I wouldn't risk this (or any other plane) to Blue Arrow servos. I bought 4 of them a while back during a big Hoby Lobby sale. One was DOA, 1 died after I install (noticed before I flew it) in a DL50 and the other two had poor resolution and liked to jitter and tremble. I swapped them out for some little GWS Picos and they work fine with a very small weight penalty.
Keep up the good work on this little DLG, I need another one...o.k I really don't but I sure WANT another one
Pensacola, FL, USA
Joined Dec 2000
Quick servo test
OhioPete.
I had the same experience with Blue Bird and came to same conclusions, but I only tested three which is not a very large number. However, it made me a firm believer in testing any servos to be used on elevator. Back in October I posted a thread with simple, quick test set up. Hope it is of some value. http://www.rcgroups.com/forums/showthread.php?t=581765 Regards, John255 |
Blue Bird and Blue Arrow are two different brands, correct? I had heard better reports about Blue Bird and bad reports about Blue Arrow.
And am I correct in the Waypoint series being the same as the Blue Bird? I'd still like to find reliable 4gm servos, but, haven't tried the BMS303's yet. charlie |
Upstate, NY
Joined Feb 2002
Personally I have used more than 16 different Blue Bird BMS303, and so far they have been very reliable. I have also sold many of these to Apogee 400 owners and I haven’t received a call or email about lack of performance.
The Blue Arrows are an entirely different brand; I did use them for a while, but stop because they didn’t perform well at all. I recommend the BMS303, they are the best for that size and work very well with as little as 3.6 v. Jose |
Pensacola, FL, USA
Joined Dec 2000
Room?
To get back to the Apogee Sport, will there be enough room in the pod for using other small servos like HS-55's or GWS Pico BB's? Or, will only the 303's fit the designed space? John255 |
Upstate, NY
Joined Feb 2002
John,
The Apogee Sport is not necessarily designed for any one servo, but for a size of servo that fits the design; you could use the Dymond 47 or any of the Ultra-Micro servos, probably a better fit than the HS-55 would be the HS-50. Jose |
Reason: Necessary > necessarily
The Wing Nut
The wing nut is affixed to the bottom of the wing bolt block using 5 minute epoxy. Be sure to ligntly sand the surfaces of the nylon nut to ensure a good grip for the epoxy.
The wing bolt is used to hold the nut in place. A small rectangular plywood piece will be provided in the kit to span the wing saddle. Protect the bolt threads with Chapstick or a tiny bit of Vaseline, but take care not to get the greasy stuff on any of the surfaces to be glued. Jack Stephens |
Upstate, NY
Joined Feb 2002
Pod boom intersection
Nice job Jack! that was some sanding you had to do in the pod/boom intersection. I adjusted the model, so people will only have to sand half as much in that area.
P.S. I sent you some building materials you are going to need. Jose |
Final Pod Sanding
In sanding the pod to its final shape, the builder will need to refer to the sectional views on the plans to check the desired profile at key points along the pod. Removing too much material at the "corners" could result in an embarrassing hole in the pod.
I still have a bit of sanding to do before glassing the pod, but I think it has a pleasing shape at this point. I will not glass the pod until after the wing is fitted. As a prototype, with all hand cut parts, I need to be sure that the wing saddle is accurate before I commit to the glass. Jack Stephens |
| Thread Tools | |
| New Product Apogee Elite: A New Era in Mini-DLG, Full House from ECM | Jose E Bruzual | Hand Launch | 252 | Jan 12, 2010 08:05 PM |
| New DLG design from Mountain Models | CoClimber | Hand Launch | 290 | Jul 26, 2004 07:22 PM |
| New kit from Climate Models | Climate | Vendor Talk | 0 | Jan 20, 2003 04:22 PM |
| a great new kit from Laser Models! | CrazyMike | Fuel Plane Talk | 7 | Oct 30, 2002 07:47 AM |
| new kit from Great Planes | radioflier | Electric Plane Talk | 4 | Aug 03, 2002 06:25 PM |
