Old Oct 28, 2006, 11:09 AM
AerodromeRC is offline
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
AerodromeRC 1:6th scale Fokker Dr.I
Hi All,
AerodromeRC 1:6th scale Fokker Dr.I for AXI 2826 BL motor has been added to our web site and store.
it has:
Two piece construction, top, middle wings and part of fuselage remove as one piece for easy transport
Wing alignment is built into model
Fuselage built from laser cut formers and stringers
Front of the fuselage is balsa box, the rear is built up
Laser cut balsa turtle deck
Laser cut parts for built up cowl
Contains nearly all wood necessary to complete model
Dummy Spandau machine gun kits included
Dummy engine included
Dummy pilot included
Laser cut plywood IP struts
Laser cut tail parts included
Scale number of ribs
Flat bottomed scale like airfoil
Laser cut 1/32" plywood trailing edges insure scale scalloping
Balsa and ply tabbed leading edges, included
Balsa and plywood wheel kit with Neoprene foam rubber tire material included
www.aerodromeRC.com
--Kurt
AerodromeRC is offline Find More Posts by AerodromeRC
Discussion AerodromeRC 1:6th scale Fokker DVII Build AerodromeRC Scale Kit/Scratch Built 7 Aug 24, 2007 07:24 PM
For Sale 1/4 scale Fokker DR-1 Triplane by Balsa USA> nakman8 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 20, 2006 09:11 PM
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scale Kit/Scratch Built 3 Aug 29, 2005 03:22 PM
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scratchbuilt Indoor and Micro Models 0 Aug 28, 2005 06:26 PM
AerodromeRC 1/6th scale Fokker EIII and GWS powered 1/12th scale Fokker DR.1 AerodromeRC Scale Kit/Scratch Built 1 Aug 23, 2005 08:30 PM
