Old Nov 14, 2006, 09:36 AM
kgn831aa is offline
Find More Posts by kgn831aa
Joined Jun 2006
formosa2 with a123s ?
any one put the a123s in a formosa 2 or even a one ,, some were some one did put the a123s on a slow stick , sais they got 45 min of serious flying from them , that was on just two cells ,i love the formosa 1 ,,but want a 2 real bad ,
kgn831aa is offline Find More Posts by kgn831aa
Old Nov 14, 2006, 10:47 AM
Dragon 2 is offline
Find More Posts by Dragon 2
Fly Fly Fly Crash
Dragon 2's Avatar
United States, CO, Montrose
Joined Aug 2005
Whats a 123s?
Dragon 2 is offline Find More Posts by Dragon 2
Old Nov 14, 2006, 11:05 AM
LBMiller5 is offline
Find More Posts by LBMiller5
Use the Force!
LBMiller5's Avatar
San Marcos, CA
Joined Jan 2005
A123's are the new 3.6 volt Lithium Nano-Phosphate batteries that come inside the DeWalt 36 volt cordless power tools. Each cell is 3.6 volts nominal with a 2300mah capacity. They are capable of 30C continuous discharge rates (69 amps) with bursts to 40C (92 amps). They weigh 70 grams per cell for loose cells, and around 73 grams per cell with the welded tabs.
If cared for properly they can deliver at least 1000 charge cycles, and if you keep the current draw down to under 10C, 2000 charge cycles are possible. They have a solid aluminum outer can, so they can take bumps and bruises that would destroy a Li-Po battery.
I did a How-To thread on how to disassemble one of the DeWalt packs to harvest the cells a few weeks ago. Here is a link to that thread for more information.
Disassembly of a DeWalt 36v battery pack
Lucien
LBMiller5 is offline Find More Posts by LBMiller5
Site Sponsor
Old Nov 15, 2006, 06:47 PM
kgn831aa is offline
Joined Jun 2006
nice write up too it was , i want to try them in a formosa 2 the bigger one ,, whats your thoughts on that ,, id be happy if it flew only as good as the formosa 1 does on the nh 9.6 pack ,
Old Nov 22, 2006, 12:30 PM
kgn831aa is offline
Joined Jun 2006
any one else interested in this
Old Nov 24, 2006, 09:37 PM
unoguy is offline
Find More Posts by unoguy
Joined Nov 2006
anyone have any info or experience with this topic?
unoguy is offline Find More Posts by unoguy
Old Nov 25, 2006, 12:28 AM
Use the Force!
LBMiller5's Avatar
San Marcos, CA
Joined Jan 2005
A 3-cell A123 pack has an open circuit voltage of 3.6 volts per cell or 10.8 volts, which makes it about the same as the open circuit voltage of a 8-cell Ni-MH pack. The cells weigh 73 grams each with solder tabs, so 3 cells weighs 209 grams, and by the time you tape it up and add a power lead, it will weigh around 220 grams or 7.75 ounces. The A123 cells have a capacity of 2300mah. 2300mah Sub-C Ni-MH cells weigh around 2 ounces each, so an 8-cell pack of these would weigh about a pound. This makes the A123 pack about 1/2 the weight of Ni-MH cells.
It looks like the A123's would be a big step up from Ni-MH cells!
Lucien
Site Sponsor
Old Nov 25, 2006, 03:57 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
I fly my Formosa II with three Emoli cells, a TP2908 and a GWS 1170 prop. With three A123 cells you would need a slightly hotter motor because the voltage is lower.
Len
LenBFP is offline Find More Posts by LenBFP
Old Nov 25, 2006, 11:42 AM
kgn831aa is offline
Joined Jun 2006
formosa2
this is starting to look like it might work ,, thanks guys ,,, btw how much time are your getting with that set up , and do u fly mild to wild or some were in betwwen
Old Nov 26, 2006, 06:17 PM
LenBFP is offline
LenBFP's Avatar
Joined Jan 2002
Some where in between. It climbs straight up to the limit of sight, but not real fast. In level flight it is fast enough; the seven inch pitch probably helps. I haven't timed any flights. I would guess over ten minutes, but it could be less. I don't run the batteries to cut off.
Len
Old Nov 27, 2006, 10:04 PM
kgn831aa is offline
Joined Jun 2006
formosa2
gone to have to gety one i think , i love the formosa1 i just have it stock but i do like how it flies once i got 13min40 secs on it , iam trying to get 15 out of it on the 350 brushed , and a 9.6 , i just got a lipo so ill try that next i do use quit abit of throttle managment to get the times iam getting , as for the formosa2 , whats the longest flight times anyone has got what set up , and what kind of flying are u doing to get it ,,,,,,,,,,, iam still learing just been doing this for 5 months now i startted with the slow stick ,,next was the estarter , an now the formosa1 ,,,,,,,,, i have not went to brushless yet i have a gws 18 i may try soon but right now the stock motors are fast enough for me , on down wind i think i might be hitting 35 to 40 mph love the flyby , had a friend let me fly his bristol scout , at nite lol it was great , isure ill have one them too soon ,,,,, love this hobby
Old Nov 30, 2006, 11:41 AM
val1756 is offline
Find More Posts by val1756
oh
Joined Sep 2004
i would love to see pics of these a123 packs in a formosa 2
by the way kelly is a chump
val1756 is offline Find More Posts by val1756
Old Dec 01, 2006, 02:30 PM
kgn831aa is offline
Joined Jun 2006
chump
yep i isand i want to see pics too
Old Nov 28, 2007, 09:46 PM
kgn831aa is offline
Joined Jun 2006
a123s flight duration ,in your small or large planes
Len
a year ago i asked about the use of these in gws formosa ,, well i still see just the 6 to 8 min times ,, iam sorry but iam not gone to be happy with that ,, has anyone gotton , over 15 min with the a123s the 3s ,
iam kinda ruined now that i been getting anywere from 20 to 60 min in the small stuff ,, but i do want to fly bigger just want to fly longer than 6 min ,,
Old Nov 29, 2007, 02:03 PM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
Your paying 3x the cost to get that run time. You can charge these Cells in as little as 10-15 minutes. Have a couple of theses packs and you can fly, Charge fly non stop. Just land and rotate packs.
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Data QJ EP-8 with A123s Report SlowRide Electric Heli Talk 11 Oct 30, 2007 05:23 AM
