Old Mar 19, 2007, 01:29 PM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
wow 3 flights in today! i moved the battery back a little and i can hover about 6 feet off the ground.
mecevans is offline Find More Posts by mecevans
Old Mar 19, 2007, 03:22 PM
reyn3545 is offline
Find More Posts by reyn3545
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
I can't imagine the spring causing any interference, but I guess stranger things have happened.. I'll try the SPCM route first..... that should filter out about everything.
reyn3545 is offline Find More Posts by reyn3545
Old Mar 19, 2007, 04:51 PM
av8r is offline
Find More Posts by av8r
...the wind usually blows
av8r's Avatar
Carbon Creek
Joined Jan 2004
Just curious, what ESC are you using?
av8r is offline Find More Posts by av8r
Old Mar 19, 2007, 05:19 PM
reyn3545 is offline
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
I think this plane has a Castle 35... I'm traveling this week, so can't check to be sure.
Old Mar 19, 2007, 05:42 PM
av8r is offline
av8r's Avatar
Carbon Creek
Joined Jan 2004
I had a CC P35 suddenly start to cause glitching on my Katana Mini. I replaced/eliminated everything else. They replaced it with another one and it did exactly the same thing, so I replaced it with an E-Flite 40A and the glitching was gone. I still use CC's on other planes, but I've put filters on a couple of them just to be safe. They're very good in every other respect and I like being able to program them through the USB.
Old Mar 19, 2007, 07:00 PM
reyn3545 is offline
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
was it glitching just on the motor or the control surfaces too? Mine was glitching on every channel.
Old Mar 19, 2007, 08:15 PM
av8r is offline
av8r's Avatar
Carbon Creek
Joined Jan 2004
It was on all channels.
Old Mar 21, 2007, 05:34 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Well, it looks like mi MFX will come in at 30.6 ounces w/o the wheel pants, and with a Polyquest 2100 pack. I defy anyone to build one of these with a flying weight under 30 ounces. HH should change their specs to show the true flying weight.
Chuck
Chuck is offline Find More Posts by Chuck
Old Mar 21, 2007, 11:10 PM
Major Justice is offline
Find More Posts by Major Justice
Major Justice's Avatar
Kentucky
Joined Sep 2006
I finally figured out that the screws provided with the 480 are 6-64 & not 4-40. They looked a lot like the ones for the landing gear, & even though I got them to thread pretty far, they ended up pushing out the blind nuts. I have some 4-40x1/2 cap screws, but they didn't fit either. I ordered a box, so I should be back to work on this plane by next week.
I really don't understand the thread specifications though. Normal thread specs are like 1/4 x 12UNC x 2A. 1/4 being the diameter of the thread, 12 being threads per inch, & 2A being the precision of machining. Can anyone explain 4-40 x 3/8? I'm guessing 3/8 is the length.
Major Justice is offline Find More Posts by Major Justice
Old Mar 21, 2007, 11:18 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
hey adam i liked the fms models!
Old Mar 22, 2007, 06:20 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
4=size(diameter), 40=# tpi, 3/8= length.
Old Mar 23, 2007, 12:04 AM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
why are you guys complaining about the strength of the landing geat block? ive had on bad landing and it hit pretty hard, you guys must be ramming into the ground!
Old Mar 24, 2007, 02:02 PM
reyn3545 is offline
reyn3545's Avatar
Alpharetta, GA
Joined Jun 2006
Isn't that what you're supposed to do?
I've had a few soft landings, a few hard ones, its been holding up great since its first flight in January. Actually the whole plane is doing great, if I could just iron out the glitching... maybe I'll have some time next week.
Old Mar 24, 2007, 02:15 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
I needed some major stress relief this morning so I pulled out all the stops on the MFX this morning. Couldn't sleep so I was at the field before daylight. Had a great time out there all by myself. Now back to reality again. Work BITES!
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 25, 2007, 12:07 AM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
ive been doing some onboard video with mine lately. is pretty cool fro the view of the cockpit .
anyone try a gyro on a 3d plane?
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
