Old Nov 10, 2006, 03:11 PM
Russell
Russell
Guest
n/a Posts
Re: Converting a Myford S7 to Imperial
Hi Ian
I expect someone will correct me if I'm wrong but I think even metric
Myfords have imperial lead screws. Cheapest and easiest therefore would
be a cross slide screw and nut which would bring it to correct spec for
a metric machine.
Russell
strikergreen97 wrote:
> Hi, I am new to Model Engineering and have just purchased a good (to
> me) Myford Super 7. It looks like the previous owner looked after it
> well and started to converter it to an Imperial Machine but did not
> finish the job.
> The LeadScrew is 8 TPI with wheel marked in 0.125" per revolution.
> 0.001" steps..
> The CrossSlide is 10 TPI but still has the Metric micrometer Dials.
> Very Confusing.
> The TopSlide (compound Slide) has a 2mm pitch Screw and Metric Dials.
> My question is it easy to swap the metric items menchioned above to
> imperial. ?
> The Lathe also came with a 3 Phase Motor 370W (1/2 Hp) Book Crompton,
> which I am thinking of converting to Variable Speed, But thats another
> day, one thing at once.
> thanks ian.
Old Nov 10, 2006, 05:11 PM
Charles Lamont
Charles Lamont
Guest
n/a Posts
>Myford Super 7
>0.001" steps..
>Very Confusing.
>imperial. ?
You can get imperial (or metric) feedscrews, nuts and dials from Myford.
Fortunately you do not want a metric leadscrew, as these are still not
made, AFAIK.
Charles Lamont
Re: Converting Mini Helicopter Electrics to a GWS Foamy Michnet76 GWS (Grand Wing Servo) 8 Nov 03, 2004 11:27 AM
