings 17 Mar 31, 2007 10:03 PM
Pitcheron flying wing possible? MattyB Slope 14 Dec 03, 2005 01:48 AM
Smallest Flying Wing Possible snowball1288 Foamies (Kits) 7 Dec 28, 2004 06:39 AM
Question Well performing long chord-ed flying wing, how is it possible? e-sailpilot86 Thermal 1 Jul 26, 2002 08:49 PM
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 02:29 PM
