Flying slower is always nice. I have only done this mix 3 times now and the first was very interesting. From 150' up I dumped all the flaps with one of my switches allowing down aileron instead of up. Very nice feel however in real life controling the speed/penetration or ground speed more importantly in the variable conditions may be more important. What happens when the wind is up? How will this affect the planes ability to penetrate to the target and get there on time. This really is going to require lots of field testing
Latest blog entry: Scale and Aerotowing
Unfortunately, I do not believe it would qualify, as the rudder is molded with the fuselage. I don't think that or the molded wingtips are within the spirit or letter of the "Woodie" rules that I have seen.
Jack Womack |
Latest blog entry: The BEST!
Reduk,
I set mine up on the bench with a ruler. I proped up the aft of the fuselage until the wing was perfectly level... in other words the center of the leading edge radius and the trailing edge were the exactly same distance from the table. I then measured the same thing on the stab. I worked on the linkage and radio until the trailing edge of the stab was 3/32" higher at the trailing edge than the leading edge. That gave me 1.5 degrees of positive decalage. I believe... without doing any math... that 3/32" is about 2.5mm... but I'd check that if I were you. I hope that helps you out. Jack Womack |
Oddly, I had one laying on my bench that I won in a raffle... I did this without ever thinking about having an incidence meter... so I sold it at a swap meet. Old free-flighters never die, we just smell that way...
Let us know how she flys. Jack |
I specked out today flying this model. It was a bit scary. I lost it several times. It's been a while since there was any lift to work, and today started out very slowly. I am getting better at flying this creature and I increased my stab throws today, which helped me some. I also decreased the amount of positive flap for thermalling. I am still convinced that the ailerons adding lift at crow is the way to go for this one. I landed it about 10 times today and all would have been 90+. She floats in from high and low, while I modulate the large flaps and elevator. Plenty of control, even slowed way down. I've been very happy I bought this one... chincy tips and all... Started my winglets tonight... I may build new stabs...
Jack |
Europe - Belgium
Joined Mar 2005
Hi Jack, <-- strange to speak this out as one word
![]() Thanks for keeping us informed. How do you describe its turning in circles, especially the thermalling kind when they occur few and soft? Is it working time or no brainer? Predictable or "spicy"? etc etc. You have many experience to compare with other gliders you have. Jurgen. |
The MH-32 seems to like the speed up at all times, but it slows down nicely when a little camber is added. Thermal turns I found were best with a touch of rudder held into the turn modulated by ailerons to keep the bank angle constant, and a lot of up elevator... so it's work time when thermalling... but worth the effort. The model climbs nicely.
Jack |
Joined Apr 2006
I have about 10 flights on mine now and I agree with Jack. You will work with this one, but I think that makes you a better pilot. I have not had any real lift days yet, I have had one small climb out, but so far it has all be sink city.
The thing I love about this plane is it will float forever and I have made as many as 7 turns under 20 feet when coming into land. It just does not want to quit flying. I added a skeg because it wont stop sliding either. ![]() Great plane though and super tough...except the winglets, they are not so great. Tom |
Hi guys
I see this thread has gone quiet. Anyone have any more news/updates? I have just taken delivery of my D'fly Strong, electric version. I was hoping to use a 600w outrunner I have, but the nose is just too narrow, so I'll have to look at inrunners. I want to use 4 lipo cells ('cos I have 'em in stock......), does anyone have any suggestions re. power systems they have used in this plane, and any balancing issues (the "instruction" page says nothing about the electric version)? Cheers Chris
Latest blog entry: Last great slope session of the summer?
Inverness, Fl
Joined Mar 2004
motor
I would go with a Medusa Motor. Made in the USA and very effecient.
http://www.medusaproducts.com/motors...50-XXXX-GB-428 Go with the 036-050-1600 kv with gear box. According to their motor calc, with a 18x12 prop you will produce more than 105 oz of thrust at 92% eff at 40 amps. I used 50C temp with a 4s 4400mah pack on the motor calc which would give you over 6 min of wide open throttle. High quality motor with great customer service. |
| Thread Tools | |
| Discussion C.G. on the Dragonfly Strong | mike5656 | Sailplane Talk | 12 | Oct 24, 2007 04:16 PM |
| Discussion Thermik dream or Dragonfly strong | kipecoul | Sailplane Talk | 27 | Apr 05, 2007 03:27 PM |
