Old May 14, 2007, 01:37 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Don't get me wrong, I believe in the AMA and am a member of a club. There are too many activities I would not be able to participate in if I were not a member. The AMA is turning around big time and has fully recognized electrics as far as I can tell. There are the hard core individuals that make life just a little more stressful but I have that everywhere I go. My brother called me from the Magical Kingdom (Disney) the happiest place on earth this weekend. Said he was about to throttle some folks down there for their lack of courtesy on the road.
bildo baggins is offline Find More Posts by bildo baggins
Old May 19, 2007, 10:11 PM
RickC2009 is offline
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
Where do you like the C/G on this plane?
I have mine set at recommend 3.75 inches but would like to know where others have there C/G set to.
Rickc
RickC2009 is offline Find More Posts by RickC2009
Old May 19, 2007, 11:22 PM
crash test dummy is offline
Find More Posts by crash test dummy
Foamsmithing forever!!
crash test dummy's Avatar
Sugar Grove, Il.
Joined Aug 2004
I did something really stupid the other day. I tripped in my hanger and fell on my MFX!!! CRAP!! I see the wing sets are 67 bucks on horizon web site. However, do any of you know if I can buy just 1 wing? If I'm going to spend 67 bucks on just wings, I may as well just buy another whole plane and have spare parts.
CTD
crash test dummy is offline Find More Posts by crash test dummy
Old May 20, 2007, 06:13 PM
reyn3545 is offline
Find More Posts by reyn3545
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
I had 4 or 5 more flights today, no real problems, except that the 16x10 won't let me slow the plane down to land... I have to set the throttle adjustment down about 5 clicks, to the point where I'm afraid its gonna die, but so far it hasn't. Plenty of power to do absolutely anything, and a real blast to harrier around the field.
reyn3545 is offline Find More Posts by reyn3545
Old May 20, 2007, 07:00 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Well, I finally got to fly mine. I can say, everything positive I've seen and heard about this baby is 100% spot on. I think I'm gonna love it.
Chuck
Chuck is offline Find More Posts by Chuck
Old May 20, 2007, 08:28 PM
dnorm is offline
Find More Posts by dnorm
1.21 Gigawatts!
United States, NY, New York
Joined Sep 2006
reyn, are you really running a 16x10 on this plane??? wow, i run a 12x7 doesn't the 16x10 hit the ground? what motor, what is your current draw? more power to if you are, i just didn't know it was possible :-).
dave
dnorm is offline Find More Posts by dnorm
Old May 20, 2007, 09:47 PM
Sugar Grove, Il.
Joined Aug 2004
reyn 3545
16 X 10!!! Really!
CTD
Old May 20, 2007, 10:57 PM
starcad is online now
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
dave
I was wondering the same thing. I'm running a 12X6E, tried a 12X7 but everything was running hot so I went back to the 12X6E and love the way it flies. Three more today bumping my total up to 75 now. Went to try my new 2200 but forgot to put Velcro on it and so I save it for next weekend. Bad luck whit the camera today as my wife used it last week and forgot to turn it off. dead batteries so will try again next weekend. This plane really ROCKS!
starcad is online now Find More Posts by starcad
Old May 21, 2007, 12:41 PM
netdudeuk is offline
Find More Posts by netdudeuk
England
Joined Nov 2005
Which are the APC props of choice for the Park 480 1020Kv (with a 2200 3S 12C/16C pack and 33A constant (40A burst) ESC) for sports flying and for 3D ?
Would one of the AXIs from here be a better option, considering the other power system components ? Price would need to be comparable with the Park 480 1020Kv. Prop advice would be welcome if there are obvious AXI options.
I maidened the plane this evening with a Towerpro 2908-10 motor (which lasted all of one minute). It cut out in the air and there was smoke coming out of the cowl once I'd landed.
It was a close thing getting it down as I'd not even got it trimmed out, it seemed quite tail heavy with a 95mm CG and it didn't want glide at all. It was also a lot more twitchy than I'd expected. Is the CG right ? Anyone care to comment about this ?
What are you using for aileron and elevator expo for low and high rates ?
Did anyone notice the mistake in the manual where it converts the rudder throws in mm ? Neither of those imperial values match the metric ones. I trust that the imperial sizes are correct ?
netdudeuk is offline Find More Posts by netdudeuk
Old May 21, 2007, 03:01 PM
reyn3545 is offline
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
Woahhh.. Oops! I should have posted that message on the Funtana X100 thread on rcuniverse. If I could put a YS 140 and a 16x10 on this plane... I don't think it would last too long! But it is a great flying plane.
Old May 23, 2007, 02:06 PM
mitang is offline
Find More Posts by mitang
Joined Sep 2006
Hello everybody!
Did anybody had power failure problems with new E-Flite ESC 40-Amp with Dual BEC? This is version 2 of the ESC, but manual says that if using economy class sub-micro servos, the suggestion is to power only 3 servos What are economy class servos? I'm using Hitec HS-55 for ailerons and HS-65HB for the tail.
Do I still need redundant Park BEC to power the receiver and servos?
tnx for any info
mitang is offline Find More Posts by mitang
Old May 23, 2007, 02:24 PM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
mitang,
I have been running the same set up (2 HS-55's and 2 HS-65's with the Eflite 40a esc) in a Seagull Extra for 150+ flights with no problems to date. Make sure to place it where it will get lots of cooling air as this will be critical as temps rise this summer.
dawg
r/cdawg is offline Find More Posts by r/cdawg
Old May 23, 2007, 03:02 PM
mitang is offline
Joined Sep 2006
Originally Posted by r/cdawg
mitang,
dawg
Hi dawg,
What battery do you use? LiPo 3s?
mitang
Old May 23, 2007, 03:56 PM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Originally Posted by mitang
Hi dawg,
mitang
3S Thunder Power 2100 Prolites.
Old May 24, 2007, 10:42 AM
malcolmm is offline
Find More Posts by malcolmm
Canada, BC, Vancouver
Joined Jan 2005
Hello everybody!
tnx for any info
I run this ESC with 4 hs-65's, with a TP 2100 prolite. No problems so far. I mounted my ESC were there is lots of cooling.
Malcolm
malcolmm is offline Find More Posts by malcolmm
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
