Old Nov 12, 2006, 03:37 PM
torcgolf is offline
Find More Posts by torcgolf
PiLoTuS pArKfLyIcOuS
torcgolf's Avatar
Dub Cee, California
Joined Aug 2002
Question
LiPo Question - How do you know when you need a charge again?
i just purchased a 6300mah 3-cell pack. i prolly only used about 2000mah or less the last time i ran it, which was a week ago. my question is, should i recharge it again before i go out? or can i run it some more until the next time? i use it for a large sailplane but for motoring up to altitude then shutting off so i dont really need a full pack.
how many volts should it be reading before it's dangerous? how can i tell without a low voltage cut off on my esc? when i hook up the pack to my watt meter it reads 11.6v
this is only my second time i used a lipo
torcgolf is offline Find More Posts by torcgolf
Old Nov 12, 2006, 03:40 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Approximate remaing capacity based on open voltage.
http://www.rcgroups.com/forums/showp...1&postcount=11
Old Nov 12, 2006, 04:00 PM
torcgolf is offline
torcgolf's Avatar
Dub Cee, California
Joined Aug 2002
thank everydayflyer. so according to this, im at approximately 52% capacity? whoa, i didnt know i used up that much! i guess i did some more bench testing during the week swapping props.
so, just how much should i have in capacity to store the lipo for long periods of time (winter time etc). i remember asking a similar question on storing but then i only stored it a week at a time.
Old Nov 12, 2006, 04:12 PM
Southern Pride
3.85 volts per cell in a cool location.
http://www.motorola.com/testservices/article1.htm
Have a question, How do you guys fly so high yet still be in range of control? alanhsu Aerial Photography 29 Sep 07, 2012 11:00 AM
Discussion How do you know when you need a programmable ESC? Scott_S. Power Systems 4 Jul 21, 2007 03:41 PM
Dumb question: How do you know when your batteries have had it for the day? steve crewdog Radios 4 Sep 04, 2005 05:55 AM
Newbie question : How do you guys hold the wings on ??? AntoineL Scale Sailplanes 11 Aug 16, 2005 03:17 PM
dumb noob question: how do you know when to use 11.1 or 7.2 v? steve crewdog Power Systems 4 May 22, 2005 05:20 AM
