I would say you would take a big weight hit in the tail. The 81's weigh twice as much as the 65's I believe.
Latest blog entry: Bildo at Nall 2013
Wow! You had problems with the PH-35 and 4 HS-65's? Hmmm, makes me reconsider a ext BEC. I bought the 35 so I wouldn't have to.
http://www.dimensionengineering.com/ParkBEC.htm
Got one in my 6 servo Mini Ultra Stick. Weighs almost nothing, reasonable price. Works great. |
Canada
Joined Dec 2005
Hello Everyone, i crashed my Brio 10, last friday, and right away I bought the MFX, used all the electronics from the BRIO into it,
4 hitec HS55 servos elfite 40 amp ESC eflite power 10 motor thunder power 2100 lipo berg reciever It flew great, almost too well, I'm happy with the setup, From having a few of the old mini funtana I beefed up the area around the motor mount, as well as the landing gear, Johnny Toronto Ontario Canada |
How do you compare the Brio to the MFX for performance and fun factor?
United States, NY, New York
Joined Sep 2006
i have both planes bildo, the brio IMO is more difficult to fly and is a bit harder to tell orientation which is a problem i typically rarely have...the biro will test your skills and is a blast to fly - it's a bit faster and the pull pull rudder really makes a difference. landing the mfx is also ALOT easier the brio you have to fly it in while the mfx you can float in due to the larger wing area....i have had problems with the landing gear being the weak spot, but i have just bent it back in place every time...
this is as honest opinion as i can give you...it's a blast to fly but will test your piloting skills... i just got back form lunch a bit ago and was flying the mfx - the weather here in northern va is just perfect for flying...and this plane is just a dream to fly everytiem i bring it out. dave |
I'm liking my MFX more as I get more time on it. I had a bit a slight warp in one wing and after taking it out it really flies well. Just put HS-65s on the rudder and elevator so it reacts a lot quicker/better.
Canada
Joined Dec 2005
I agreee, I have more fun with the MFX than the Brio, - more flight times, easier to land, and makes me feel more confident doing low inverted fly-bys..
yesterday I flew the MFX at a farmers field where the ground was really rough and bumpy i landed numerous times with no damage to the landing gears surprisingly, Also I experimented with a 10x7 prop, whoa!! talk about speed |
I fly a 12x6E but have tried the 13x4E on another plane with the 480/910 motor. It does really well in 3D and speed seemed to be at least as good as 12x6. The airframe is a little more draggy tho.
Sorry, I haven't hit the forum in a few days.... I don't know if I really needed the BEC, but I had replaced the ESC and the glitching didn't go away. After that, I just gutted everything else, re-checked the Deans connectors, added the BEC, etc.. and the problem went away.
My plane wasn't impossible to handle with the glitching, but it certainly was challenging. As well as it floats, I just got it near the runway, cut the engine and glided in (glitching). So, if you're working fine with the Phoenix ESC now, I wouldn't worry too much about the problem.. just address it if it comes. |
| Thread Tools | |
| New MINI E3D from Gary Wright - Build and Fly | Harley | Sport Planes | 792 | Oct 05, 2009 07:12 PM |
| Poll New Warbird offering from E-Flite | Tommy D | Electric Warbirds | 35 | Jun 05, 2006 10:46 AM |
| New Cessna 182 370 ARF from E-flite | hlondono111 | Electric Plane Talk | 0 | Oct 03, 2005 03:47 PM |
| Yippee! New Ultimate from E Flite!!! | marshallcowboy | Electric Plane Talk | 0 | Jul 18, 2005 10:14 PM |
