Old Oct 28, 2006, 10:02 PM
magic612 is offline
Find More Posts by magic612
Bernoulli+Newton=Lift
magic612's Avatar
Somewhere south of Chicago, IL
Joined Jan 2006
"WICKED WITCH of the West" biplane - pictures, videos & FREE PLANS
Okay, so I bought a bunch of Depron foam yesterday at my LHS and was trying to think of something unique to make. I remembered on GWS's site there is a funky looking plane called "Mr. Lin the Magician" or something, and thought: Why not make a Wicked Witch on a broom, using a similar concept for the design?
Well, about 6 hours later, here's what I came up with - couldn't test fly it today, since winds have been about 15-20 MPH all day, and I'd rather give it a test flight under calmer conditions. It did glide pretty well across my living room, so I'm pretty sure it will fly (though whether I can control it will be another matter!).
Pretty simple setup: 6mm Depron foam for the body, skirt (lower wing) and hat (upper wing), and 3mm Cellfoam 88 for the broom (tail and horizontal stab). I only made it aileron and elevator, but it would be simple enough to add a tail function, if desired - I was going with weight savings in mind. Motor and gearbox is a GWS IPS with "C" gear ratio, two Naro/std servos, GWS 4 ch. receiver and an 8 amp ESC. I wound up designing it with the CG right where the battery goes (partly intentional!), so any battery can be stuck on it within reason. My AUW is 7.5 oz, and I figured the wing area at 289 sq inches (give or take a few), so wing loading is 3.75 oz per sq. foot.
Hopefully I can try it tomorrow, and with any luck, it will fly slowly enough and with sufficient stability to use it on Halloween night!
PLANS ARE IN POST 18.
Video is in Post 19.
magic612 is offline Find More Posts by magic612
Old Oct 29, 2006, 01:48 AM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Very cool... Once my boy gets a bit older (23 months now) I think I'd like to try something like this... I think he's still too young to appreciate it
2nd pic... kinda reminded me of a star trek design... Is that what you meant?
Also, I can't tell from the pictures, but one thing I recently learned in a staggerwing bipe (which I guess this sort of is...) is that you want the top wing to have a slightly greater incidence than the bottom wing... Something about it'll stall first while the bottom wing will continue flying... Nothing major, just an 1/8" or something like that... I guess the other alternative is to not stall it...
Keep us posted w/ the maiden!
-mike s.
msmith is offline Find More Posts by msmith
Old Oct 29, 2006, 05:02 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
That looks really good, magic!
I remember as a kid we used to have "bat" kites - they were black with a pair of stick on eyes on them. If you took one of those and attached it to the witches back/shoulders, it'd work pretty good, I think. You'd just need R and E on the broom then.
Kites are a couple of bux at wally world - you'd just need to shoot a coat of black over top of the spiderman logo
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Oct 29, 2006, 08:39 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Thanks for the nice words guys - much appreciated!
msmith I did build in a higher incidence for the top "wing" - it's set about three degrees up from the bottom "wing". And my wife was the one who first pointed out the resemblance to the Enterprise.... that one got me thinking about another unique one I'll have to try one of these days...
brad - I remember those kites! They don't make 'em like they used to, eh? You know, I suppose it wouldn't be hard to slide the witch "back" on the broom, and use her "back" as a tail if needed, too. Though the 3D one I used would work too. Come to think about it, would she actually turn, or would you need an aileron function to force the banking?
Heh - and wouldn't the paint on the kite weight it down a bit too much? It could be re-made out of the black plastic from a trash bag - it would be harder to puncture / tear, then!!! Haha!
Old Oct 29, 2006, 12:31 PM
thetriguy is offline
Find More Posts by thetriguy
Joined Sep 2006
Magic612,
Great job, it looks awesome! I wish I had seen something like this sooner, I would have HAD to try and build one for Halloween... Put a small led light pointing towards the witches face, that would be cool!!
Mark
thetriguy is offline Find More Posts by thetriguy
Old Oct 30, 2006, 08:42 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Thanks, Mark! My older daughter thought it needed a cat - perhaps putting one up front would be a good place to hide that LED...
Maiden flight was less than impressive. It's severely underpowered with the IPS-C motor / gearbox. It flew, sort of, but never got enough lift to at least stay level, much less gain altitude. So it did a slow descent each time a tried to toss "her". I'm going to try an EPS-C system with a larger pack - both will add weight, but I'd rather her go fast and fly than slow and not fly at all. A Lipo might have helped some (I've only got NiMh's right now), but would have only saved about 3/4 oz., so I think it just needs more power. Heck, a LiPo and brushless would be ideal, but I don't have the $$$ for either right now.
Ah well, not sure I'll get her going for this year, but I'll have her for next, for sure!
Old Oct 31, 2006, 07:51 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
IF you want a bargain for Brushless. This guy on ebay is awesome! I buy all my stuff. Super Fast shipping and excellent prices on good hardware
http://stores.ebay.com/Heads-Up-RC
Here is a nice Motor and ESC combo for $32 plus $2 shipping.
http://cgi.ebay.com/2408-21-Outrunne...QQcmdZViewItem
SGTalon is offline Find More Posts by SGTalon
Old Oct 31, 2006, 08:07 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Wow! Thanks SGTalon - that looks like quite a deal. What do you know about that motor and ESC though? Any good? Any issues?
Old Oct 31, 2006, 04:37 PM
Joined Dec 2003
This one night be better. The BP21 likes an 8" max prop - this one will churn a 12" prop.
http://cgi.ebay.com/2410-12Y-Outrunn...QQcmdZViewItem
Old Jun 15, 2007, 09:31 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
How far ahead of Halloween are plans needed?
Alright, so since I finally got around to creating a blog here (and adding the pictures below to it), I thought I might at least gauge how far ahead of Halloween folks might want plans for this.. ahem, "girl". I have yet to put a brushless / lipo set up on her, though from what I remember of the flight characteristics when I did fly her, she will very likely stay aloft. (Note: the radio had been ripped off for other projects before I acquired brushless and lipo gear, but she's hanging in my garage, waiting to terrorize the skies again!)
Anyway, I do want to test her out fully with brushless / lipo before finalizing plans (which I'll do as soon as I get some more servos which are on order), but how far ahead of Halloween would you guys want plans to be able to build this? Yes, FREE plans - this is one of those things I'm more than happy to share. (All I ask is that you guys please post pics of your versions.)
So I was wondering when I should have them ready for posting: July? August? September? Thoughts?
Old Jun 15, 2007, 01:21 PM
Beemus is offline
Find More Posts by Beemus
The Dude Abides
Beemus's Avatar
Brockport
Joined Sep 2005
Dude, cool witch, and sooner is always better than later (in most things).
Peace Man
Beemus is offline Find More Posts by Beemus
Old Sep 17, 2007, 11:48 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Well, you know how life can get in the way of getting stuff done you want to get done - first, been painting my house for the past few months. Second, been working on othe planes in the spare time I have had. Third, broke a tiny wire lead off of my "Blue Wonder" brushless motor, rendering it uselss.
However, I did drag the "Witch" in from the garage yesterday, and I have two "Blue Wonders" on their way to me, which I suspect I'll see at my house in about a week. I'm quite sure with one of those motors on there, and a 500 or 800 mAh Lipo, the "Witch" will fly quite soon.
I'll post progress reports when I can - and hopefully a video or two as well.
Old Sep 17, 2007, 03:19 PM
Jim_W is online now
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
Waiting to see plans and video myself!! I built a GWS Magician 2 years ago, and put LED's on it. It flew really well, just very fragile. Not something I'd go to the trouble of adding LED's to again. Been looking for a more robust alternative. This looks interesting. Nice job.
http://www.rcgroups.com/forums/showp...96&postcount=8
Jim_W is online now Find More Posts by Jim_W
Old Sep 17, 2007, 03:28 PM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Jim -
That looks awesome! I'm thinking that if people made this Witch out of EPP foam, it'd be plenty durable. Mine is Depron, so I'll have to be careful on landings, but anyone with EPP on hand can make her just about crash proof.
I'll clean up the plans and have them posted sometime in the next week or so.
Old Sep 17, 2007, 03:31 PM
kf2qd is offline
Find More Posts by kf2qd
Joined Jul 2006
Plans?
Magic - I would love to see a set of plans .
Kf2qd
kf2qd is offline Find More Posts by kf2qd
Just in time for xmas "Clayton Classic" flybaby2000 Thermal 0 Dec 24, 2004 06:40 AM
Boat For Sale...just in time for christmas thechosen1one Boats (FS/W) 3 Dec 09, 2004 08:09 PM
Rave Just in time for the building season... SKYPILEIT Humor 3 Dec 06, 2004 11:01 AM
JR XP8103DT Helicopter TX - Just in time for Xmas! bobandris Aircraft - Electric - Airplanes (FS/W) 0 Dec 16, 2001 11:26 PM
FS: JR XP8103DT Helicopter TX - Just in time for Xmas! bobandris Aircraft - Electric - Airplanes (FS/W) 0 Dec 11, 2001 12:40 PM
