Old Nov 10, 2006, 10:42 AM
GaryB is offline
Find More Posts by GaryB
GaryB's Avatar
Topeka Billard, Kansas, United States
Joined Feb 2001
Multiplex FunJet vs ParkZone F-27C Stryker
...i've owned 2 Projeti's - both with Mega 3 turns - they were in the 100mph range (and are both now departed)...
...i'm still flying my Multiplex Pico Jet w/Mega 3 turn - it's not quite as fast (probably in the 85 to 95mph range)...
...so when Horizon claims 80mph for their F-27C Stryker i'm not too impressed - i'd like something as fast as my old Projeti's with more durable foam - which would come closer to getting me there...the Multiplex FunJet or the ParkZone F-27C Stryker?...
GaryB is offline Find More Posts by GaryB
Old Nov 10, 2006, 05:01 PM
pache11 is offline
Find More Posts by pache11
pache11's Avatar
United States, IL, North Aurora
Joined Mar 2005
F-27C will do about 70-75 straight and level max stock. It does have a very nice flight envelope. Can be flown very slowly or fast. This design has alot of drag so it will be expensive to push to 100 or better. It is a very durable airframe and has forgiving flight characteristics
pache11 is offline Find More Posts by pache11
Old Nov 10, 2006, 07:14 PM
Piledriver is offline
Find More Posts by Piledriver
almost slackin
United States, MO, St Peters
Joined Dec 2005
The Funjet is easily faster but less forgiving than the Stryker, using same weight and power.
The Funjet is as capable as a Stryker of slow flight but is just a little less floaty.
The Funjet has better roll rate and less drag.
Piledriver is offline Find More Posts by Piledriver
Old Nov 10, 2006, 07:48 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Just Get a Stryker body for $20.00, carve off the air intakes to stream line it, put balsa elevons, projeti type tail and put in a hot motor! Butch
Butch777 is offline Find More Posts by Butch777
Old Nov 10, 2006, 08:05 PM
GaryB is offline
GaryB's Avatar
Joined Feb 2001
...thanks for the info - i think i'm leaning toward the FunJet - are they now available in the USA?...
Old Nov 10, 2006, 08:14 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
They should be available through GP or Global, but suppy may be an issue.
After building and flying the FJ the Stryker seems slow and mushy. I really enjoy the FJ, it took a few flights to adjust to it from the stryker, but it is a superior design. Sorry if this offends any of the Stryker faithful, but I'm convinced the FJ is superior.
Ryan
rycomm is offline Find More Posts by rycomm
Old Nov 10, 2006, 11:22 PM
RCPlains is offline
Find More Posts by RCPlains
Joined Jan 2005
...Hobby People doesn't list the FunJet - Tower's site says available in mid-November - anybody else carry the FunJet?...
RCPlains is offline Find More Posts by RCPlains
Old Nov 16, 2006, 10:53 PM
Mach61 is offline
Find More Posts by Mach61
Ottawa, ON. Canada
Joined Oct 2006
I love the Stryker but it is true that if you want speed instead of just cruising around you should go for a less draggy airframe like the Funjet or a wing. Stryker design based on a glider - flies and looks great. Have not got the Funjet yet but fly the Microjet which is a crazy fast little bird. Too bad they discontinued it but Funjet should be better flyer and easier to see.
Mach61 is offline Find More Posts by Mach61
Old Nov 19, 2006, 12:19 AM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
its discontinued? whats this then?
http://www2.towerhobbies.com/cgi-bin...?&I=LXFRU8&P=7
mecevans is offline Find More Posts by mecevans
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion ParkZone F-27C Stryker blindman Parkflyers 7 Jul 01, 2007 04:12 AM
Discussion Parkzone F-27C Stryker LoneStarLegendRC Electric Plane Talk 3 Mar 30, 2007 09:34 PM
