Old Nov 04, 2006, 12:38 PM
Keith43221 is offline
Find More Posts by Keith43221
Got H2? Fuel Cell R/C Car
Keith43221's Avatar
United States, TX, Del Rio
Joined Mar 2004
Converting a Cirrus SR22 by KMP
Link: http://www.kmp.ca/product_info.php?c...roducts_id=121
Hey guys,
First off, does anyone have any building/flying information this plane? Looks like a really nice plane, but I'm not able to find much online about it. Second, I would like to convert this plane to electric and so far it looks like it shouldn't be that hard.
Wing Span: 87.5"
Length: 68.4"
Flying Weight: 13 lb
Wing area: 913 sq. in
I was looking at the AXI's and 5320's seem to be a good choice. The trick is that this plane is suppose to have a 3 bladed prop. But because I have no idea what is the prop size, I cant say if the motor is the right choice.
Any bits of info would be appreciated.
Thanks, Keith.
Keith43221 is offline Find More Posts by Keith43221
Old Nov 05, 2006, 12:13 PM
kmp647 is offline
Find More Posts by kmp647
marshall , va
Joined Jul 2003
You need to figure out what prop clearance there is.
A 2 blade will give the best performance
I woul only go 3 blade if you have to for scale appearance or because prop clearance is so low.
seems like an 18x10e 2 blade would work. good prop for a 5320/28
you will be experimenting with 3 blades! hope they are not to expensive.
Graupner makes them I think.
kmp647 is offline Find More Posts by kmp647
Old Nov 05, 2006, 12:50 PM
Keith43221's Avatar
Joined Mar 2004
Hey, if a 2 blade will work, that's fine with me.
Thanks for the response, are you the owner/employee of KMP?
Old Nov 05, 2006, 01:06 PM
kmp647 is offline
marshall , va
Joined Jul 2003
No, my initials are coincidence.
But i have flown 12 lb plane electric with 5320/28
and with 5330/f3a both on 10s batteries.
I think 5320/28 will give excellent scale performance and then some
If there is room for 18x10e 5320/28 on 10s 3700s will be 2,100 to 2,500 watts.
good pitch speed too.
Plenty for a 13 lb plane sport performance.
also there is a hyperion outrunner z4045/14 or one of the z50s that will fly it well too.
battery access is always an issue, it would be nice to see the instructions but they are not posted yet.
Its fun but risky to do the first conversion/build on this type of plane.
you have to figure it all out yourself.
These days at least motor mounting is easy
battery access and getting the Center of gravity right is the hardest.
Mattching the motor to the plane isnt that tough anymore
Plenty of motors out there will fly it.
Kevin
Kevin
Old Nov 05, 2006, 01:30 PM
Keith43221's Avatar
Joined Mar 2004
Thanks! 10s1p 3700's? The cost of the batteries needed is probably the only thing some attempting. I'd buy the kit, then look at the battery room situation.
thanks.
Discussion Cirrus SR22-G2 Keith43221 Giant Scale Airplanes 0 Nov 04, 2006 12:16 PM
