Old Nov 06, 2006, 07:54 PM
IBWingnutz is offline
Find More Posts by IBWingnutz
Build, Fly, Crash. Repeat
Tampa, FL
Joined Oct 2005
E-Flite 450 or 480 Outrunner
I have both sitting in front of me, but which to use? I am working on a new Ultrafly 300S Extra (~20oz)(35" Wingspan) which I want top speed more than anything... specs of each are:
Park 450 BL 890KV
Recommended props: 9x6 to 11x3.8 Slow Flyer or 10x5 to 12x6E
Weighs: 72g (2.5 oz)
Current rating: 14A continuous, 18 Burst
Park 480 910 KV
20A continuous, 25 burst
Weighs: 87grams or 3.1oz
10x6 - 12x6 Prop
I know most of these outrunners can be pushed harder than this with proper airflow, the dozen or so 370s i have can really take a beating.
These KV's look low for something speedy right, what is obtainable in terms of top speed?
edit: battery will be a 3cellTP2100
IBWingnutz is offline Find More Posts by IBWingnutz
Old Nov 06, 2006, 07:57 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Great question. I'll be waiting on a good answer also.
I have some thoughts, but don't want to muddy the water so to speak.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Nov 06, 2006, 08:17 PM
HPSOV is offline
Find More Posts by HPSOV
Sydney, Oz.
Joined Mar 2006
The 480 is used by a lot of people in the Katana Mini at around 28oz on an 11x5.5E.
I'd say the 450 would have plenty of power for a 20oz plane.
HPSOV is offline Find More Posts by HPSOV
Old Nov 06, 2006, 08:22 PM
Tampa, FL
Joined Oct 2005
Up to what point though can I equate power to speed? Sure these guys could produce lots of thrust but 3d isn't my goal? The LHS initially gave me a 450 for the model so yeah you're right it should
Old Nov 06, 2006, 08:32 PM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
If you want off tap unlimited 3D go the 480, if you want nice solid performance for a 1/2 oz weight saving the 450 is plenty. The other option is to go the 480 and simply deprop it a bit until you want the extra performance later More Power = more fun
Tim
tim_mellor is offline Find More Posts by tim_mellor
Old Nov 06, 2006, 08:53 PM
MailOrderGuy is offline
Find More Posts by MailOrderGuy
Sir Buildsalot
MailOrderGuy's Avatar
Stockbridge, GA
Joined Nov 2002
Originally Posted by IBWingnutz
Park 480 910 KV
APC 11x5.5E
I am flying this setup on my Eflite Mini Ultrastick (24oz) , TP prolites of course TONS of power at 20amps WOT. Will go straight up till I say stop. Very good top speed too.
I may step up to the 12x6E and see what that prop does for me, got goosy bumps thinking about it
I think there's only a $5 difference between the motors, HECK! go for the 480, you'll have power in reserve .
My .02 worth
MOG
MailOrderGuy is offline Find More Posts by MailOrderGuy
Old Nov 06, 2006, 09:26 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
If you want speed, go more pitch, less diameter.
And if you really want speed, you should use a higher kv motor.
Pinecone is offline Find More Posts by Pinecone
Old Nov 07, 2006, 03:38 AM
R/C Dallas is offline
Find More Posts by R/C Dallas
R/C Dallas's Avatar
Italy, Friuli-Venezia Giulia, Fontanafredda
Joined Apr 2005
IB
I fly my 23oz MUS on the 480/910 with an APC 11x7E for great speed and unlimited vertical. Of course this setup is for "bang the sticks" type flying and not for top speed.
There is a higher kv 480 (around 1050kv I think) that would give you better pitch speed vs the 450 or 480/910. If you are looking for maximum speed you can drop down in prop diameter and go up in pitch, say around a 9x9 or 10x8 to get the balance between speed and thrust you are looking for.
Good luck and good flying
Randy
R/C Dallas is offline Find More Posts by R/C Dallas
Old Nov 07, 2006, 08:22 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
For the 1/2oz weight difference you can put 200W though the 480 and only 140W through the 450. Stick a 9x9 (or whatever high pitched prop pulls ~20A) on the 480 and it MUST get you more speed.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 07, 2006, 02:05 PM
Tampa, FL
Joined Oct 2005
Thanks guys, more watts behind a more pitchy prop, check, so let me throw a curveball....
what about returning one of these (if its possible, some LHS don't like that) a nd getting something like (or equivalent to) Himax 2025-4200 inrunner and slap it in the supplied falcon 400 gearbox. Weight probably goes up a bit however this way I can control with gearing how fast whichever prop is going to spin.? What would be better than the himax? I think it can only handle 175 watts to the 480's 200+ Thoughts?
Old Nov 07, 2006, 03:40 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Nooooooo don't do it. Gearboxes are noisy and need maintaining. Changing prop pitch is the same thing as changing gearing but a whole lot easier At the weights you are talking about you may want the 200-250W power of the 480.
Tim
Old Nov 07, 2006, 04:34 PM
Sir Buildsalot
Stockbridge, GA
Joined Nov 2002
Tim
I TOTALLY AGREE WITH TIM, ditch the GB.
Oh, and good luck returning that motor, most hobby shops will not do that.
Just my $.02
Old Nov 07, 2006, 04:39 PM
Tampa, FL
Joined Oct 2005
Done and done. Thanks guys! 480 it is, will report on flight characteristics
This is why I love RCGroups
Old Nov 08, 2006, 05:49 AM
eran_k is offline
Find More Posts by eran_k
Eventually...I will fly
Israel
what are the hacker, Axi, Hyperion or a chinese motor equivlent to the 480?
Eran
eran_k is offline Find More Posts by eran_k
Old Nov 08, 2006, 06:15 AM
HPSOV is offline
Sydney, Oz.
Joined Mar 2006
Hacker A30-28S
Hyperion 3007-30
I use the Hyperion in my 27oz PA Katana Mini. Using an 11x5.5E prop it pulls about 25A for 270W. Its plenty of 3D power, pulls out of hovers wonderfully.
Wanted E-Flite 450 outrunner needed or similar sized shovelheadfreak Aircraft - Electric - Power Systems (FS/W) 1 Nov 11, 2006 05:30 PM
Wanted E-flight 450 or 480 outrunner shovelheadfreak Aircraft - Electric - Power Systems (FS/W) 1 Oct 06, 2006 02:10 PM
Wanted E-flite 450 or 480. Outrunner Dora Nine Aircraft - Electric - Power Systems (FS/W) 3 Apr 24, 2006 10:00 AM
For Sale E-flite 450 Outrunner LND409 Aircraft - Electric - Power Systems (FS/W) 6 Apr 07, 2006 04:50 PM
Sold E-Flite 450 outrunner $50 shipped dawnron1 Aircraft - Electric - Power Systems (FS/W) 1 Mar 29, 2006 09:17 PM
