This thread is privately moderated by tim_mellor, who may elect to delete unwanted replies.
Old Oct 03, 2010, 10:17 AM
Block is offline
Find More Posts by Block
Syracuse, NY (USA)
Joined Dec 2004
For checking calibratiion/accuraccy of 1g resolution scales, use a known weight such as coins (google to find their weights). My $30 scale from OfficeMax is very accurate to 1gm.
Block is offline Find More Posts by Block
Old Nov 29, 2011, 09:24 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Models and Equipment used ...
at the German Indoor Aerobatics Championship 2011 in F3P-Expert class:
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 29, 2011, 09:47 AM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Other than airframes, no huge changes from last year. Would that be a fair assessment?
Trisquire is offline Find More Posts by Trisquire
Old Nov 29, 2011, 11:30 AM
bmz is offline
bmz
Find More Posts by bmz
bmz
Joined Mar 2009
The servos FS31 almost disappeared
The weight stay constant, but the servos are heavier
Mfly motors disappeared, replaced by SG motors
bmz is offline Find More Posts by bmz
Old Nov 29, 2011, 02:31 PM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Hitec 5035 arrived and is sure best servo for such low weight. This servo is on my Symmetric ruder, and im happy about it. I cut wire down and get 3.3g. I get mine at Autopartner.se
I still like JR servos allot but it is very hard to bring plane weight down without using latest hot releases.
3Don is offline Find More Posts by 3Don
Old Nov 30, 2011, 02:43 AM
Kimmo Kaukoranta is offline
Find More Posts by Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
Are you guys running the 5035's with 5V from the BEC or direct from 2S? At least Markus seems to be using them with the YGE-4 that does not have a BEC. Will they hold up?
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Nov 30, 2011, 01:20 PM
-MZ- is offline
Find More Posts by -MZ-
Joined Feb 2010
Yge 4
Hi Kimmo,
i use the YGE 4 (the old version with BEC ). It works very fine!
Cheers
Markus
-MZ- is offline Find More Posts by -MZ-
Old Dec 01, 2011, 01:21 AM
Tampere, Finland
Joined Apr 2004
Thanks Markus! I did not realize there were 2 different versions of the YGE-4. I only have the "4S" versions with no BEC.
Old Dec 01, 2011, 06:43 AM
Joined Sep 2000
Models and equipment used ...
at the German Indoor Aerobatics Championship 2011 in F3P-AM class:
Old Dec 13, 2011, 02:44 PM
jibber is offline
Find More Posts by jibber
Joined Jan 2009
Hi,
can anyone tell me why they are using the hs-65hb on ailerons?
I think it is somehow slow.
Why is nobody flying with Futaba S3114 or s3154/3154mg on ailerons?
does the hs65hb crash better because of the carbonite gear?
Think for the F3P stuff the HS5035 is a good servo for all control surfaces.
But I can't make up my mind on AM-plane servos....any advise?
cheers,
cyril
jibber is offline Find More Posts by jibber
Old Dec 13, 2011, 03:19 PM
racerxky is online now
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
Originally Posted by jibber View Post
Hi,
cheers,
cyril
I dont think anyone at that level cares about crashing. If you crash you loose.
The HB servos weigh less than their MG counterparts. I'm sure these guys stripped the servos down to save weight.
The larger Hitec servos have more torque. We use these servos in F3P with very long arms and as such we divide the torque they provide. Things tend to be slow because the servos lack torque more than they lack speed. Going to a faster servo will only make things faster if you have an oversupply of torque.
The Hitec stuff has proven itself to be very robust servo for this size application. The new HS-45HB is pretty amazing. The HS-65HB is bomb proof at this size. I've personally burnt up some expensive Futaba digitals in this application so now I stick with the Hitec stuff.
racerxky is online now Find More Posts by racerxky
Old Dec 14, 2011, 04:12 AM
jibber is offline
Joined Jan 2009
Hi,
thanks a lot for your answer. That helps.
I will give the 65hb a try...
you re right about the crashing at this level...:roll eyes:
cheers,
cyril
Old Mar 14, 2012, 04:04 AM
Volodymyr is offline
Find More Posts by Volodymyr
Poland, Podkarpackie Voivodeship, Jaroslaw
Joined Nov 2010
And what about equipment that was used at Iitop 2012?
Volodymyr is offline Find More Posts by Volodymyr
Old Mar 15, 2012, 02:11 AM
Joined Sep 2000
The data was collected and displayed at the entrance of the hall. I have not seen a spreadsheet online however.
Jürgen
Old Mar 15, 2012, 05:43 AM
alan_g is offline
Find More Posts by alan_g
Joined Feb 2011
Here is the photo of collected data of used equipment. If you zoom in with the icon on the top of the picture, it is possible to read almost everything..
https://picasaweb.google.com/alan.go...67263570935810
Best wishes,
Alan G.
alan_g is offline Find More Posts by alan_g
Discussion E-Starter and equipment weight Fallout Beginner Training Area (Aircraft-Electric) 7 Jan 19, 2007 02:13 PM
Discussion EVO Size & Weight information wanted MrMel Batteries and Chargers 1 Aug 21, 2006 06:48 PM
Cool Buying Used Equipment - Weight the Risk aeajr Beginner Training Area (Aircraft-Electric) 4 Feb 21, 2005 04:53 PM
