Hi Guys
I am glad to hear that people are still buying these wonderful planes, I maidened my Fokker DVII in May 2012 and since then have flown over 150 flights.
I installed a Turnigy 28 /30 1100 KV motor with a plywood motor mount on it and a 30 amp speed controller. The only modification I had to make was to lower the battery tray and a velcro strap for my 1300 mah batteries, it was just too tight of a squeeze with the Turnigy batteries. I was very nervous with my maiden flight as with my other planes ( PARKZONE Wildcat, ME-109, and UM P-51 Mustang) The Fokker hand launches as easy as my micro Mustang and has a lot of power with my motor set up, it is also a very responsive plane especially the rudder, I am using the Spektrum DX5.
The Fokker DVII is quite strong the only thing that was damaged was a small crack in the fuselage, two of the wing struts popped out once on a hard landing, one of the lower wing tips was slightly damaged ( when landing and one side of the planes wheels hits first noses over hits one wing tip then the other and sounds like you are beating a drum)
Luckily that does not happen very often, and the last thing the landing gear, after some harder landings the struts would start to bow out then I would bend them back an so on, after I had 100 flights I took apart the landing gear, I hammered the landing gear struts straight and reinforced the back two with a CF strip, I glued it on filed it smooth and repainted the whole thing in Fire red, a perfect match, since then I haven't had any problems with the landing gear struts bending.
This summer one of the guys that flies at the park bought a Parkzone SE5a, they look great together, we were able to have mock dogfights
They looked very good together, the SE5a was faster and the flight times were longer but otherwise they were similar.
Under the Christmas tree there is another red plane waiting for me a E-flite Mig-15, I had a chance to fly one this summer and wow what a plane!!
Thanks and enjoy Sabastian
