Old Nov 12, 2006, 07:44 PM
Nicetie is offline
Find More Posts by Nicetie
Private Pilot/K5MBV/SCUBA
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
US Engines and Quadra
I bought an airplane with a US Engines 41. Does anyone know the history
of these engines. I'm told they are identical to the Quadra. They aren't.
I know it's a heavy low powered engine, but don't know how well they start,
run, and last. If you have experience with them, fill me in.
Mine had a stripped prop adapter that I repaired with a heli-coil. The metal
(aluminum) seemed awful weak to tighten a prop bolt onto, but now it's OK. Is the rest of the engine poor quality too?
Ken K5MBV
Nicetie is offline Find More Posts by Nicetie
Old Nov 12, 2006, 08:34 PM
Maineiac63 is offline
Find More Posts by Maineiac63
Maineiac63's Avatar
Blissfield, Michigan
Joined Apr 2005
I have a couple of US Engines 35 and one 25 - they have always ran just fine for me - no complaints , Jim W1SJG
Maineiac63 is offline Find More Posts by Maineiac63
Old Nov 12, 2006, 08:44 PM
Nicetie is offline
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
Jim, does the kill switch short the wire to ground for running or for
disabling the magneto? I haven't started mine yet and don't want
to accidently get spark while choking the engine. ...ouch
tnx, Ken K5MBV
73's
Old Nov 13, 2006, 12:58 PM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
Ken K5MBV
They weren't bad before they moved the factory. After that they suffered a great deal in their reputation.
If you have a good one, they will do the job.
Once you get the starting drill down, they really aren't bad to hand start. But you will need a good shoulder and arm if the spring starter is missing.
Artisan is offline Find More Posts by Artisan
Old Nov 13, 2006, 01:04 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
AMEN!
I bought a US Engines 35 cc after having a Quadra 35cc.
Supposedly, the US E had been factory run.
After pumping on that thing for 4 hours, the next day after I recovered, I found the carb had been installed -backwards-... so the pressure input to the carb from the crankcase was facing out, to atmosphere. It couldn't pump diddly!
Fixed that, and installed the spring starter, and it worked fine.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 15, 2006, 10:58 AM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
Running a 41 cc US engine. A bit hard to start "on its own", but I do use a small squirt of "canned engine starter". One small squirt, one pull and she runs.
You do have to make sure that your needles are set correctly.
I also use the angled deflector intake on it. Do not really know if it helps or not.
If you do "prime the engine", you do not have to worry that she will accidentally start. Just keep your thumb on the inlet and rotate (not flip) a couple of times while holding the prop with your full hand, and do not let go until you have turned the prop fully.
indoruwet is offline Find More Posts by indoruwet
Old Nov 15, 2006, 03:08 PM
Maineiac63's Avatar
Joined Apr 2005
The wire from the magneto goes thru the kill switch, so when the kill switch is off the plug gets no spark. I do mark my switch with a red mark so I know if it's in the right position. I don't know who or when but someone showed me how to take the prop in hand and just go back and forth thru the compression stroke while stuffing a finger (thumb?) in the carb to prime the engine and when the finger tip gets wet the you're ready to open the switch and she should fire right up.
Old Nov 15, 2006, 03:50 PM
Nicetie is offline
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
Maineiac63,
OK, Thanks for the info. Hope mine works this well. I had to cut a big hole
in the cowl to get my finger in for choking.
The weather is really nasty out right now. Maybe tommorrow I can run it.
It's 49 deg, but the wind is blowing 35MPH with gusts to 50MPH!
One question: When the switch is OFF is it closed or open ie. wire to coil
grounded not? This was what I should have asked in the beginning, since
I still don't know the answer. My switch has no marking but I can check
it with an ohmeter after pulling the connecter from the coil pin.
Thanks, Ken
Old Nov 15, 2006, 06:52 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
My experiences with gas motors led to use two kill switches, in series.
One the usual manual, easily accessied without exposure to the prop, and the other on a servo, which could be shut off in flight.
This is particularly useful in a twin.
Old Nov 15, 2006, 07:45 PM
Nicetie is offline
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
Hi Sparky Paul,
But, does grounding the mag/coil kill pin allow the engine to start or does it kill it? I guess by deduction from your post that grounding the pin allows
the motor to run since you had them in series so that either could kill the engine. I've had several replys to this post and not one of them has answered
the question, but I got a lot of good advice.
I like the servo method. Is there a gizmo to operate as a switch from a servo channel output or do I have to cobble a mechanical one?
Ken
Old Nov 15, 2006, 08:27 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Ken, it's as simple as using a servo wheel with a cutout that releases the roller on a switch..
Channel 5 is usually the retract channel, and works fine for this.
I've used it for on-off with electric motors, before the days of ESCs, also.
Old Nov 15, 2006, 08:57 PM
Nicetie is offline
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
Guess I'll visit Radio Shack tomorrow. Everything electronic and
semiconductor in junk boxes, but no electrical parts here. No switches
of any kind. Haven't even seen a microswitch in years. This would be
the easist way to do this. Two switches would be safer too, so I'll
pick up a SPST toggle switch while I'm there.
Ken
Old Nov 16, 2006, 01:30 AM
Crusty is offline
Find More Posts by Crusty
Joined Oct 2006
Hi Sparky Paul,
Ken
Grounding the wire from the Mag kills the ignition
Crusty is offline Find More Posts by Crusty
Old Nov 16, 2006, 06:42 AM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
Us 41
About 6 years ago I built a Sig 120 4 Star. I put a US 41 on it.. It started, ran, and pulled the model "very" well. I flew it for 2 yars, traded it, that owner flew it for a year or so and sold it to the 3rd owner. I saw it at a flyin this summer and it is still running perfect. I ask the present owner about the motor and he told me he had done nothoing to it but clean the screen and replace the plug.. The US 41 is a little heavy, but used on the right model, they are a great motor for the money.. Brian Smith
BrianSmith is offline Find More Posts by BrianSmith
Old Nov 16, 2006, 11:04 AM
Nicetie is offline
Nicetie's Avatar
Garland, Texas
Joined Jan 2006
THANK YOU Crusty!
Ken
US Engines 41 Starting procedure. fenderjw Engines 5 Jan 07, 2010 12:02 PM
For Sale US engines 41 cc w5kfg Aircraft - General - Miscellaneous (FS/W) 0 Oct 15, 2006 04:57 PM
US Engines 41 fenderjw Aircraft - Fuel - Airplanes (FS/W) 5 Jan 14, 2005 11:31 PM
Discussion NIB US Engines 35cc Gas Engine-$110 Shipped dhable Aircraft - Fuel - Airplanes (FS/W) 4 Nov 05, 2004 07:51 PM
Help! the "NEW" US Engines JEanes Engines 1 Mar 03, 2004 11:15 AM
