Old Sep 02, 2002, 07:39 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Speed 400 Pylon Racing - 1 vs. 2 wing servos
Hi all,
Some gents in town are looking to get a S400 pylon racing league going in town, and I've decided to take part. Since the basic requirements are a Graupner 6v motor (timing adjustable), 8 cells, APC 5x5 prop and 150 sq" min wing, there aren't many kits available ready-made. That's a good thing...I'm designing my own!
I'm pretty much designing to the minimum specs (152sq", Vv=0.018, Vh=0.438), but I've decided to run a 5.9% thick airfoil (which I can't describe further...secrecy you know ). As such, it's effectively flying on ~130 sq" of MH30-style wing.
Anyways, the question is this: do I use one or two wing servos? With one, things are simpler, but differential is harder to set. With two, I can try things like snap-flap, and landing becomes easier with spoilerons. Is it worth the added hassle?
Also, could some pylon guru's explain how they set aileron differential? Do you want an axial roll, or is some adverse yaw useful seeing as there aren't rudders on these models?
TIA
SoarNeck is offline Find More Posts by SoarNeck
Old Sep 02, 2002, 08:18 PM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
I'm no expert, but weight is your enemy. An extra servo is dead weight on a pure racer.
Allan Wright is offline Find More Posts by Allan Wright
Old Sep 02, 2002, 08:49 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
See you at the races. I will have my own 150 sq in racer (MH20 8% thick) ready to challenge you.
I wouldn't add the complexity of two wing servos unless your secret airfoil needs flap to turn fast. Differential is not necessary and axial rolls are lower drag than asymetric rolls.
DaveSawers is offline Find More Posts by DaveSawers
Old Sep 02, 2002, 08:52 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Bring it on! Good to hear that there are quite a few people interested. Any idea how many might be showing up?
Old Sep 02, 2002, 09:36 PM
jimmy6819 is offline
Find More Posts by jimmy6819
North Aurora, IL
Joined Mar 2000
This is an interesting question. I've seen several people modify the servo mount on the VIP racer (not a Sp400 racer, similar) and mount 2 HS55's side by side, giving them differential and spoilers for landing. The VIP drops like a ROCK with spoilerons.
jimmy6819 is offline Find More Posts by jimmy6819
Old Sep 02, 2002, 10:42 PM
JJEXP is offline
Find More Posts by JJEXP
So tired
JJEXP's Avatar
Bensalem, PA USA
Joined Apr 2001
I thought for speed 400 pylon, you could only use 7 cells, not 8. Correct me if I am wrong
JJEXP is offline Find More Posts by JJEXP
Old Sep 02, 2002, 11:20 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Could be...I'm not sure. These are local rules I'm talking about here, since there's no minimum area requirement in FAI that I know about.
Old Sep 03, 2002, 07:37 AM
Joined Oct 1999
These are our local rules so we are allowing 8 cells and mandating a larger model than the Stinger and most of the other all moulded models so they fly fast but are still usable as sport models.
I know at least six people are building for the first event. There may be many more...
Old Sep 03, 2002, 03:34 PM
Neil Stainton is online now
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
They sound like excellent rules. The idea of using 7 cells for competitions is mad - just a relic from the distant past when good chargers were very expensive.
I hate 7 cell packs because of the odd number of cells makes the construction so awkward. And the performane of an 8 cell model is much better...
Neil.
Neil Stainton is online now Find More Posts by Neil Stainton
Old Sep 03, 2002, 08:56 PM
Flying Cat is offline
Find More Posts by Flying Cat
Flying Cat's Avatar
Cary, NC
Joined Jan 2002
I recently removed the second servo from the wing of my Python. Originally, I installed the second servo so I could slow the plane during landings.
But once I had more than 5 landings under my belt with this plane, I found out that I did not really need the spoilerons, so to save weight my Python now has a wing with only one servo.
Good Luck on your races,
Flying Cat
Flying Cat is offline Find More Posts by Flying Cat
Old Sep 04, 2002, 08:12 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Your rules sound a lot lot what some of the 1/2A pylon gas guys want to do. 150sq" min. wing and limiting the engines to bushing (stock) .061s and 25% fuel. Though, I think they want a minimum weight of 15 oz. The idea is to have airplanes that are big enough for most guys to fly and keep it fast enough.
I like the 8-cells as well. Do you guys have a wing loading or min weight rule?
Troy is offline Find More Posts by Troy
Old Sep 04, 2002, 08:53 PM
Joined Oct 1999
No and No. See the related thread http://www.rcgroups.com/forums/showt...threadid=59858 for a full listing of the proposed rules. I think a competitive model will have to be quite light though.
Old Sep 04, 2002, 09:01 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
I wouldn't personally be in favor of a loading rule, since it would limit creativity a little.
On a related note, I think I can get this little critter in just a hair over 13 oz...should move pretty well at that weight.
I only wish I'd heard about this earlier, since I'll barely have time to flight test. I haven't done any racing for about 10 years...I think I'll name my racer "Ziggy"
Old Sep 05, 2002, 12:06 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
Yah, I suppose you'd penalize yourself for being heavy.
Old Sep 05, 2002, 03:33 PM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
Hmm...,
Bigger than 150sq. in., room for 8 cells, not another heavy composite ARF, finishes at 13oz... Seems like I've heard of an airplane that fits this description before. www.fastcomposites.com
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Reply With Quote  (Disabled)
1 vs 2 aileron servos? machine 3D Flying 17 Apr 02, 2004 04:59 PM
Speed 400 4.4:1 & 2 SPT Q-HUNTER Aircraft - Electric - Airplanes (FS/W) 4 May 17, 2003 10:08 PM
Speed 400 Pylon Racing in SoCal? W Cole High Performance 27 Jan 23, 2003 10:52 PM
NorCal speed 400 pylon racing TedLarson High Performance 0 Jun 03, 2002 01:21 AM
1 vs. 2 Aileron Servos AirVenture Sport Planes 13 Feb 07, 2002 01:13 PM
