Old Nov 03, 2006, 12:11 PM
Miem
Miem
Guest
n/a Posts
Is there such thing as waterproof RC servo motor?
Hi
I will build a robotic application in which I'm planning to use RC
servo motors. The robot will be controlled by two RC transmitters and
it need to work in a wet environment.
I can seal, (make waterproof) the receiver electronics, power units
etc. But I don't know how to make RC servo motors a waterproof.
Any suggession?
Thankx
Miem Chan
ephedralover@hotmail.com
Guest
n/a Posts
Re: Is there such thing as waterproof RC servo motor?
http://www.offshoreelectrics.com/how...of_a_servo.htm
On Nov 3, 9:05 am, "Miem" <MiemC...@gmail.com> wrote:
> Hi
> Any suggession?
> Thankx
> Miem Chan
Old Nov 05, 2006, 08:11 PM
Rick Russell
Rick Russell
Guest
n/a Posts
In article <1162573550.825936.50900@f16g2000cwb.googlegroups. com>,
Splashproof, sure. Just seal all the case edges/holes with silicon
sealer, then put a rubber gasket where the servo arm is attached to
the spline. You might need to grease it up to keep it running freely.
Immersion-proof? Difficult. You're always going to have a weak spot
where the servo axle exits the box. I doubt it could be made entirely
waterproof. You could try encasing the entire servo (except for the
wires and the control rod/arm) in a rubber balloon and seal it up real
good. The boat guys do this with their radio equipment, but the
ultimate goal is to keep the inside of the boat dry.
Rick R.
Discussion Is there such a thing as "too hot a motor?" Ebolavoodoo Power Systems 5 May 29, 2007 10:42 PM
Is there such a thing as "Dreaded WEDGIE Flap?" Helicool Foamies (Kits) 4 Aug 28, 2003 11:55 PM
Is there such a thing as a too large esc? Rackey Beginner Training Area (Aircraft-Electric) 7 Mar 06, 2003 07:48 AM
Is there such a thing as ground effect ? dvint Modeling Science 3 Feb 06, 2003 09:32 AM
Is there such a thing as motor being too powerful/prop being too big? simingx Power Systems 9 Jan 28, 2003 07:36 PM
