This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Apr 29, 2010, 10:46 AM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
You need the "power" output of 4s, rather than 3s: from what I've read, the stock motors, on 3s batts, just don't produced adequate thrust.
Now, if you want better motors for 3s use, I can make recommendations.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Apr 29, 2010, 12:03 PM
jonnyjetprop is offline
Find More Posts by jonnyjetprop
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
There are 2 stock motors. The stock ones for 3s powered my ME 262 just fine until one of the motors sheared a shaft. (The older motors have a 2mm shaft)
I can't remember which was which, but one had blue shrink wrap on the motor wires near the endbell and the other had green shrink wrap. Both of the motors had blue endbells.
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Apr 29, 2010, 12:46 PM
Joined Sep 2009
Green does far better with 4s.
Old Apr 29, 2010, 01:53 PM
martimer is offline
Find More Posts by martimer
USA, MO, O'Fallon
Joined Dec 2003
I would prefer to fly on 3S and would love some recommendations for new motors.
martimer is offline Find More Posts by martimer
Old Apr 29, 2010, 01:57 PM
Joined Sep 2009
http://hobbycity.com/hobbyking/store...idProduct=4196
2 years use and going strong: drop in replacement for the green thingies.
Old Apr 29, 2010, 03:15 PM
martimer is offline
USA, MO, O'Fallon
Joined Dec 2003
Thanks angelfood.
I have looked in to the GWS motors and I am confused by the color coding. Does the blue in "BL 2028-4 blue" refer to the end caps or the colored band around the wires? I keep seeing references to green and blue in the specs. The motors that came with my 262 have blue end caps and green bands.
I was rumagging around the 'why did I buy that again' pile and found a couple of GWS brushless EDF 64s with 'white' (non-anodized) end caps and green bands.
I have not quite an idea of how to read the specs on these. What are the kV for these motors and the recommended voltages? I have not been involved much in the hobby for a few years due to illness and while I was gone, GWS released brushless motors and I missed the announcements and experiments. I have my AXI's and E-Flites all figured out, but these 'GWS' motors are a bit of a mystery. When last I frequented this site, Hobby Lobby was the sponsor - I do not know what happened but I hope the parting was not acrimonious.
Last question for the next few minutes is how would I order extra fan adapters?
Marty
Old Apr 29, 2010, 04:48 PM
Joined Sep 2009
Marty, inverse order:
1. Look for gwsprops.com or something like that-a great source for parts-caliberhobby.com or caliber.com is a GWS distributor/retail seller in California, but with much higher prices;
2. The green band means you have a greenie;
3. Go to the GWS site in Taiwan, and get the specs for whatever you want. http://www.gws.com.tw/
Old May 07, 2010, 01:09 AM
skydve76 is offline
Find More Posts by skydve76
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
Just installed two of these:
http://www.hobbycity.com/hobbyking/s...kv_for_55/64mm
in the recommended fans from hobby city. 23 amps each motor when in the nacell. Will get about 450-500 watts total.
Using a 3s 2200 20 C lipo so may not get all the watts, but at least 400. Not bad, I think it will fly because I know it flies (just barely) on 180 watts.
skydve76 is offline Find More Posts by skydve76
Old May 21, 2010, 08:25 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
My experiences:My hand-me-down ME-262 has two of the 2028 brushless motors (green tubing) and black GWS impellers fed by two Castle Creations Thunderbird 36's on a 2200mah 3S 20C lipo pack. I use a Spektrum AR6000 receiver and an add-on Park BEC to prevent receiver brown-out. The model flies at scale-like speeds and will do nice big loops after a shallow dive. it does quick axial rolls, requires some down elevator at full throttle for level flight. I fly mostly at 1/2 to 2/3 throttle, full throttle only for a loop.
Caution, don't fly too long (until low voltage cutoff), one motior will cut out before the other and the other will keep running at full thrust. You might regain control by chopping throttle immediately, dropping the nose to gain flying speed and level out for a dead- stick landing. A one-engine out emergency is not for newbie pilots, best to keep flight times down to about 5 minutes mostly at 1/2 -2/3 throttle depending on the actual condition of your lipo pack. A tired pack/one that gets hot, may have very limited duration before LVC.
E-Challenged is offline Find More Posts by E-Challenged
Old May 23, 2010, 11:38 AM
martimer is offline
USA, MO, O'Fallon
Joined Dec 2003
Thanks again for all the tips. One more question:
How well does this thing hand launch with the stock motors?
I have bad shoulders but no easy access to a paved runway.
Old May 23, 2010, 11:40 AM
GunnyGlow is offline
Find More Posts by GunnyGlow
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
I wouldn't hand launch this thing. Bungee launch yes....
It needs a fair amount of airspeed to get flying well enough so that the nacelles don't cause it to rotate beyond control.
GunnyGlow is offline Find More Posts by GunnyGlow
Old May 23, 2010, 01:19 PM
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
Finally had this running with two of the new turnigy EDF outrunners and fans. Lots of power, but some reason it was somehwat unstable in flight. After a loop, after the over the top part it started snapping. I applied full rudder and saved but I was too low. I punched and pulled too far back on the stick and it snapped again and went in. I am thinking I had too much elevator throw.
PICT0001.AVI (2 min 57 sec)
Old May 23, 2010, 02:43 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
Bummer. Damage report? Photos?
Old May 23, 2010, 03:04 PM
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
About 5 big pieces, the third time its been in that shape. Totally repairable. The nacells are 2 oz glassed so they are still in perfect shape. Motors and fans are still perfect. So I'll have it in the air again after an hour of work.
Old May 23, 2010, 04:17 PM
Joined Oct 2000
The nacelles need some kind of reinforced tape on the bottom for belly landings. You need a buddy that can launch fast and level at full throttle. A little down elevator trim might be wise. Be ready to contol natural pitch up right after launch and prevent stall/crash. You do not want any tail -heaviness and don't want large control throws. Ailerons on mine are very effective. If at all posible, find a large field with smooth tkeoff and landing surface using wheels until you have it under control. Let it lift off gradually when ready. Keep turns wide and bank angles gentle with adequate speed to avoid stall/crash syndrome turning on final and landing., It takes a lot of room to come to a stop on landing. Try to keep nose wheel from hitting ground first, gear leg will bend and linkage may break.
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Discussion ****GWS262: Turbo Rocks the Sky!!**** RAY GWS Product Announcements 6 Aug 22, 2007 08:37 AM
Discussion GWS 262 comming soon! GWS4CEO Parkflyers 32 Jan 14, 2007 02:01 AM
GWS "turbo" daryl GWS (Grand Wing Servo) 10 Feb 12, 2004 11:43 AM
Brushless GWS P-51 ROCKS !!!!!! RMason Parkflyers 15 Jan 03, 2003 05:55 AM
