Old Nov 04, 2006, 03:49 PM
DaveInLA is offline
Find More Posts by DaveInLA
Joined Sep 2006
Need help charging NiMH with Deans female with charger with Tamiya male connector
I have the EasyStar RTF which came with the CG-207 NiCd/NiMH charger. The charger has a Tamiya male connector head, the NiCd battery in the EasyStar has a Tamiya female. No problem there.
However, I want to get a GWS E-Starter soon and starting using Deans connectors in all my other (future) planes. Since I'm still pretty fresh at all this, I want to stick with NiMH batteries rather than jump to Lipo for now. So the dilemma comes when trying to charge the new battery with a Deans female connector with the current charger with the Tamiya connector. I can't find an adapter with a Tamiya female and Deans Ultra male.
The other option is to change the connectors on the charger to Deans, but then I'd also have to change the connectors on the EasyStar ESC and battery as well, which is a lot of trouble. I also don't want to buy a new charger just for the E-starter. Any suggestions?
DaveInLA is offline Find More Posts by DaveInLA
Old Nov 04, 2006, 04:00 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
http://www.cheapbatterypacks.com/mai...5&pgid=adapter
Forget about standardiziing... just pick the best high current connector and make or buy adapters
rutat is offline Find More Posts by rutat
Old Nov 04, 2006, 04:10 PM
wrenwright is offline
Find More Posts by wrenwright
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Ditch the Tamiya connector. They are notorious for high resistance and even fail to make a good connection once they have been used some.
If you think changing a few connectors is a lot of trouble, you had better get out of electrics.
wrenwright is offline Find More Posts by wrenwright
Old Nov 04, 2006, 04:34 PM
DaveInLA is offline
Joined Sep 2006
I guess I have to either make my own adapter like that website above, or change all my connectors. I'd rather keep that charger stock.
Old Nov 04, 2006, 05:25 PM
tic is online now
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
standardizing on deans ultra now will save a lot of hassle in the future. I agree, ditch the tamiyas.. Deans will take you to 200 amps and above.. Pretty much all you'll ever need
tic is online now Find More Posts by tic
Old Nov 05, 2006, 12:30 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Ditch the Tamyias now or later but you will change them.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Nov 05, 2006, 08:32 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Standardize. It will make life easier over time. I use Deans for over 15 amps, Deans Micro for under (usually used at 10 amps or less).
And if it wasn't for some foamies, I would probalby just use Deans for everything. I just hate to add that extra few grams.
Pinecone is offline Find More Posts by Pinecone
Discussion need help charging NiMh batteries and using super brain charger rwbana Electric Power Cars 4 Apr 25, 2007 02:47 AM
Help! need help charging thunder power pack on commonrc charger gunit29 Batteries and Chargers 2 Jan 14, 2006 10:45 AM
Charging NiMH with Hitec CG-25A Charger? galloping gimp Hitec/Multiplex USA 3 Dec 09, 2004 12:44 PM
Question Charging NIMH with a veteran, current adjustable charger? AKACully Batteries and Chargers 5 Apr 09, 2004 10:02 PM
charging NIMH with NICD charger pc_pilot Parkflyers 4 Sep 11, 2002 11:22 AM
