Espritmodel.com Heli Air
This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jun 16, 2008, 05:44 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Originally Posted by skyhawk
I'm sorry yours have failed Merlin - however I have 6 of them and I know a lot of others that have these green motors and have not had any problems with them. I don't think they really need any improving (except to bring down the price!)
Maybe you just got a couple of lemons - or they may have had a bad batch.
Remember when they 1st came out? A lot of problems. I got mine from Tower Hobbies and i think they were from an early shipment. The replacement still runs I think. I/m just put off by them. If i crash I want it to be my fault not an equipment problem. Maybe I'll try again someday but not with a GWS motor. For now I'll watch jamesdr fly his EDFs and I'll stick with props.
MERLIN
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Jun 17, 2008, 08:44 AM
SCCA, EAA, M.E.
spinnetti's Avatar
USA, KY, Verona
Joined Nov 2001
MERLIN
I'll second that.. mine were full of defects (holes not tapped right, different amp draws, iffy bearings)..... Mine are buried in my 262, but they run hot on 3S and don't work very well.. no doubt will be the death of my 262 at some point..
spinnetti is offline Find More Posts by spinnetti
Old Jun 17, 2008, 10:39 PM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
I just did this to my rotors:
http://www.rcgroups.com/forums/showp...6&postcount=49
82T gear, 9/32" drill bit, and my current draw went down by 5 amps!
rdeis is offline Find More Posts by rdeis
Old Jun 17, 2008, 11:53 PM
Bay Area
Joined Feb 2004
How does that modification reduce current draw?
RCDad is offline Find More Posts by RCDad
Old Jun 18, 2008, 12:16 AM
Montana is Home by the Range
United States, OR, Gold Hill
Joined Aug 2005
mt_flyer is offline Find More Posts by mt_flyer
Old Jun 18, 2008, 01:32 AM
kensp's Avatar
Darwin Australia
Joined May 2002
The latest GWS rotors come with a back plate as shown in this photo, No1, of the latest EDF-75 rotors. I have done a similar thing on the EDF-64 using a 6 mm Depron disk, photos Nos 2, 3 & 4 .
What I think happens is that without the disc the rotor blade area is only supported by the front of the rotor cone and can therefore develop a wobble at the rear. This wobble will have the same effect as an imbalance and lead to a lower RPM and therefore a higher amp draw. The disc stabilizes the rear of the cone and allows a higher RPM. A higher RPM on the same motor/fan/ battery set up means that there is more back EMF and therefore there is a lower current draw.
Ken
kensp is offline Find More Posts by kensp
Old Jun 18, 2008, 10:02 AM
AMA 353531
rdeis's Avatar
Joined Aug 2003
I believe it stiffens the rotor and reduces vibration as Ken said. Cleaner rotation reduces draw.
Reduces wear and tear on the rotor, too, so it's less likely to throw a blade.
Several people have done this in different ways with pretty good results, I found the gear the easiest, took me 5-10 minutes to do both rotors.
The same size gear works for EDF-55 rotors.
Old Jun 18, 2008, 10:18 AM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
rdeis,
Man, 5 amps is a lot for two motors. Are you still using the VL hand wound motors? I'll have to try this to see if I get about the same with the 55's. I do think the 55's are a bit stiffer though and ballance better then the 64's.
What glue did you use? I'll prop try the rubberized CA and light ply disk.
Thanks for posting the link--Stacker
stacker is offline Find More Posts by stacker
Old Jun 18, 2008, 11:31 AM
AMA 353531
rdeis's Avatar
Joined Aug 2003
It sure is! I'm racking my brain to figure out if anything else could acount for the difference. I might have removed a little debris from the exhaust duct in between tests, but I don't think so. I ran it up fo 5-10 seconds on my wattmeter, pulled the rotors and installed the disks, reinstalled them, and ran it up again for 5-10 seconds. I didn't recharge in between, so that might account for a small decrease, but not 5 amps!
Yes, same motors, still seem to be running very well. I've got two more of them that I plan to install in my GWS 15 when I get around to building it. I think I'll be looking for a good 4s wind for them, though.
I agree that the 55s are stiffer than the 64s, will be interested to see your results.
Rubberized thin CA. The fit is so neat that you almost don't need it.
Old Jun 18, 2008, 01:08 PM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
rdeis,
Thanks for the info. I'll try to mod several rotors on one of my 262's. Be nice if I could shed a few amps.
As I remember, I think you were running the same setup as me, 5 turn nsnsnsns? Mine was all 55's though. I bet you could use the same wind for you F15 but with four cell bat. prob. be around 22-25 amps.
Cheers--Stacker
Old Jun 19, 2008, 02:48 PM
Solidworks
speedracer24's Avatar
Stanfield,NC
Joined Apr 2007
What other adhesive could be used for someone doing this mod? Thick CA maybe? I am going to use 6mm depron.
speedracer24 is offline Find More Posts by speedracer24
Old Jun 19, 2008, 03:01 PM
AMA 353531
rdeis's Avatar
Joined Aug 2003
I'd stick with thin glue because:
A> you want a tight fit and
B> thin glue is less likely to glob up and ruin the balance. (you should probably re-balance the rotor afterwords anyway.)
If the disk fits as well as it should, then thin foam-safe CA would do the trick.
Old Jun 19, 2008, 05:48 PM
kensp's Avatar
Darwin Australia
Joined May 2002
You will need to use foam safe glue if you use Depron.
I cut my 6mm Depron discs very slightly oversize and forced them in so they were under compression. This way they are in so tight that to get one out you have to cut it into pieces. Make a simple tool to ensure that you push the disc in straight
Ken
Old Jun 19, 2008, 07:12 PM
Solidworks
Stanfield,NC
Joined Apr 2007
I made the discs and installed them. They sound alot smoother and quieter than before. Thanks for the info guys.
Old Jun 19, 2008, 10:18 PM
Bay Area
Joined Feb 2004
Very nice mod. Improves performance (higher RPM), more efficient (lower AMP draw), and may even help to prevent that dredded in flight impeller destruction (more structural support).
I'm going to do it to mine!
     DRIVE / FLY /
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Discussion ****GWS262: Turbo Rocks the Sky!!**** RAY GWS Product Announcements 6 Aug 22, 2007 08:37 AM
Discussion GWS 262 comming soon! GWS4CEO Parkflyers 32 Jan 14, 2007 02:01 AM
GWS "turbo" daryl GWS (Grand Wing Servo) 10 Feb 12, 2004 11:43 AM
Brushless GWS P-51 ROCKS !!!!!! RMason Parkflyers 15 Jan 03, 2003 05:55 AM
