Old Feb 14, 2007, 10:36 AM
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I find if you land with some power on in grass it does fine. This is even think grass that is up to 3-4 inches tall.
Vintauri is online now Find More Posts by Vintauri
Old Feb 14, 2007, 01:30 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
nose over on landing
I see this nose over problem landing on pavement, I think the drag of the tail in the grass should help, the thing lands so slow it isn't a big deal anyway, the only issue would be grabbing the airfoil between the gear on really long grass. Might make takeoff a bit hard.
burkefj is offline Find More Posts by burkefj
Old Feb 14, 2007, 01:47 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Guys the full scale ones nosed over - it is the axle/wing.
I have landed on grass long and short and pavement. It takes full up (high rate) on grass for me to keep it from ground looping. Pavement is no big deal, just 3pt it in....
That "wing" or axle on both the SE5a and DVII grabs that grass and tries to kick it over - simple as that.
Old Feb 23, 2007, 02:16 PM
Jim Mayer is offline
Find More Posts by Jim Mayer
Jim Mayer's Avatar
Bensenville, Ill. United States
Joined Nov 2003
Well ,
Been following this thread for some time so yesterday I went out and bought the Foker. Got it home did a quick check on all the parts and started detailling. Painted the engine on the batt hatch and started working on the pilot. As I was waiting for the pilot to dry I decided to go over the covering with the trim iron to seal all the edges and seams prior to shrinking as I wanted to use claybusters idea for dulling the finish. I pull out the top wing and find the right aileron tip is broken and the covering is cracked over the break, also the cowl is broken. Call the LHS where I purchased it from and he said to bring it in. I told him I had already painted the engine and started to work on the pilot figure. He then said I should call GP and see if they would send me new parts or a new plane. I said why don't you order another one and when it comes in we'll just switch the batt cover and pilot. He agreed but we'll see.
Jim...
Jim Mayer is offline Find More Posts by Jim Mayer
Old Feb 24, 2007, 09:44 AM
Jim Mayer's Avatar
Joined Nov 2003
Anybody out there have any info on how much and what part of this planes fuse was metal? Was it just the front around the engine or did it go back as far as the cockpit?
Jim..
Old Feb 24, 2007, 09:50 AM
claybuster is offline
Find More Posts by claybuster
Electricholics Anonymous
claybuster's Avatar
WARREN, MICHIGAN
Joined Jul 2005
Jim..
Jim,
This is something I've been trying to find out for a long time.
claybuster is offline Find More Posts by claybuster
Old Feb 24, 2007, 02:13 PM
Jim Mayer's Avatar
Joined Nov 2003
Originally Posted by claybuster
Jim,
Claybuster;
I found this email address experts @overthefront.com supposed to be aces reguarding WWI aircraft. I will let you know what respons if any I get.
Jim...
Old Feb 24, 2007, 04:04 PM
claybuster's Avatar
WARREN, MICHIGAN
Joined Jul 2005
Claybuster;
Jim...
Thanks Jim, I'm looking forward to find out the answer.
Old Feb 24, 2007, 08:24 PM
Jim Mayer's Avatar
Joined Nov 2003
Ok claybuster Got 2 responses. basically they said the same thing an aluminum cowl cut on a diagonal around the engine. My guess is that the batt hatch and the "cheecks" that come with the kit represent the aluminum around the engine.
Jim...
Old Feb 25, 2007, 05:33 AM
claybuster's Avatar
WARREN, MICHIGAN
Joined Jul 2005
Jim...
Thanks Jim!
Now I know what to make dull and what to make look a little shiney.I've also been wondering the same for the SE-5a. If you get a chance and want to give them a call about the SE-5a it would be appreciated.
Old Feb 25, 2007, 04:16 PM
HogCrewChief is online now
Find More Posts by HogCrewChief
Terryville,CT (USA)
Joined Mar 2006
Hey guys I have a little problem and a question. I am putting my ElectriFly Fokker DVII together and I noticed the horizontal stab has a pretty good warp in it. If the stab was not covered in monokote it would be real easy to get the warp out. Is there anyway to get the warp out without taking all the covering off?
Tony
HogCrewChief is online now Find More Posts by HogCrewChief
Old Feb 25, 2007, 04:27 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
Use your fingers to bend the warp out of stab. You should see rinkles appear. Heat these rinkles with your heatgun to shrink them out. The stab should be true now.
You have it backwards... The fact that it is covered makes it simple to get the warps out.
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Feb 25, 2007, 06:20 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Be careful with the amount of heat you apply. That covering is very low temperature.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Feb 25, 2007, 08:26 PM
Terryville,CT (USA)
Joined Mar 2006
Thanks for the help. I will try getting it straight and putting the heat gun to it tomorrow night.
Tony
Old Feb 25, 2007, 10:08 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
Good. Just be careful you don't apply too much heat in one area. My gun has a spring type trigger, so I just pulse it on and off and varying frequency's to keep it at a good temp. Perhaps holding each side flat on a table while you shrink will be easier. With warps in fuses and wings, you usually just tweak it with your fingers.
For Sale Great Planes ElectriFly Fokker D.VII HogCrewChief Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2007 05:52 AM
New Product **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Electric Warbirds 3 Sep 12, 2006 01:26 PM
New Product **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Product Announcements 0 Aug 31, 2006 01:30 PM
Discussion **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Jim T. Graham Product Announcements 4 Aug 18, 2006 09:50 PM
New Product Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Scale Kit/Scratch Built 0 Aug 15, 2006 05:47 PM
