This thread is privately moderated by tim_mellor, who may elect to delete unwanted replies.
Old Nov 09, 2006, 11:05 PM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Data
F3P Equipment Weight and Information
This is a resource sheet for fliers of light weight F3P or Light Indoor 3D planes (under 200g). With the large number of Servos and growing variety of ESC, Rx, Motors etc and the sometimes inaccurate data given by sellers or manufacturers maybe it is time to do our own.
Data prefered at this stage is "ACTUAL USER DATA" manufacturers of light weight equipment cheat about weights in particular wire weights and plug headers.
The attached Zip file is an excel spreadsheet, as it starts to fill up I will also place a PDF version here as well. Please feel free to post anything to add to the list here. This is not a dicussion thread and postings will be trimmed over time as the data is added to the chart.
If any of you want to add to the excel file then feel free
Tim
tim_mellor is offline Find More Posts by tim_mellor
Old Nov 12, 2006, 11:28 PM
AirNerd is offline
Find More Posts by AirNerd
GIMMIE FOAM!!!
AirNerd's Avatar
Edwardsville KS
Joined Oct 2005
I just bought a Cyclon Micro...and it indeed weighs 27 G's
AirNerd is offline Find More Posts by AirNerd
Old Nov 12, 2006, 11:30 PM
AirNerd is offline
GIMMIE FOAM!!!
AirNerd's Avatar
Edwardsville KS
Joined Oct 2005
I can also take 2 grams off HS-50s & 55s.
Old Nov 13, 2006, 03:44 AM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Hi All,
I have about run out of bits to add. Anyone got any other bits numbers or links to fill in the gaps please add them. Even if you think a particular item shouldn't be there post it and why not or if the item is a bit suspect for this use.
In particular can someone have a good look at the Futaba Rx and Servos, they have been poorly supported in Australia so very few people use them. JR Rules down under
thanks
Tim
Old Nov 13, 2006, 07:42 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Tim,
For the receivers it might be worth splitting the 35MHz/36MHz and 72MHz units into two groups as many types are only available in one or the other.
The following are all 35MHz (probably 36MHz too?)
Where 2 weights are shown they indicate: (Claimed weight/~measured weight).
My scales are only accurate to 1 gram thus the ~.
Receivers (35MHz)
Multiplex RX-5 (8g/~9g)
Jeti Rex 5 (8.5g)
ACT Pico 4 (4.5g/~5g with full size crystal) - I like this receiver!
ACT Digital 4 (5g with crystal)
MZK Penta (2.8g)
MZK Penta light (2.1g)
MZK Penta pro (4g)
MZK Quadra
Motors
MicroREX220-3-3200 (11g/~12g) - may be slightly high but scale error is 1g!
MicroREX220-6-1600 (21g/~21g)
MicroREX220-6-2000 (21g)
Cells
3s TP480 prolite (32g/~37g as supplied)
2s Hyperion 300mAh 20C (~19g with 40mm cable & micro deans)
ESC
CC ThunderBird 9 (8g/~9g)
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Nov 13, 2006, 11:37 AM
aglenn is offline
Find More Posts by aglenn
aglenn's Avatar
Joined Aug 2004
The best indoor combo for f3p that i have found is the Axi 2203 -47 Phoenix 10 2 Dog rc 2 cell 360 and a berg 4l
aglenn is offline Find More Posts by aglenn
Old Nov 13, 2006, 06:11 PM
RCAV8R13 is offline
Find More Posts by RCAV8R13
I'm goin' Falcon nuts
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
I found this GIF on another thread. I hope I don't get in trouble for reposting it but it has a lot good info on what the "Pros" are using in Europe.
RCA
RCAV8R13 is offline Find More Posts by RCAV8R13
Old Nov 13, 2006, 06:50 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
That's Jürgen's. He won't mind.
Tom
Trisquire is offline Find More Posts by Trisquire
Old Nov 13, 2006, 07:02 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
thanks RCA,
I used to have a few of those from earlier this year (posted here somewhere) but lost them along the way.
Tim
Old Nov 15, 2006, 02:15 PM
Mister UHU is offline
Find More Posts by Mister UHU
Mister UHU's Avatar
London UK
Joined Dec 2005
Tim : this is such a useful thread.
Brilliant !!
Days of work, all done, what a time saver.
Now all that is needed is a popularity or personal rating index,
and any dummy can be an instant expert.
Thanks Tim !
Mister UHU is offline Find More Posts by Mister UHU
Old Nov 16, 2006, 03:30 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Hi all,
Version 2.0 is underway. I will also do a PDF version along with that one. Should be done in a couple of days.
Still working on it work is getting in the way
Tim
Old Nov 21, 2006, 06:02 AM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
Strecker website: www.rs-e-motoren.de
The 12 grams 195.03 motor is superior for F3P, but has a pricetag...
The Strecker is 1500kV, the MicroRex 3200kV and the NanoCyclon 1900kV.
Impressions here in Holland are the MicroRex does not have the pull out of the Strecker, maybe the 1900kV NanoCyclon is a better budget option.
www.mamo-models.com is selling the NanoCyclon too now and started advising this motor instead of the MicroRex for the new Manta kit....
Pjotrrr is offline Find More Posts by Pjotrrr
Old Nov 22, 2006, 11:39 PM
RCAV8R13 is offline
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
New 17g motor from MP Jet
I found this at Icare. Looks promising. $45.00 and has two ball bearings.
http://www.icare-rc.com/mpjet.htm
RCA
Old Nov 23, 2006, 12:03 PM
AirNerd is offline
GIMMIE FOAM!!!
AirNerd's Avatar
Edwardsville KS
Joined Oct 2005
Cyclon Nano
I got robed!!! JOke Joke...you can delete me
Old Nov 25, 2006, 10:58 PM
RCAV8R13 is offline
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Take the O ring off. I'll bet it weights .2g.
RCA
Discussion E-Starter and equipment weight Fallout Beginner Training Area (Aircraft-Electric) 7 Jan 19, 2007 02:13 PM
Discussion EVO Size & Weight information wanted MrMel Batteries and Chargers 1 Aug 21, 2006 06:48 PM
Cool Buying Used Equipment - Weight the Risk aeajr Beginner Training Area (Aircraft-Electric) 4 Feb 21, 2005 04:53 PM
