This thread is privately moderated by tim_mellor, who may elect to delete unwanted replies.
Old Jul 03, 2007, 11:22 PM
racerxky is offline
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
!!! I hadn't seen this stuff. Looks promising for sure!
racerxky is offline Find More Posts by racerxky
Old Jul 04, 2007, 05:42 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Aio_1
Seems there's a new ESC worth looking at.
Castle creations have a new Thunderbird 6 on their website.
It looks to be ideal for F3P.
6 Amp ESC that weighs 4g (advertised).
Over here we have the YGE series (Heino Jung):
YGE6 = 0.6g (1.1g with cables), 1A BEC
YGE8 = 2.2g (4.9g with cables), 2A BEC
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 29, 2008, 09:41 AM
FAI_guy is offline
Find More Posts by FAI_guy
Joined Jul 2007
Jürgen
And MGM has a special brushless controller for 1S Li-poly:
TMM 0703-3 Expert
7 A continuous, 10 A peak, 1 A BEC, 1.1 g (3.7 g with cable & connector).
The Gasparin ESC as used in the miniature 3D plane is a stripped down version of that controller.
FAI guy
FAI_guy is offline Find More Posts by FAI_guy
Old Apr 01, 2008, 01:52 PM
Joined Sep 2000
Models and Equipment Information ...
from the Top-Ten of the German Indoor Aerobatics Championship 2008:
Old May 13, 2008, 01:43 AM
rcgood is offline
Find More Posts by rcgood
rcgood's Avatar
San Antonio, TX
Where do you get those YGE controllers?
rcgood is offline Find More Posts by rcgood
Old May 13, 2008, 05:06 AM
rmr24 is offline
Find More Posts by rmr24
rmr24's Avatar
Joined Jul 2006
http://www.bsdmicrorc.com/productDet...01&catID=10037
http://www.homefly.com/products.asp?id=33
http://www.wes-technik.de/English/controller.htm
rmr24 is offline Find More Posts by rmr24
Old May 28, 2008, 07:34 PM
scharlach is offline
Find More Posts by scharlach
United States, GA, Sharpsburg
Joined Jan 2005
1.2 gm servo
If anyone is interested in a 1.2gm servo that has enough power to
control 4 oz fast airplanes. See thread titled 1.2gm servo improvements
under indoor and micro airplanes
scharlach is offline Find More Posts by scharlach
Old Aug 24, 2008, 06:14 PM
dkselw is offline
Find More Posts by dkselw
Warwick, Qld, Australia
Joined Aug 2004
The JR R610M receiver is listed here as weighing 9g or 6g without case. Would this be without the antenna and the crystal?
This website http://www.hstore.com.au/ProductSear...rodID=JRPR610M lists the R610M as weighing 11.6g or 9g without the case. I weighed my R610M, with case, full length antenna and crystal it weighs about 12g (not very accurate scales though).
I am thinking of trying the Hyperion DSP4-TSR receiver, listed here http://www.airstrike.com.au/Hyperion%20Receivers.htm as 7g total weight with antenna. Can anyone confirm this weight?
dkselw is offline Find More Posts by dkselw
Old Aug 25, 2008, 05:31 PM
dkselw is offline
Joined Aug 2004
I measured the following components with calibrated laboratory grade scales, rounded to the nearest 0.1g:
Propellers
GWS EP-7035 2.8g
GWS EP-8040 5.3g
APC 8x3.8 SF 6.5g
APC 9x3.8 SF 8.5g
APC 9x4.7 SF 9g
Servos
GWS PICO+BB (including standard wires and a single sided servo arm) 7.5g
The claimed weight for this servo on the card that comes with the servo is 6.2g, and on the side of the servo is 6.5g.
Receivers
JR R610M (including case, crystal and original antenna) 14.2g
JR R610M (without case but including crystal and original antenna) 11g
The crystal weighs 1.53g (including the plastic end piece).
Old Nov 03, 2008, 08:17 PM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
What are a good replacement for Dymond 4.7? That have good centering,speed and tork.
Nicoflyer is offline Find More Posts by Nicoflyer
Old Nov 28, 2008, 09:26 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
DesirePower 2cell 360mAh claimed 19gram. The 2 i bought weighs 24.8 and 24.9 grams with balance and power leads/plugs. (altho they are pretty short.)
methuso is offline Find More Posts by methuso
Old Nov 28, 2008, 11:05 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
There are definitely some distributers around who look at the competition and advertise their own products with the specs they'd like them to have rather than telling you what they're really selling. It's infuriating and all too common.
We should really be sending the stuff back and demanding a refund but they know most of the time we won't bother.
Of course there are plenty other specs they could be lying about that are harder to identify. For example are the cells really 360mAh or capable of whatever C rate was claimed.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Jan 26, 2009, 02:21 PM
Dimitry999 is offline
Find More Posts by Dimitry999
Hungary
Joined Feb 2007
Arced Digital Micro Servos
Hey everyone!
Just have a quick question:
Does any of you use the arced digital servos from 2dogrc.com?
http://www.2dogrc.com/ecommerce/os/c...c-104_155.html
Dimitry
Dimitry999 is offline Find More Posts by Dimitry999
Old Mar 13, 2009, 10:21 PM
rcgood is offline
rcgood's Avatar
San Antonio, TX
What's a really good, reliable and accurate scale that has at least a .01g resolution? I did some searches and seems like American Weigh scales are pretty popular but I want to hear from people that have been using different fine resolution scales.
Old Mar 25, 2009, 10:05 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
How much are you willing to pay?
Top quality instrumentation doesn't come cheap.
Discussion E-Starter and equipment weight Fallout Beginner Training Area (Aircraft-Electric) 7 Jan 19, 2007 02:13 PM
Discussion EVO Size & Weight information wanted MrMel Batteries and Chargers 1 Aug 21, 2006 06:48 PM
Cool Buying Used Equipment - Weight the Risk aeajr Beginner Training Area (Aircraft-Electric) 4 Feb 21, 2005 04:53 PM
