Found this from a recent post elsewhere, scroll down and you'll see a sparcap press illustration. It looks like they are using steel plate then silicone then another clamping plate.
It says they can get 30 bar of pressure which is about 363 PSI. A good vac pump will generate 25inches of mercury which is about 12 PSI. Wow, I'm glad you asked this, it helps answer a question I had in another thread http://www.airplane-model.com/tech-built-up-d-box.html |
Tony - Wondering in what way have your spars not been acceptable? I have already seen reference to the discontinuities due to the steel clamping plate.
If you use a vacum technique (admittedly much less pressure than clamping) the discontinuites would not be possible as the bag would account for the steps in layers. What are your goals :- maximum removal of epoxy? I favour the simple vacum approach:- there are a lot of molded gliders out there winning major contests that have had the spar layers simply vacumed wet into a mold. Usually the spar is designed for stiffness and is way over strong - would any minor loss due to just the vacum technique compromise the job? I have seen spars fail due to insufficient epoxy. cheers jeff Keeping it simple. |
Joined Nov 2002
Thanks Jay, that's what I was looking for.
jeff, I've had success bagging the spar caps flat on a piece of mylar but I'm looking for a perfectly pre-dimentioned carbon cap that requires no trimming after it is laid up and the mould with silicone and metal insert will (I think) achieve that. I'm going to go with Sleds suggestion using the silicone with steel insert in the mould and vacuum bag it. I'll post a photo of the finished cap. T.D. |
| Thread Tools | |
| Discussion What type of Foam is used in Hobby Lobby kits? | Y2kGTP | Foamies (Scratchbuilt) | 8 | May 04, 2007 11:34 AM |
| Question What type of plug is used for charger connection? | ejaf | Micro RTF | 5 | Feb 12, 2007 11:01 PM |
| What type of plane to use for AP | MICROMAN | Aerial Photography | 3 | Nov 29, 2004 11:15 AM |
| What type of Fire Extinguisher for Lithium Fires? | CustomPC | Batteries and Chargers | 12 | Jun 22, 2004 06:01 PM |
| Question What type foam to use for 3DX?? | Trogdor | Foamies (Kits) | 6 | Feb 04, 2004 03:22 PM |
