Old Apr 14, 2007, 01:11 PM
elektryki2222 is offline
Find More Posts by elektryki2222
Poland, Olkusz nearly Krakow
Joined Dec 2004
Thanks Guys ! I'm test fly on 65 EXP on aileron elev 50.
My setup :
-MFX
-4 hitec hs55 ( no good on aile - i'm waiting for HS65 )
-Receiver Corona dual conversion from united ( test before fly is good )
-Jeti Spin 33 ESC.
-axi 2814/20 ( Very good motor ! )
-RTF weight on SFG 900gram = 0,9kg
-11x4,7 propeller APC E.
Best Regards Krzysiek.
elektryki2222 is offline Find More Posts by elektryki2222
Old Apr 14, 2007, 02:33 PM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
stop!! i wouldnt fly it with hs 55 on rudder and elevator ,you need the hs 65 on the rudder and elev more than the aileron. you could strip them out and cause it to crash ,im using hs 55 on aileron and its fine. if your are going to use hs 55 take it easy
mecevans is offline Find More Posts by mecevans
Old Apr 14, 2007, 04:09 PM
david_r2ese is offline
Find More Posts by david_r2ese
david_r2ese's Avatar
United States, IL, Galena
Joined Apr 2002
Here is my example of the MFX.
Park 480 1020
E-Flite 40A ESC
Park BEC
2 S-75's for AILs
2 HS65's for RUD & ELE
3S 2100 Lipo for power.
Ordering corona dual conversion rec. since the GWS had range problems.
Modifications:
Since I do not have a paved strip anywhere close by, I swapped the original wheels and pants for some 3" foam wheels and homemade SU-31 type fairings. It rolls pretty well through the grass. I also added aprox. 1.5" of foam to the back of the rudder to improve knife edge as suggested by several here.
Dave
david_r2ese is offline Find More Posts by david_r2ese
Old Apr 14, 2007, 04:58 PM
hemituda is offline
Find More Posts by hemituda
hemituda's Avatar
Joined Aug 2006
Now thats what I call tundra tires.
hemituda is offline Find More Posts by hemituda
Old Apr 14, 2007, 05:08 PM
papasmurf is offline
Find More Posts by papasmurf
"I passed on the kool-aid"
Waco, TX
Joined Jan 2004
HS-55's can suffice on the tail. That is what I have on mine and I have flown it pretty hard. Of course the 65's work as well if you want to pay the difference and get the extra torque. I have 55's in my katana mini too all around and just about every other plane I have this size and they have held up really well. IMO the only time I have to worry about stripping gears on them is when they are in storage and get bumped.
papasmurf is offline Find More Posts by papasmurf
Old Apr 14, 2007, 05:58 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
I believe the 55s will work but the 65 will give you great speed. The difference is very obvious.
I flew mine today after taking out some warp in the wing. Seems to fly straight now with neutral trim but the speed was increased considerably too with less drag from the trim not being required. Might have to go with some flaps now or move the battery back farther.
bildo baggins is offline Find More Posts by bildo baggins
Old Apr 14, 2007, 06:32 PM
reyn3545 is offline
Find More Posts by reyn3545
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
You guys that have added foam to the tail.... do you add it to both sides or just 1? Peel the covering off first, or just glue over it? what type of foam? etc.. etc.. etc...
reyn3545 is offline Find More Posts by reyn3545
Old Apr 14, 2007, 08:19 PM
Joined Apr 2002
Curious...
I have a spare Futaba gyro laying about. Would this be useful at all on this plane, and if so, on what control?
Dave
Old Apr 14, 2007, 08:43 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Gyros have been tried on 3D foamies and I believe the conclusion was not really effective.
Old Apr 15, 2007, 02:01 AM
Joined Dec 2004
OK Guys. I'm buy HS65 und get in elev und rud. und HS55 on elev und rud go to aile. I'm going today at test... hehe... OK i'm fly not hard . Best Regards und thanks for help Krzysiek.
Old Apr 15, 2007, 09:23 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
No kidding huh? Geez I'm glad I don't have to fly where he does.
Dora Nine is offline Find More Posts by Dora Nine
Old Apr 15, 2007, 11:04 AM
Joined Apr 2002
It wouldn't be so bad if they let me cut down a few small trees. I have a small strip of rough but mowed grass surrounded by trees. Everything else is a field that only gets cut back 2 times a year. Of course I could try to fly between the trees and shrubs and land on the gravel drive nearby. Oh what I could do if I had a Bobcat... I can't even fit the plane into my car to take it anywhere else.
Dave
Old Apr 15, 2007, 11:23 AM
hemituda is offline
hemituda's Avatar
Joined Aug 2006
At least you can fly somewhere. I have to dodge baseball players on a field ( or really wait until there are no games) to fly. The only other option is to drive 1.5 hrs to go 26 miles in L.A. traffic to fly with at least 100 other people at the local flying site. There is nothing wrong with having to be a bush pilot.
Old Apr 15, 2007, 12:17 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
Originally Posted by david_r2ese
Curious...
Dave
i would put it on the rudder, thats what i heard they put it on 50% 3d planes
Old Apr 15, 2007, 02:23 PM
Joined Dec 2004
Today i''m fly on 65 EXP on aile, 40 elev , 20rud. I'm fly on 95mm CG. What CG you recomend on 3d flight ?? Best Regards Krzysiek.
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
