Old Nov 02, 2006, 09:27 AM
pmarek is offline
Find More Posts by pmarek
Nose down, speed up!
pmarek's Avatar
Glasgow, Scotland
Joined Nov 2006
Idea
Long Range RC
Hello,
Just started working on an MAV project. I don't need to make it very autonomous; basicaly it can be operated all the time by a pilot who's getting video from the plane. My only problem is, can I somehow increase usual range (~500m) of a standard RC system to at least 1km?
Sorry if that question was already brought up here; I did not find anything on that topic .
Prez
pmarek is offline Find More Posts by pmarek
Old Nov 02, 2006, 09:23 PM
Blue Sky is offline
Find More Posts by Blue Sky
It just keeps getting better!
Blue Sky's Avatar
Eureka, CA
Joined Oct 2002
Most standard full range RC systems are good for 2+ km.
-Dave
Blue Sky is offline Find More Posts by Blue Sky
Old Nov 03, 2006, 01:11 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
A good RC system like a JR, is good for 5 KM ......
JettPilot
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Nov 03, 2006, 05:21 AM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
Range can vary a lot from 500m to 5km depending on factors..
A low to ground as in two feet of the deck model planes will be lucky to operate much more than 200 metres average probably 500 metres max assuming flat ground no hills tress building etc blocking signal as the signal risks to de distorted from things in the ground like iron in the clay or wire fences or salty water which can recuce signal strength
High up verticall the signal might be 1km easy for good sets and possibly 5km with correcet usage line up antennas L recieving anntenna etc
I opt to reasearch solutions that will return the plane as quickly as possible to recieving range if it strays outside the tranmision range or auto land it if cloud or fog interupts normal vision flying (I dont mean drinking and flying double vision issues )
Also terrain avoidance which could help me not to hit the hillside while doing DS
There also exists ways to extend range of radio recievers with antenna gain eguipment
lots of solutions debates exist on search usualy for large gliders which theraml at 3 to 5kms ranges
Ralf
treehog is offline Find More Posts by treehog
Old Jan 10, 2008, 09:18 AM
tron is offline
Find More Posts by tron
tron's Avatar
Valencia, Spain
Hi all, you can use new equipments RF of 869-928Mhz. Range up to 50Km.
What about the rc link?: 869Mhz RC&FPV system of DMD. TX=500mW (+27dBm), RX sens=-99dBm, Patch 15dBi.
At 9.38Km i received -82dBm (view on OSD). Easy Glider.
For additional info: http://www.rcgroups.com/forums/showthread.php?t=799087
regards,
tron is offline Find More Posts by tron
Old Jan 10, 2008, 11:15 AM
problah is offline
Find More Posts by problah
N00bie question, what about a 2.4ghz radio? Would it require some type of a booster, and are there any available?
problah is offline Find More Posts by problah
Old Jan 10, 2008, 07:18 PM
sectrix is offline
Find More Posts by sectrix
The cake is a lie
G. Heights, Illinois
Joined Feb 2006
I'm hoping to build the same thing. The control system I thought up was to use 2 radio modems (Digi XTends) and 2 microcontrollers (Parallax). One microcontroller would read and encode input from your controller and transfer it to the sending modem, which would transmit to the plane. The receiving modem (on the plane) would transfer the received data to the microcontroller, which would decode it and drive the servos. It would take a bit of work (you would have to write firmware) but in exchange you get up to 65 Km line-of-sight range, 256 bit encryption, FHSS (Frequency Hopping Spread-Spectrum) capabilities, error correction, 115 Kbps uplink (room for telemetry data, if you like) and a bunch more. Don't know the rules of radio in Scotland, but they only come in 900 MHz.
sectrix is offline Find More Posts by sectrix
Old Jan 10, 2008, 08:44 PM
dmgoedde is offline
Find More Posts by dmgoedde
Joined Aug 2007
Originally Posted by sectrix
...you get up to 65 Km line-of-sight range...115 Kbps uplink (room for telemetry data, if you like).
For XTend, the stated range drops for the higher data rate of 115 kbps. The Max range of 50-60km is for 9600 bps. Also, for the max range, high-gain antennas are needed. No problem on the ground station side, but a Yagi isn't practical on the plane for weight and pointing reasons.
Still, stated range for XTend 900 with rubber ducky antennas is around 20 miles LOS. I'll know soon enough what pans out in the real world, as I have made a breakout board to connect an XTend to the "IMU" port of AttoPilot Beta (see attached pics).
If data is sent ASCII, then you are right, you probably need 115kbps. For the RC portion transmitted from ground to plane, an nmea type format like this for 4 servos at 50 Hz would take about 10kbps alone:
$1289,1251,1846,1439*2D<CR><LF>
That is 25 bytes * 50 Hz * 8 bits/byte = 10,000 bits/s. (This is a quickie estimate)
If you send the data as binary instead of ascii, then same info transfer would consume less bandwidth.
dmgoedde is offline Find More Posts by dmgoedde
Old Jan 12, 2008, 02:27 AM
matttay is offline
Find More Posts by matttay
Joined May 2003
This is a cool application for smartphones: http://www.comvu.com/
Install this app on your UMTS smartphone, stick the smartphone in your airplane, and then you get streaming video at about 150 kbps pumped to a webpage. In real time, you can go to a webpage on your PC or another smartphone and see a 2 second delay of what your phone sees. Not good enough to fly by, but the range cannot be be beat.
Note that a 150 kbps stream is about QVGA at 15-25 frames per second. Not great. However, operators are rolling out video calling that will run at higher bit rates. Expect low-latency VGA at 25 fps to be available from your cellphone in the next 18-24 months.
PDA devices shoudl be considered more for UAVs. With 4GB of storage, 128Mbytes of RAM, integrated displays, a UMTS modem with data rates in excess of 1Mbps, WLAN, bluetooth, GPS receivers, self-contained battery + power supply, 3MP cameras...there's just too much good stuff in a modern PDA to not find a way to be useful in a UAV. All of that in a package that weighs 150g.
matttay is offline Find More Posts by matttay
Old Jan 16, 2008, 02:19 PM
zlite is offline
Find More Posts by zlite
Chris Anderson
San Francisco/Bay Area
Joined Mar 2007
Absolutely. We've open sourced a complete navigation and imaging autopilot for Windows Mobile (now working on an GPS-enabled iPaq). Not the greatest camera in the world, but you can't beat the range ;-)
The thinking was "cellphones already have virtually all the hardware you need of a navigation-only autopilot. Let them do the work of systems integration, and turn the autopilot into a software-only problem". Now looking to port the VB code to newer Windows Mobile versions.
It's here on DIY Drones.
Also note that the Pict'Earth guys have a Noikia N95-based onboard imaging software package, too.
zlite is offline Find More Posts by zlite
Old Aug 09, 2008, 12:11 PM
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
maybe look here too:
http://www.rcgroups.com/forums/showthread.php?t=905915
thomasscherrer is offline Find More Posts by thomasscherrer
Old Aug 09, 2008, 12:42 PM
hoysome is offline
Find More Posts by hoysome
hoysome's Avatar
Alberta, Canada
Joined Jun 2008
you just brought back a thread from 8 months ago to advertise your new transmitter? your thread is more than enough
hoysome is offline Find More Posts by hoysome
Old Aug 25, 2009, 01:49 AM
Scotty Love is offline
Find More Posts by Scotty Love
Joined Aug 2009
Hu???
I would love to find a way to fly my B2-spirit 2 or even 3 miles out. I have a real nice live video feed but now I just need to buy somthing that will extend the range of the bomber. Can some one please tell me what I need to buy to get that kind of range? I have a $500 budget if that helps.
Scotty Love is offline Find More Posts by Scotty Love
Old Aug 25, 2009, 06:11 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
WOW, you want to fly 2 or 3 miles is that even possible?
I will do a search if I can and find an answer for you, wait maybe you can do a search as well?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Aug 25, 2009, 10:04 AM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
More then possible
airmcn_3 is offline Find More Posts by airmcn_3
Long Range Transmitter Question MTS Radios 3 Dec 21, 2008 08:58 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
