Old Sep 02, 2002, 05:52 PM
JasonD is offline
Find More Posts by JasonD
United States, CA, San Diego
Joined Mar 2002
Corona Blade Grip Question
In the instructions for building the Corona it tells you to use one #4 blade grip and a #6 blade grip. Won't this cause the blades to not track the same? Is the construction manual wrong? Why did they suggest this combination instead of using the same number blade grip?
Thanks in advance.
Jason
JasonD is offline Find More Posts by JasonD
Old Sep 02, 2002, 10:13 PM
ericss is offline
Find More Posts by ericss
edison,nj
Joined Jun 2001
Jason,
6,6 grip gives you more lift as compare to 6,4grip and 4,4 grip, at a particular head speed. However, 4,4 grip is more stable than others, since the head speed is higher. I would recommend 4,4 grip if you are new to heli. The recommended 6,4 grip give you something in between.
You will also find how to adjust the blade pitch at P5-4 of the operator manual. Hope this help.
Eric
ericss is offline Find More Posts by ericss
Old Sep 02, 2002, 10:45 PM
gstew is offline
Find More Posts by gstew
Columbus, MS, USA
Joined Oct 2000
Jason,
As Eric mentioned, the manual tells you how to adjust the tracking so that the blades are tracking each other... with a 4-6 grip combo, you end up adjusting the blade on the 4 grip to have a bit more pitch and adjusting the blade on the 6 grip to have a bit less pitch so that they end up at a average of 5 degrees (not including the 2 degrees built into the blade holders) and in track.
I too like the 4-4 grip combo better than the 4-6 for the reasons Eric cited.
Later!
Greg in Minneapolis
gstew is offline Find More Posts by gstew
Old Sep 03, 2002, 11:44 AM
JasonD is offline
Joined Mar 2002
Thanks guys,
Guess I'll give the 4 4 grip a shot next time I fly it.
Jason
Question CP2 CNC blade grip question... elan Micro Helis 0 Jul 13, 2006 11:19 AM
Alert Corona Blade Grips Question Help mcoccia Electric Heli Talk 2 Jan 13, 2005 10:40 PM
Corona blade grip losinground Electric Heli Talk 7 Sep 10, 2004 01:14 AM
VE metal blade grip question Vance Electric Heli Talk 0 Jul 20, 2002 10:23 PM
