Old Apr 23, 2007, 07:58 AM
Model Designer - AMA 667982
starcad's Avatar
Tucson, AZ, USA
Joined Sep 2000
Well I put on four more flights yesterday morning and had a blast. Had a new battery a 2200 I picked up off ebay. What a difference compared to my name brand 2100 packs. I got 5 more minutes of flight time and the pack was only touch warm. I was able to get out and fly with a bunch of my old friends up at Maxwell Middle School here in Tucson. Great bunch of guys all with the same interests. Fly models and the sky was crowded all morning with as many as 7 planes in the air at a time. Ttyl. gotta go to work.
starcad is offline Find More Posts by starcad
Old Apr 23, 2007, 08:05 AM
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Ok starcad, what battery is this? Sounds like you found a winner.
bildo baggins is online now Find More Posts by bildo baggins
Latest blog entry: Bildo at Nall 2013
Old Apr 23, 2007, 02:49 PM
The sky is my playground.
Dora Nine's Avatar
New Hampshire
Joined May 2005
I'm curious as well. Damn seven planes. The most I dare is two others. For me, things start getting crowded after that.
Dora Nine is offline Find More Posts by Dora Nine
Latest blog entry: A good watch...
Old Apr 23, 2007, 03:13 PM
david_r2ese's Avatar
United States, IL, Elgin
Joined Apr 2002
How about 10 planes in a 9'x10' dorm room plus 3 in the works
Of course one of the largest is the MFX, which is only slightly beaten out as largest by my OV-10
The good news after having a glitch in an aileron servo, it seems to have been fixed by putting in a different servo. Only another flight will tell for sure.
Dave
david_r2ese is offline Find More Posts by david_r2ese
Old Apr 23, 2007, 03:15 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Never did combat have you Dora?
Old Apr 25, 2007, 11:26 PM
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
waaa! had a bad crash today i was flying around today and all of a sudden i get a small glitch, i didnt think anything of it so i kept on flying. i get a couple more, then more and decide to land and check it out, when im landing the elevator goes full down deflection and im diving quick. at the last second it responds and it pancakes the ground. heres what it could be
theres a guy with a bazillon antennas on his roof next door and he does amatur radios
bad crystal and reciver
motor loose and causes vibration
speed controller
some how my battery ballence wire broke too? theres allot of cracks everywere but ill try to repair it, i doubt it will last much longer and i may need to retire this one. the cowl is in pretty bad shape too
mecevans is offline Find More Posts by mecevans
Old Apr 26, 2007, 12:10 AM
Paul Teesalu
ss2p's Avatar
Goleta, CA
Joined Aug 2006
Bummer man! I've also noticed glitches on my hitec 05s receiver.. maybe thats where the problem starts? I just flew her in about 10mph winds, it did great!
Paul
ss2p is offline Find More Posts by ss2p
Old Apr 26, 2007, 12:26 AM
hemituda's Avatar
Joined Aug 2006
Save a few bucks and go 2.4 when you can, You won't be dissappointed
hemituda is offline Find More Posts by hemituda
Old Apr 26, 2007, 06:27 AM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Might wanna get yourself a Electron 6 or other dual conversion. 2.4 is a good option too but I'm waiting till I get plenty of service outa my current equipment. Got about 8 or ten good receivers now.
Damage looks fixable for sure.
Old Apr 26, 2007, 08:57 AM
mecevans's Avatar
Joined Feb 2006
just bought my optic 2 months ago so im not going to upgrade till the modules come out. it might be the reciver but im going to buy a new xtal, just kind of stange because all of my other 200 plus flights ive never seen glitches. hey SS2P ever fly in 25 mph + winds? the thing just sits there at 3/4 throttle
Old Apr 26, 2007, 09:05 AM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Don't forget that if you don't put a tie-wrap around the Elevator and rudder extension they came come apart a little in the air and cause so scool crashes!
Elvan!
DoctorAudio is offline Find More Posts by DoctorAudio
Latest blog entry: Composite 200 mm micro quad!
Old Apr 26, 2007, 08:55 PM
Joined Apr 2002
I must say, this is probably my favorite plane to fly now. I've had it in the air more in a week than any other plane I own. It is pretty tough too! I've had a few pancakes on landing from not keeping my speed up or too much flare, and have no issues with the landing gear. Today while flying in wind I shouldn't have been, I got a little disoriented on an inverted harrier and got all kinds of screwy. After clipping the top of a tree I kept it flying, but I was behind about 1/2 a second on my inputs and ended up pancaking inverted from 3 feet. All I suffered was a broken prop! Man this plane is nice!
Dave
Old Apr 26, 2007, 09:23 PM
Joined Dec 2006
Dave
You're lucky! I just ripped the entire UC out from my MFX after a pancake. It's all fixed with epoxy, I just need to get some covering material to replace the material that got ripped. Otherwise this is my favorite plane! It went together very smoothly and it flys great. The only problem is that if I fly it too high, I start getting confused as to the orientation in hovers (although that is probably just a problem with my eyes ).
rx20040 is offline Find More Posts by rx20040
Old Apr 26, 2007, 09:32 PM
...the wind usually blows
av8r's Avatar
Carbon Creek
Joined Jan 2004
The white wire on the TP 3S 2100 PL is always the one that breaks. I strap the balancer plug wires down with strapping tape to provide some strain relief. Haven't had one break since.
Also, don't rule out the battery pack as the cause of the glitching. I had a terrible intermittent glitching problem once and it turned out to be a broken solder connection between two of the cells on a TP 3S 2100 PL. It's easy to diagnose, just try a different pack.
av8r is offline Find More Posts by av8r
Old Apr 27, 2007, 12:06 AM
mecevans's Avatar
Joined Feb 2006
doctoraudio i have bent the ends of the linkages and glued the screws so i doubt it was that, also all channels were twitching.
av8r i dont have a second pack so how can i fix it?
i bet its just the xtal, they wear out dont they? this reciver has been used on 2 planes
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 792 Oct 05, 2009 07:12 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
