Old Jul 09, 2001, 11:13 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
same endurance regardless of throttle setting
This puzzles me.. I fly the skyscooter WOT on 1650 NiMH .. 8 cell packs for 12 min. or so then bring it in. There is more mah left in the pack, but I know the motor and battery are getting way hot so I end the flight early.. Then, I fly at half throttle on a fresh pack, for the same 12min.. battery and motor seem just as hot, and battery pack takes the same mah in a charge.. can't figure it out. Motor is definetly running slower at reduced throttle, should be using less current.
tic is offline Find More Posts by tic
Old Jul 09, 2001, 11:16 PM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
What type of speed controller?
A low rate controller will work like this.
ScottS is offline Find More Posts by ScottS
Old Jul 09, 2001, 11:25 PM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
yeah.. figured it was the ESC.. it's the one that came w/ the plane.. HITEC SP1010.. frame rate controller???... so what happens to the excess current ?
Old Jul 10, 2001, 04:08 AM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
Heat
fisher is offline Find More Posts by fisher
Old Jul 10, 2001, 05:24 AM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
same heat after full throttle run as one at 1/2 throttle.. how can less current heat the same amount? doesn't the speed controller turn the motor on and off repeadedly? If it turns it off alot during half throttle operation.. I would think the battery would last longer.. Is the heat in the ESC?
Old Jul 10, 2001, 06:42 AM
robertc is offline
Find More Posts by robertc
glen innes australia
Joined May 2001
Tic, take their word for it. frame rate throttles will do this,they are inefficient at partial throttle settings. I wont go into the technical details -I'm sure they are posted here somewhere. The real world of electronics is a little more complex than the simple verticle and horizontal lines shown in basic electronics books. If it was that simple then we would not need high rate controllers.
Regards
Bob
robertc is offline Find More Posts by robertc
Old Jul 10, 2001, 08:39 AM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
Yeah.. time to upgrade ESC... mo money
governer mode an throttle setting bertvk Kontronik 5 Mar 13, 2005 03:26 AM
Throttle Setting and Efficiency, BR vs. BL FlyingW Power Systems 3 Jun 11, 2003 07:56 PM
most efficient throttle setting for climbing bracicot Electric Sailplanes 3 Feb 11, 2003 04:34 PM
Throttle setting/hover J328 Electric Heli Talk 3 Jan 15, 2003 08:00 PM
