Old Nov 02, 2011, 08:25 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Since the Dragonfly Strong spar is constructed the same way... you're not too far off base...
schrederman is offline Find More Posts by schrederman
Old Nov 19, 2012, 12:39 PM
pablo pinto is offline
Find More Posts by pablo pinto
FLY FOR FUN - GLIDE FOR LOVE
pablo pinto's Avatar
United States, FL, Miami
Joined Jan 2011
DragonFly Strong
Hi, i am new in the teme of sailplanes and gliders and i have a Dragonfly Strong and a BLIZZARD 3.4 meters but i wanna convert to electric because now i am living on a flat area and i would like to have an electric gliders can you give me an advise if is posible to convert this beutifull birds to electric, and what motors do you recomend , i have the motor MVVS 5.6/690 http://www.espritmodel.com/mvvs-46-5...ess-motor.aspx and i wanna know if this motor is good or is too strong for this bird or what motor do you recomend.
Thank you.
pablo pinto is offline Find More Posts by pablo pinto
Old Nov 19, 2012, 01:17 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I think that should work fine. That web link gives you good starting point for the size of the other components you will need too...
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Nov 20, 2012, 01:24 AM
Joined Jan 2011
thank you Woodstock 1 .
so do i have to change the CG if i convert to elctric or the original CG is fine?
Old Nov 20, 2012, 04:44 AM
Joined Dec 2005
No!
By the way, I found the factory suggested CoG was way too far forward.
Chris
Old Nov 20, 2012, 12:03 PM
Joined Jan 2011
about the dragonfly
What CG do you recomended if i convert to electric?
Because i try to fund some info or manual but nothing (because i lost the original manual).
Can you help me please.
Old Nov 20, 2012, 12:10 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Basically you are going to take your DragonFly Strong, a winched plane and convert it to a DragonFly Strong-E
http://www.soaringusa.com/DragonFly-Strong-E.html
Likely you could just buy the E fuselage and retain the one you have for Hi-start/winch/slope
CG would remain the same, in terms of starting point on the specs, then you tune to taste. Pablo Pinto prefers his CG more rearward. Your smileage may vary.
aeajr is offline Find More Posts by aeajr
Old Nov 20, 2012, 12:13 PM
ajbhatta is offline
Find More Posts by ajbhatta
Lexington, KY
Joined Jul 2003
Dragonfly Strong
Hi Pablo: The sialplane version that i am flying is around 68 oz. The motor that you are looking at puts out approx 700 watts. If you add battery weight and motor weigh I am guessing that it would be closer 80-85 oz if you eliminate the receiver pack. This works out to ~135-140 watts/lb which should give it vertical performace at peak power. Quite frankly 400 watts with a cheap outrunner would be all you need and give it a healthy climb rate.
Cheers
AJ
ajbhatta is offline Find More Posts by ajbhatta
Old Nov 20, 2012, 01:46 PM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Pablo - I found this post that says after some testing that he ended up with 4 3/8" back for the CG...
http://www.rcgroups.com/forums/showp...99&postcount=1
GliderJim is offline Find More Posts by GliderJim
Old Nov 20, 2012, 06:59 PM
Joined Jan 2011
about the dragonfly
aeajr , ajbhatta Glider Jim , thank you very much for the info i going to work now and i hope to do the fly this weekkend ,i will send you the pictures or video to show you how this bird flys.
Thank you very much for your help :
Old Nov 21, 2012, 08:17 AM
ajbhatta is offline
Lexington, KY
Joined Jul 2003
I flew mine with CG about 102 mm back from LE did OK, considering conversion to electric for ALES type stuff
Old Nov 22, 2012, 11:05 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I wanted more vertical. I started with a geared Mega and ended up with a geared Neu. Wonderful glider.
http://www.espritmodel.com/neu-1115g-series-motors.aspx
Evan D is offline Find More Posts by Evan D
Old Nov 23, 2012, 01:02 PM
WDKK is offline
Find More Posts by WDKK
United States, IN, Fort Wayne
Joined Dec 2006
The first Dragonfly
Hi guys,
This is the original Dragonfly. This plane flies like a dream and can thermal with the best. This Dragonfly also qualifies for all woodie contests too. 2013 is going to be a great year
I hope.
WDKK
P.S.
You might know a few of the guys in the background. I keep pretty good company lol
WDKK is offline Find More Posts by WDKK
Old Apr 02, 2013, 01:34 AM
00-KAZ is offline
Find More Posts by 00-KAZ
Belgium
Joined Oct 2006
Hello all,
I have recently got me a Strong X and building it as we speak.
Just a question on the stabilizer. I would like to make it removable for transport. Is there a way to fix it properly? Or do you all fix the stabilizer in place without making it removable?
00-KAZ is offline Find More Posts by 00-KAZ
Old Apr 02, 2013, 01:08 PM
Joined Nov 2002
I hope.
Due to the molded wing tips, some CDs may disqualify it from woodie competition. Woodies are generally thought to be non-arf types that are built by a modeller... though that isn't stated in the rules as Ray Hayes wrote them. It's just a kind of an understanding... implied, if you will.
Don't get me wrong... I would let you fly it, but some might not. Just be prepared for that.
They are great models...
Discussion C.G. on the Dragonfly Strong mike5656 Sailplane Talk 12 Oct 24, 2007 04:16 PM
Discussion Thermik dream or Dragonfly strong kipecoul Sailplane Talk 27 Apr 05, 2007 03:27 PM
