Old Apr 27, 2007, 01:04 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
It is either ther Xtal or the rec!
Have had xtal go bad in a crash!
Elvan!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Apr 27, 2007, 08:15 AM
av8r is offline
Find More Posts by av8r
...the wind usually blows
av8r's Avatar
Carbon Creek
Joined Jan 2004
Originally Posted by mecevans
doctoraudio i have bent the ends of the linkages and glued the screws so i doubt it was that, also all channels were twitching.
av8r i dont have a second pack so how can i fix it?
i bet its just the xtal, they wear out dont they? this reciver has been used on 2 planes
It's probably unlikely to be the pack, just something to consider. I guess it's not so easy to diagnose if you don't have another pack. Maybe you could borrow one from somebody just to try?
Glitching could be caused by a lot of things including the Rx, crystal, ESC, antenna and other wire routing, a bad servo overloading the system, a bad tx, interference, etc.
Try to eliminate the easiest things first, like a different flying site, different pack, etc.
av8r is offline Find More Posts by av8r
Old Apr 27, 2007, 04:29 PM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
i think i have it solved! i put a rx batt to the rx and turned on my tx, nothing. if i would have been flying a little longer it would have crashed reaally bad. i swamped out the rx and it works fine
mecevans is offline Find More Posts by mecevans
Old Apr 27, 2007, 05:10 PM
ededge2002 is offline
Find More Posts by ededge2002
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
you cant have the antenna overlap like this!
http://www.rcgroups.com/forums/attac...mentid=1280945
if wound around somthing it MUST not overlap nice even wraps wroks much better this mess just wont do here. dont blame a rx for a poor jop
ededge2002
ededge2002 is offline Find More Posts by ededge2002
Old Apr 27, 2007, 05:24 PM
rightflyer is offline
Find More Posts by rightflyer
Columbus, oh
Joined Apr 2003
Ededge2002 Good catch. I missed the overlapping of the antenna. That would definitely cause a reduction in range.
rightflyer is offline Find More Posts by rightflyer
Old Apr 27, 2007, 09:51 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
so by overlaping it fried the rx?
Old Apr 28, 2007, 07:23 AM
ededge2002's Avatar
Joined Dec 2002
it wont damage the rx at all to overlap it like that but it will cut out some of the range and or ability to rseist glitches. the antenna should be wound like this if at all
hope things work out for you! re-do the antenna and give it a shot with a real good range test
ededge2002
Old Apr 28, 2007, 07:59 AM
starcad is offline
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
Originally Posted by bildo baggins
Ok starcad, what battery is this? Sounds like you found a winner.
It really wasn't the new battery but the way I charged it. I've been charging with the balancer hooked up during charge. My son told me to do it that way. In a conversation the other night I told him I was only getting around 1000 back in after I flew. He then told me to charge it normally like I have been doing but then after it ends to recharge a .3 amps. That did it and put the extra back into the battery. With my conservative flights I managed 3 to 5 minutes more flight time per pack.
starcad is offline Find More Posts by starcad
Old Apr 28, 2007, 08:10 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Balancing is always good. You will recover some lost capacity and keep from burning something up. Balancing my TP 2100 bats now. Thw weather is looking good today.
bildo baggins is offline Find More Posts by bildo baggins
Old Apr 28, 2007, 08:17 AM
starcad is offline
AMA 667982 KG7NKY
starcad's Avatar
Joined Sep 2000
No, you didn't fry the receiver, what you did was probably reduce your range to less than half. Any time you fold the antenna over itself you are reducing the range of the receiver. If your trying to hide the ant. then run it down the inside of the fuselage and let it exit out the rear of the model. You can secure it with a piece of scotch tape at the rear. Oh, don't forget a strain relief as this will help to prevent the ant. from being jerked out of the receiver if you happen to have a misfortune.
Old Apr 28, 2007, 08:21 AM
starcad is offline
AMA 667982 KG7NKY
starcad's Avatar
Joined Sep 2000
Wish I could go out today but Comcast has other plans for me. Tuesday and Wednesday will be my weekend this week. You guys have a blast for me and I will be thinking of you as I sit in my cube looking out the window. Fly high and soft landings.
Old Apr 28, 2007, 01:46 PM
IH8VTEC is offline
Find More Posts by IH8VTEC
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
I charge with my tp 205 connected to my 2100's and it tells me the pack is full before the charger does. I take the balancer off and a couple minutes later the charger says full. That how you do it?
IH8VTEC is offline Find More Posts by IH8VTEC
Old Apr 28, 2007, 03:26 PM
david_r2ese is offline
Find More Posts by david_r2ese
david_r2ese's Avatar
United States, IL, Galena
Joined Apr 2002
I bet you guys didn't know the MFX has an option for retracts.
david_r2ese is offline Find More Posts by david_r2ese
Old Apr 28, 2007, 07:02 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Just found out mine has retractable tail wheel and quick release rudder. Tail wheel got pushed back out of the fuse and ejected my rudder on takeoff from wet grass.
Old Apr 28, 2007, 07:15 PM
Joined Apr 2002
It really is amazing what new features we find on our planes over time.
My MFX is all ready to go again, except that no LHS's have any 12x6E props. Dang it. No good ordering any as I'm leaving for home in a week.
Dave
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
