Old Nov 12, 2006, 08:40 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Avro Vulcan easy build plans
This model was designed by my flying buddy Richard Phillips.
I had test flown his model and praised it up so much,that when he went away he offered to build me one. Two hours later I was picking it up.
He has asked me to post plans and notes for the build as he is not so hot on the PC side
Just finished working on the build for an Avro Vulcan pusher prop model.
It uses the same construction as my estratos model, keeping it basic, taping rather than gluing all the wing sections and CF spars together, UHU por gluing the fuz bits together.
The model has turned out to be a very good flyer indeed.
Richard modded his construction to make cutting out and then the fitting of your radio gear a bit easier
here are the drawings for the build
davereap is offline Find More Posts by davereap
Old Nov 12, 2006, 08:46 AM
davereap's Avatar
Joined Feb 2005
pics and plans
video
rc depron vulcan (2 min 49 sec)
Old Nov 12, 2006, 09:41 AM
davereap's Avatar
Joined Feb 2005
Construction
WING
Using the simpler layout plan
Cut out the main 800x600 wing triangle
Cut out the two wing extensions for the Vulcan shape
Cut the triangle into three sections along the front spar line and the elevon spar line
From the elevon section the two pointed ends are cut off, these are refitted to the spar and wing extensions later, forming the wings end/tip part.
From the elevon section a 75mm length is removed, this is for the fuz spacer and will go between the working elevons.
The elevons will need shaping later as per plan 1, they are 2” wide parallel over the center section of the wing, then they sweep back to the tips
Use 2” wide white tape tp and bottom on all panel joins
Fix the 3mm CF spar rods in place across the wing sections.
On the large panel one spar goes on the elvon hinge line and one goes to the front of the panel
Now refit the front section back with tape top and bottom
You should now have one large triangle and a lot of smaller bits left
Work out the length of the rods needed for the leading edges of the triangle., don’t forget they have togo further than just the edges of the triangle, they go to where the tip of the wing will be.
Tape into place….the rods should extend a good couple of inches from the triangles tips.
Now you can tape the wing extensions and the small tip bits you cut from the elevons.
And also tape the fuz spacer central on the elevon hinge line
Your two elevons can be fitted now or later, but it is probably easier to shape them now as the whole wing can be laid flat on the cutting board.
When I fitted the elevons I tape covered them completely on both sides to stiffen them
Old Nov 12, 2006, 10:01 AM
davereap's Avatar
Joined Feb 2005
BODY
Decide on the method of construction and the internal width needed to fit your preferred battery into
Make two horizontal spacers .. after working out the full width, internal + walls
1 …from the front of the wing to the point of the nose
2 …from the rear of the central elevon spacer to the motor mount position
Tape in place
In Richards original, the top and bottom of body were carved from a lump of polystyrene block
I then found that the polystyrene was a bit soft for fitting the servos in through, and that the body was not wide enough to take my battery, so most of my lower fuz was made up using 6mm depron, spaced wide enough to take my gear, basically a simple box structure with rounded corners for a bit of shape. The lower front curved nose section was left carved from the polystyrene block
I used UHU por to glue the body together, and then to fit the upper and lower body sections in place over and below the wing
Old Nov 12, 2006, 10:27 AM
davereap's Avatar
Joined Feb 2005
SPECIFICATIONS
C.O.G. …..11 inches measured forward from the rear of the elevon at the next to fuz position
AUW 8 ½ oz without battery
CD rom type motor used gws 8x4 direct hyper prop 11.1v 1800mA battery weight 3 ½ oz. 12A speed control couple of 9 or 5g servos hitec rec
With its rearward position it is best to use as light a motor as you have, or your batteries will be right up the nose end for balance
Flight time 20 mins at full power, but it only needs ½ power to cruise so …loads of time
heres a pic of the motor ...highly recomended better than 1:1 power/thrust on this setup
Old Nov 12, 2006, 10:47 AM
davereap's Avatar
Joined Feb 2005
Heres a link to my estratos, a similar build delta
My 1m version now fitted with a KF top step, which makes a much stiffer wing
http://www.rcgroups.com/forums/showt...t=434265&pp=15
Old Nov 12, 2006, 10:50 AM
davereap's Avatar
Joined Feb 2005
heres a link to my fighter duo design the SU27 and F15
http://www.rcgroups.com/forums/showt...t=580622&pp=15
Old Nov 12, 2006, 07:07 PM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
There's that blue motor again .... !!!!!!!!!
Love the Vulcan , with it's "cranked" wing!!!!!!!!!!!! ... We HAVE to add this one to the build list...Thanks for the plans ...!!!!!
That taping method is very interesting , could you please describe it in a bit more detail ... what specific advantages does it offer... it does seem like a really good idea!!!!
gpw is offline Find More Posts by gpw
Old Nov 13, 2006, 01:48 PM
davereap's Avatar
Joined Feb 2005
I just use 2" wide coloured tape to fix the spars etc in place. In the UK I get it from Staples, a stationary shop, it is sold as packing tape in a variety of colours ..You should stick about 1" of the 2" all along top edge of wing, leaving the remainder loose, turn wing over so you have the sticky side up, place the spar along the edge as tight as posible, then wrap the loose tape over and stick it to the wing..benefits 1...easy removal of spars without being covered with glue. 2...It also stiffens up the depron. 3..depending on the colours used this can also be the models decoration. 4 ...its quick!
On the vulcan the wings leading edge shapes are stuck on similarly, using 2" top and bottom, that now equals 2 layers of tape, even stronger and stiffer,
The elevons are similarly hinged, another layer, but have care to fix the tape with the elevons bent in the oposite direction to the side you are sticking the tape to.... if you dont do this the elevons will not move at all.
I also tape all leading edges with 3/4" clear tape to prevent rips in the depron if you catch anything in landing.
More tape on bottom of fuz for same reason
I then coated the depron and tape with an almost clear primer which gave the coloured acrylic paints something to stick to. for this I used a Pactra sealer bought from my model shop UK.
sorry if I keep pluging that blue motor, but it really is that good, £12-15 in the UK and better performance than my axi 2208/34, less weight, less current drawn, enough thrust to easily fly the vulcan at 1/2 power..
now less than £8 from robotbirds.co.uk
I forgot to say, my vulcan was built with 3mm depron. the wings bounce a bit in gusty conditions but it is more than strong enough for any manouver I can do... It also looks great in the air.
Test flights are absolutely no problem, landing is a doddle, you can raise the nose high and come in at a crawl, with a slight breese you can harrier it to the ground.....
Old Nov 13, 2006, 06:00 PM
gpw
gpw's Avatar
Joined Jul 2002
Dave , Thanks for the info !!!!! Very interesting method for 3mm Dep ... that 's gotta' be STRONG !!!!
Old Nov 14, 2006, 12:49 AM
American since 1947
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I was wondering what all the CF ???
But when you said it was 3mm - I got it !!!
I like the Su27 too
birdofplay is offline Find More Posts by birdofplay
Old Nov 14, 2006, 05:01 PM
TGK
USA
Joined Jun 2004
Davereap,
Thanks to you and Richard for the plans for this nice looking plane! Any possibility of getting a video?
TGK is offline Find More Posts by TGK
Old Nov 14, 2006, 05:42 PM
Ontario Canada
Joined Aug 2003
Very nice work, Dave,
Amazing that something that big (880mm) could be made from 3 mm depron.
I'll add it to my winter list.
Bob
boberos is offline Find More Posts by boberos
Old Nov 17, 2006, 02:05 PM
davereap's Avatar
Joined Feb 2005
Bob
just make sure you use 3mm CF rods as spars and for the leading edges and it will be plenty strong enough...
I used 3mm x 0.5mm flats as spars... still ok but wings do bounce about in gusty conditions...
As to videos ive been thinking about that recently, so if I can my mate richard to use the camera you might get lucky.. no promises
Old Nov 18, 2006, 07:52 AM
davereap's Avatar
Joined Feb 2005
heres the vulcan torque rolling into the palm of my hand..
shows the power of that blue motor in my post no:5
Depron vulcan brushless motor power (0 min 12 sec)
Discussion need plans for easy build hemayann Dock Talk 9 Jul 17, 2007 02:26 AM
Build Log Avro Vulcan Build Thread ron_sb Foamies (Scratchbuilt) 28 May 16, 2007 11:49 PM
Discussion Plans for an easy build/easy fly? malibu43 Foamies (Scratchbuilt) 5 Feb 05, 2007 06:18 PM
Question Easy to build Novice Sailplane Plans? sixeastmain Sailplane Talk 8 Jul 02, 2003 07:01 AM
NEWBIES...Easy Build and Fly...Free Plans... gpw Foamies (Kits) 93 Apr 30, 2003 06:36 PM
