Old Mar 14, 2007, 04:48 PM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
that sucks, im gonna go and use thread lock on the screws now! i didnt think of putting it on the ez connectors but i did on everything else
mecevans is offline Find More Posts by mecevans
Old Mar 14, 2007, 05:04 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
wow! this just saved my plane, mythe landing gear was extreamly loose! one more takeoff or landing would have made it pop off!
Old Mar 14, 2007, 06:50 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
I typically use blue thread lock on all my screws, bolts and ez-connectors. It doesn't help much when you do a slam and go like I just did with the MFX. Wind was gusty and turbulent but I just couldn't help myself.
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 14, 2007, 10:43 PM
hemituda is offline
Find More Posts by hemituda
hemituda's Avatar
Joined Aug 2006
I lost two airplanes in the same manner and vowed to never use those dreaded rods and screws again. So I came up with this. http://www.precisionrcproducts.com/images/web_2.jpg
It takes a bit longer to set up but is worth the time when you don't lose an aircraft due to a loose screw.
hemituda is offline Find More Posts by hemituda
Old Mar 15, 2007, 01:54 PM
Major Justice is offline
Find More Posts by Major Justice
Major Justice's Avatar
Kentucky
Joined Sep 2006
Originally Posted by dnorm
Major,
sorry to hear bout your experience...this plane went together like a dream for me (6-8 hours if i recall correctly), what happened with your firewall, sounds odd...did the screws not thread correctly? it takes some force to rip those out...this plane is worth the effort if it's costing you some, from take off to landing and everything in between, this plane flies rock solid.
dave
All of the screws are stripped silver up to the point that I got them into the blind nuts. It seems that the blind nuts that came with the motor are exact to the ones on the MFX, so I assume the screws are the culprit. I've ordered some 4-40 x1/2 screws from Tower Hobbies, and I'll try them with the 4 good blind nuts that came with the motor. I broke a balsa spoke off of the top X on the firewall construction (Holding pliers through the skeleton to hold the blind nuts), but CA seemed to fix it. I'm also working on an Edge 540, so I'm not in a tremendous hurry to get either done.
The MFX i the first step I've took up from 25 amp setups on my electric ARFs. Neither of my current batteries were rated high enough, and I've always used e-flite's 25amp esc that already had connectors installed. I had never soldered model aircraft electronics, and to sum it up I still don't have the connectors on the ESC & battery (I understand the process. I just need some solder with flux, or a better heat source. The Horizon blue connectors need to be hotter to melt to solder that came with my iron). This plane was a Christmas present from my dad & grandma, so I will surely finish it, no matter how many problems I have. It 3Ds easier than all the others on FMS too, which matches the reports from here, and something that you ae better at provides more fun. I'd say that's why everyone loves this plane so much.
Here's a link to the MFX FMS model. I'm sure it's a bad representation of the plane (You have to set weird parameters to make a 3D model on FMS like making the plane weigh less), but it comes with & without SFG's, and FMS is a free simulator.
http://www.rc-sim.de/dl_engine/files...untana%20X.zip
Major Justice is offline Find More Posts by Major Justice
Old Mar 15, 2007, 11:32 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
just heard that the mfx was reviewed in backyard flyer. im gonna pick up a copy to see what the review is
Old Mar 16, 2007, 12:36 AM
IH8VTEC is offline
Find More Posts by IH8VTEC
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
I'll give you 3 guesses on what they said...
IH8VTEC is offline Find More Posts by IH8VTEC
Old Mar 16, 2007, 01:04 AM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
it sucks
needs more rudder
im hungry
Old Mar 16, 2007, 02:08 PM
Kentucky
Joined Sep 2006
Backyard Flyer loved the Brio. Everyone I've talked to hated it. They all had the same problem with how the linkage pulled the long aileron control surfaces. That's probably a problem that appears after some wear though, and reviews are mainly first hand impressions.
What did they say though? I'm curious now.
Old Mar 16, 2007, 06:58 PM
ss2p is offline
Find More Posts by ss2p
Paul Teesalu
ss2p's Avatar
Goleta, CA
Joined Aug 2006
I just flew mine ... Here is the whole flight no cut outs... This time I flew more funfly rather than 3d but you can still see a eye level hover and a couple of inverted and upright harriers:
http://video.google.com/videoplay?do...=mini+edge+540
ss2p is offline Find More Posts by ss2p
Old Mar 16, 2007, 07:02 PM
ss2p is offline
Paul Teesalu
ss2p's Avatar
Goleta, CA
Joined Aug 2006
oops sorry I posted wrong link its this one:
http://video.google.com/videoplay?do...mini+funtana+x
Old Mar 16, 2007, 07:05 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
That was entertaining but I missed the eye level hover. The landing definitely made it worth watching tho.
Old Mar 16, 2007, 07:10 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Very nice. Were you flying to the music. I gotta load my mp3 player and do some flying to the music. Been meaning to do that forever.
Old Mar 16, 2007, 07:13 PM
Kentucky
Joined Sep 2006
Is that with the E-Flite 1020kv outrunner?
Old Mar 16, 2007, 07:40 PM
av8r is offline
Find More Posts by av8r
...the wind usually blows
av8r's Avatar
Carbon Creek
Joined Jan 2004
Be careful. Last time I did that I was surprised by an LVC!
av8r is offline Find More Posts by av8r
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Poll New Warbird offering from E-Flite Tommy D Electric Warbirds 35 Jun 05, 2006 10:46 AM
New Cessna 182 370 ARF from E-flite hlondono111 Electric Plane Talk 0 Oct 03, 2005 03:47 PM
Yippee! New Ultimate from E Flite!!! marshallcowboy Electric Plane Talk 0 Jul 18, 2005 10:14 PM
