Charged to the point of a Big Bang suggest to me that it was a charging rate and / or a charger problem. IMO, very often the problems experienced by users of high capacity consumer grade AA NiMh cells comes from trying to charge them at to high of a rate. Most of these cells can not be charged at 1C as many suggest. These cells have high IR and as such do not take kindly to fast charge / discharge rates. I am not saying this was the case here but there have been cases of fast chargers which were made for use with very specific cells being used with other cells and cells made for a specific charger being used with other chargers. Charles |
These Sanyo cells look promising however I have been disapointer with the 2700s from Sanyo.I know apples and oranges. http://www.rcgroups.com/forums/showp...&postcount=121 I have used AA NiMH cells in TV remotes, programmable temp. contollers and many consumer electronic devices for many years. I have often stated that high quality NiMH cells do not self-discharge nearly as fast as most seem to believe. One of my test with Sanyo 2500 green sleeved cells resulted in over 6 hours of operation time in a HiTec Eclispe Transmitter after storage for 58 days at room temp.. More recently I have had excellent results with ENERGY 2300s. I just checked the voltage of a cell still sealed in package purchase on 8-2-06( just over 4 months ago) stored at room temp. ,1.26V. Yes it is true that open voltage is not a good capacity test but I know from experience that a cell at 1.26 volts no-load is far from being mostly discharged.Well perhaps I should qualify that by adding that it depends on the load which will be placed on them. TENERGY 2300s purchased 8-2-06 last charged (toped off) on 8-18-06 measured voltage of 8 cells 1.27-1.28 Placed 4 cellls in BC-900 at 500 mA discharge rate. After 5 min. holding at 1.12-1.14 volts. Discharge rate changed to 100 mA and voltage holding at 1.22 volts per cell.. So in an application where the drain would be minor such as a Remote or Memory backup even after close to 4 months these cells are still performing fine. Placed two cells that were holding at 1.22 in a universal TV remote and with continuous on cell measured 1.25V. RAYOVAC HYBRID 2100 mAh NiMH AA which was last charged / disharged on 11-2-06 under a 500 mAh load down to 0.9V and yeilded 1800 mAh placed under an 500 mAh load and after 7 minutes is holding a steady 1.23 volts. This cell has been through approx. 5 full charge / discharge cycles. Charles |
United States, NJ, Frenchtown
Joined Mar 2003
I totaly agree on charger problems.
I have a Hi-Tec #CG-320 charger. Works fine, IF, you are carefull as hell. It does not state on it that it is only for NICAD & NIMH. Has a mode #1 that lets you charge a 4.8volt NIMH at 900 ma. Fine. If you or some one else looks at the switch positions and slides it to 10.8 and mode #3, you are now charging at 1.8 amps. Nicad, OK. Nimh not to good. Still looks like a 900 ma. setup. That is why a in line Amp. meter is really required for SAFE charging. I also put a Volt meter across the battery to check the voltage also. They are only machines, not people. They can not tell when they are wrong and stop. |
RAYOVAC HYBRID 2100 mAh AA update
A single cell tested . Last charged on 11-02-06 and has been stored at room temp. for 9 weeks (63 days).
Tested in LaCrosse at 500 mA discharge rate. 1.24 volts after 2 minutes. After 150 min. (2:30) and 1270 mAh 1.17 volt. 1500 mAh / 1.15 volts. This is equal to approx. 6 hrs. Transmitter on time. I reduced load to 250 mAh (typ. Trans. load) and volts holding at 1.16 after an addational 30 minutes. Perhaps they are not as bad as I first thought. Charles |
Delta, BC, Canada
Joined Oct 2003
They have characteristics like lead-acid batteries. I.E. they hold a charge very, very well (they claim up to 7 years) but don't like to be deep discharged (if you do deep discharge them you'll only get a few cycles out of them before they really start to loose capacity.) I can't tell you how long they will last in a remote. I've been using the same pair for ~5 years now and they've probably only been charged about 5 times. At this rate, I expect they'll last a long time. ![]() Finally, while they are great for low drain devices like remotes, they suck for high drain devices and NIMH's are better in those applications. |
RAY O VAC HYBRID 2100 mAh
Stored at room temp. for 113 days since charging.
Discharged on LaCrosse BC 900. Open cell voltage 1.28 Load 500 mAh start 1.19 1 hour- 500 mAh - 1.17 2 hours -1000 mAh - 1.16 ( equal to 4 hrs. plus with most RC transmitters) 3 -1/2 hours + - 1761 -0.90 ------------------------------------- From A prior post : 82 Day test results 0.9V / 1814 mAh All things considered not bad results IMO. Charles |
It's been a year since that last post and it looks like there hasn't been much excitement about these cells since then. Why not?
Have there been any new developments? Has the capacity of the AA cells increased since then? Are these cells the way to go for transmitter and receiver packs, particularly for folks who want their gear ready to fly even after long storage? Are they a better choice for folks who like to use LiPo cells in their transmitters? |
Latest blog entry: FSS #3, 6/8-6/9 at IRKS
Ray-O-Vac Hybrids in a Spektrum DX7 Tansmitter.
I purchased these cells 14 months ago. They were used lightly a few times and then placed in DX7 approx.4 months ago. They get charged overnight with 110 mA OEM charger approx. once a week and provide approx. 12 Hrs. of Transmitter useage between charges. http://www.rcgroups.com/forums/showp...44&postcount=1 A snip from one of my Ray-O-Vac Hybrids / DX7 test. Quote:
| Thread Tools | |
| Panasonic or Sanyo 3000 mah Nimh's???? | TopGun | Power Systems | 4 | Jul 16, 2001 03:36 PM |
| 270 mah NiMH fast charge?? | jmikeh | Power Systems | 12 | Jul 05, 2001 05:21 PM |
| 4/5 2100 Sanyo NIMH Results | sjslhill | Electric Plane Talk | 1 | Jun 03, 2001 11:58 PM |
| What charge rate on a 700 mah NIMH? | atsiang | Power Systems | 7 | May 30, 2001 11:03 PM |
| 70 mAh NiMH cells | markdrela | Parkflyers | 0 | May 28, 2001 01:26 PM |
