Old Nov 07, 2006, 08:11 AM
jontom_1uk@hotmail.com
Guest
n/a Posts
Close fitting threads - how do I machine them?
Hi, all, i'm trying to machine a close fitting internally threaded
sleeve for a 40mm X 1mm threaded spigot. Any tips on how I can do it?
Current attempts (3) have all ended in loose fitting scrap. I'm cutting
internally with a single point tool and repeating the final cut at the
same setting until nothing more is removed. The sleeve will not screw
on, a further miniscule cut results in the thing being loose. I really
want a fit that produces a smooth movement with slight drag along a
length of approx 20mm. Am I expecting too much? I'm begining to think
that I will need to make the sleeve in two parts with some adjustment
between to obtain the sort of feel I want.
Any tips, help would be much appreciated.
Best regards
Keith
Dave Baker
Dave Baker
Guest
n/a Posts
Re: Close fitting threads - how do I machine them?
<jontom_1uk@hotmail.com> wrote in message
news:1162904940.746510.121340@f16g2000cwb.googlegr oups.com...
> Best regards
> Keith
Sounds like you're learning the hard way about spring cuts. If you let a
tool cut and recut on the same setting it'll rub and stop removing any
material. Add even a tiny amount to the setting and it'll dig in again and
remove a big chunk of metal. You need to find a speed and feed that let you
get the desired size on the first or second pass. Trying to 'creep up' on a
dimension is one of the hardest things to do in engineering. You get to
within a thou or so and then you're buggered because more cuts at the same
setting do nothing and changing the setting goes straight past where you're
trying to be. Machine rigidity is the key here. If there's no movement in
the machine or the tool you can take tiny cuts with a reasonable amount of
precision. Boring tools aren't rigid though by definition. External tools
are always sturdier.
Dave Baker
Puma Race Engines
www.pumaracing.co.uk
Camp USA engineer minces about for high performance specialist (4,4,7)
Old Nov 07, 2006, 10:11 AM
Tony Jeffree
Tony Jeffree
Guest
n/a Posts
On Tue, 7 Nov 2006 13:41:54 -0000, "Dave Baker" <null@null.com> wrote:
>External tools
For that reason, it may be a better game plan to machine the spigot
thread to fit the female thread, not t'other way around.
Regards,
Tony
Tony Jeffree
Tony Jeffree
Guest
n/a Posts
On 7 Nov 2006 05:09:00 -0800, jontom_1uk@hotmail.com wrote:
>I really
Alternative approach - use a suitably thick & chewy grease on a
relatively loose fitting thread to give you the right smoothness/drag
charagteristics?
Regards,
Tony
Peter Neill
Peter Neill
Guest
n/a Posts
> Alternative approach - use a suitably thick & chewy grease..
> Regards,
> Tony
Lucas Red n' Tacky Grease - the stickiest,
most-bugger-to-get-it-off-ish one that I've come across.
Only applicable if you plan to go down said route of course.
Peter
Old Nov 07, 2006, 12:11 PM
Boo
Boo
Guest
n/a Posts
I haven't tried it, but istm that you might be better off trying to grind/lap
the internal thread. Maybe you could make a male thread that's a little on the
small side and then slather on some grinding paste and just ease the fit using
that ?
Hth,
Boo
Old Nov 07, 2006, 02:11 PM
Charles Lamont
Charles Lamont
Guest
n/a Posts
In message <1162904940.746510.121340@f16g2000cwb.googlegroups .com>,
jontom_1uk@hotmail.com writes
>Best regards
>Keith
You need to make sure you are contacting on the thread flanks and not
the crest or root. Bore it initially to a size that truncates the
internal threads - 38.9 mm. Then cut the thread with a sharp pointed
tool, no radius.
Charles Lamont
Old Nov 08, 2006, 06:11 AM
Austin Shackles
Austin Shackles
Guest
n/a Posts
On or around Tue, 7 Nov 2006 13:41:54 -0000, "Dave Baker" <null@null.com>
enlightened us thusly:
making sure the tool is seriously sharp seems to help - I was cleaning out a
bore the other day and getting erratic answers, then I reground the boring
tool...
FWIW, and may not help in this case, it's easier IME to get close fitting
threads by cutting the internal one first and then the external one.
Mind, had some annoying answers with that recently - I use some small ball
joints which have M8x125 threads on control rods, which need to be
adjustable length. Made a nice thread on the rods, which fitted the
locknuts beautifully, but only screwed half-way down the ball joint thing.
Running a tap down the ball joint thread didn't make it any better, had to
tighten up the die a touch and recut the one on the rod, which naturally
then did a crappy job (the die wasn't new). I've bought a new die now.
which reminds me, was going to order some bits and pieces...
Austin Shackles. www.ddol-las.net my opinions are just that
"The breezy call of incense-breathing Morn, The swallow twittering
from the strawbuilt shed, The cock's shrill clarion, or the echoing
horn, No more shall rouse them from their lowly bed."
Thomas Gray, Elegy Written in a Country Churchyard.
Old Nov 08, 2006, 10:11 AM
Guest
n/a Posts
> >material. Add even a tiny amount to the setting and it'll dig in again a=
nd
> >remove a big chunk of metal. You need to find a speed and feed that let =
you
> >get the desired size on the first or second pass. Trying to 'creep up' o=
n a
> making sure the tool is seriously sharp seems to help - I was cleaning ou=
t a
> tool...
Thanks guys' good advice as always. Unfortunately I can't cut the
internal thread first on this occasion as I'm trying to make use of a
plate and spigot I already have. If I can get it to work as I want then
it will be an exposed thread in a dusty environment so I'm sorry to say
the (old car MOT) trick with the thick grease is a non starter this
time as well
I think Dave hit the nail on the head with my tendency to creep up on
the finish size, I will try and be a bit more confident with my final
cut and re-sharpen the tool as well to give it some sort of chance. In
thinking about what I was doing I was also as Charles guessed trying to
cut a full depth thread so I will truncate it and see if that eases the
problem, the one on the spigot is only about 80% anyway now that I've
had a proper look. I haven't cut a thread using a tap but will
certainly give that a go as it must produce a better thread form than
my poorly ground single point tool.
Altogether, a real team effort with something helpful from all of you,
thanks very much it is appreciated.
Dave, on another subject altogether I enjoyed reading your article on
what is available from the old Ford Crossflow. I have an old Westfield
with one in and have been planning to replace it with a Zetec but
reading your comments I think I will give it a bit more thought before
jumping in to spend =A32K or so.
Best regards
Keith
Wayne Weedon
Wayne Weedon
Guest
n/a Posts
> time as well
If your machine and Internal tool are light, then you might try using
the setover technique, which also works for internal threads. This will
load you tool much less than a perpendicular cut, you can then take
much lighter cuts.
The only difficulty with this technique is when screwcutting to a
shoulder, but thats always a chore unless I'm doing it on one of the CNC
machines.
Unless I'm in a hurry. I always use setover but mainly for external
threads. It's much easier to keep track of what depth you at at, at any
given time.
Wayne...
Old Nov 08, 2006, 12:11 PM
Dave Baker
Dave Baker
Guest
n/a Posts
news:1162999957.419557.143310@k70g2000cwa.googlegr oups.com...
I've never done any screwcutting myself as my mate with a CNC can do it for
me but I don't think I'd even try with a hand ground tool for my first
attempts. Those carbide inserts for threading will have the exact tooth form
properly shaped on them and be very sharp. Trouble is that's a lot of
expense for a one off job. If your tool isn't exactly the right shape and
uniformly sharp in all areas I can't see you getting a good thread from it.
>jumping in to spend 2K or so.
I'd definitely go Zetec and it won't cost 2k. The late model (1998 onwards
Focus and Mondeo) solid lifter 2.0 engines can be found for 250 or less
these days. My mate gets them for peanuts because he has a nice relationship
with his local scrappy. They have bigger valves than the earlier hydraulic
tappet ones and despite being rated at only 130 bhp they crank out a solid
175/180 bhp every time with just 45mm DCOEs and a decent exhaust. The
standard induction plenum and exhaust manifold are terribly restrictive. We
found 15 bhp just from a tubular Focus ST170 exhaust manifold on both my 2.0
Focus and a friend's. DCOE's add the rest. Add a pair of cams and 200 bhp is
not hard to get even without any head porting. The engines are bulletproof
and don't show bore or crank wear because they all get run on the synthetic
Ford 5-30 oil. They also have a brilliant baffled sump as standard which
eliminates oil surge even in track use.
Even with fitting kits, clutch, exhaust etc 1k should cover everything and
you won't get much out of a Crossflow by only spending that much. All Ford
four pots have the same bellhousing bolt spacing so it's an easy fit to a
Westy.
Dave Baker
Puma Race Engines
Guest
n/a Posts
Dave Baker wrote:
> I'd definitely go Zetec and it won't cost =A32k. The late model (1998 onw=
ards
> Focus and Mondeo) solid lifter 2.0 engines can be found for =A3250 or less
> these days. My mate gets them for peanuts because he has a nice relations=
hip
> standard induction plenum and exhaust manifold are terribly restrictive. =
We
> found 15 bhp just from a tubular Focus ST170 exhaust manifold on both my =
2=2E0
> Focus and a friend's. DCOE's add the rest. Add a pair of cams and 200 bhp=
is
> and don't show bore or crank wear because they all get run on the synthet=
ic
> Even with fitting kits, clutch, exhaust etc =A31k should cover everything=
and
> Westy.
> Dave Baker
> Puma Race Engines
Thanks Dave that's superb information. My concern was the ignition as a
decent system seems to be lots of beer tokens. I will only really be
looking for 150 bhp or so as my two kids currently drive it and I don't
want to make it too "interesting" for them - I'll never get a go again.
Pity about the 45's though as I have a pair of DCOE 40's in the garage
doing nothing still I expect E-bay will come to the rescue.
Thanks again Dave that has made my mind up for me, I'll start
collecting the kit of parts ready for the change.
Hadn't thought about the inserts either and I think I have one in some
of the unused tools I have bought in the past as part of a set so I'll
have a look in some of the darker corners of the garage.
Best regards
Keith
Discussion Watts , Mah And C Ratings - How do I work them out gjchester Batteries and Chargers 6 May 28, 2007 09:50 AM
Help! Replacing servos - How do I set them up? Hoopstar Micro Helis 2 Dec 30, 2005 12:32 AM
Help, I'm getting Overrun by Pop-Ups, How do I stop them? mrebman Life, The Universe, and Politics 18 Aug 07, 2003 05:08 PM
How do threads close? King Kong Parkflyers 4 Nov 06, 2001 11:08 AM
How do Multiplex Tx owners like them? sblack Electric Plane Talk 28 Jul 18, 2001 12:36 AM
