Old Oct 27, 2006, 12:48 PM
afineman is offline
Find More Posts by afineman
afineman's Avatar
New Hampshire
Joined Jul 2004
Mini-Review
HXT63-64 B, HXT 100 amp ESC, A123 L/I
Greetings all
I will start testing the above motor with the above ESC today ( and probably in to the evening)
I put this motor
http://www.unitedhobbies.com/UNITEDH...idProduct=2097
With this ESC http://www.unitedhobbies.com/UNITEDH...idProduct=2143
Into this plane http://ak-models.com/ultimate_120.htm
Using these batteries http://www.a123systems.com/html/home.html ( via dissected Dewalt battery packs)
I will be running 10S1P of the A123 batteries, I'll be using a Hanger9 digital tach and a WattsUp meter ( or the Watt meter built in to the Xtrema V1.1 charger).
Here are a few photos before I start the soldering
Brent
OOHH I ordered the ESC on Saturday evening (sunday morning in HK) and I got it today, NOW that was fast
My wife held the motor while I took that picture.
The motor mounted on the Ultimate.
# ESCs, HTX 100 amp, Tower Pro 60 amp and Tower Pro 18 Amp
Picture from a Taxi video I did of this plane
afineman is offline Find More Posts by afineman
Old Oct 27, 2006, 01:20 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
I am VERY interested in this!
I am converting a TopFlite Spit to electric, and expect a AUW of ~9lbs, so this setup may be just what I need. I am leaning towards Emolis for the batts. Can't wait for some numbers Brent.
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Oct 27, 2006, 02:56 PM
staggerwing is offline
Find More Posts by staggerwing
In NY's beautifull hills
staggerwing's Avatar
Binghamton Broome Cty, New York, United States
Joined Jun 2004
I too am very interested--I just now placed my first order w/ U Hobbies which includes (2) of these 100A ESC's.
A note about U Hobbies;
If you are not a Pay Pal member & don't want to become one, don't try ordering from them ----I did--- & from not having my sh---t together checking out, I am now a Pay Pal member,(until I get rid of that credit card).
Brent, Just glanced @ your motor mounting, torque is going to give that mount a real test, especially from start up & if that's hardware store grade (2) threaded rod w/ cut threads as opposed to rolled, (hard to tell from the pic), it will be even more susceptible to failure.
Not trying to be critical, but for safety, maybe you should try the mount w/ motor set up on another fixed object other than the Ult .
staggerwing is offline Find More Posts by staggerwing
Old Oct 27, 2006, 03:13 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
So you need PP to place an order?
Old Oct 27, 2006, 03:14 PM
afineman is offline
afineman's Avatar
New Hampshire
Joined Jul 2004
1st test
Hey All
According to the UPS web site, my 2 Dewalt packs are "Out for delivery", so rather than cut up a 6S2p packs, I decided I can wait a few hours for UPS to get here.
I put everything together, and sparked it up with the 6S2P pack using a 14X7 prop, the results http://www.rcuvideos.com/view_video....7fb2f7ba36d74d
So everything runs, and I got some benchmark data, I will use this data to tweak the on-line motor simulators so I can more accurately predict what I need to do with this.
I'll update again later once I get the 10S pack built ( and another short video, the best way to keep notes )
I'll go sit by the window and wait for the Brown Guy
Brent
Old Oct 27, 2006, 03:17 PM
Joined Jun 2004
"So you need PP to place an order?"
Somehow my Mastercard became part of Pay Pal during the transaction
Old Oct 27, 2006, 04:16 PM
DavidB. is offline
Find More Posts by DavidB.
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
The controller sounds like it has huge steps in the transition...I guess I'll spend a little more and get a HV-85....
DavidB. is offline Find More Posts by DavidB.
Old Oct 27, 2006, 05:30 PM
afineman is offline
afineman's Avatar
New Hampshire
Joined Jul 2004
The little brown guy came
All
I got the Dewalt packs, dissected them and made a 10S1P pack.
Here are the results still using a 14X7 prop http://www.rcuvideos.com/view_video....285b3f6d57958d
I will visit the LHS in the AM (get some larger props) and continue.
I was only drawing 27 amps and if you do the math you will see I am already up to 7+lbs of thrust so a 18-20 inch prop should do the trick for this plane.
More to follow
OOHH and DavidB I was not going up 1 click at a time, and even if it is only 20 steps to WOT on this ESC it is worth it to me, I use maybe 5 positions on my throttle, I don't need a 100 step resolution ( needing to be able to adjust power in the 1% range is not needed for how I fly)
Brent
Old Oct 27, 2006, 07:28 PM
afineman is offline
afineman's Avatar
New Hampshire
Joined Jul 2004
Video for Dave
Dave
I am using a Polk III tx from 0% power to 100% power this throttle has 24 clicks.
So in the video I use 14 of the 24 clicks, I could program my tx to reduce the range, meaning more clicks are used through the usable band.
Dave I am sure if you were to use a tx where you can program the throttle limits, there would be a change per click.
The video http://www.rcuvideos.com/view_video....08aac48a549829
Hope it helped
Brent
Old Oct 27, 2006, 07:51 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
Nice
How many watts are you expecting to run?
Old Oct 27, 2006, 09:45 PM
CSO#1 @UHobbies is offline
Find More Posts by CSO#1 @UHobbies
UNITEDHOBBIES.com
CSO#1 @UHobbies's Avatar
In a warehouse
Joined Sep 2006
Hello.
You do not need to be a paypal member to buy from us.
If you select the option to join paypal, then you will become a member.
Rgds
CSO
CSO#1 @UHobbies is offline Find More Posts by CSO#1 @UHobbies
Old Oct 27, 2006, 09:54 PM
Impact is offline
Find More Posts by Impact
High Roller designer
Impact's Avatar
Londonderry NH
Joined Mar 2005
Very nice brent, that's one big honken motor. Looks like with the right prop you will be good to go, What's the AUW going to be. To bad this weekend is supposed to be so crappy. I'm looking forward to see this fly, I hope we don't have to use the defibrillator to jump start anyone on the maiden voyage .......Impact
Impact is offline Find More Posts by Impact
Old Oct 28, 2006, 02:52 PM
afineman is offline
afineman's Avatar
New Hampshire
Joined Jul 2004
Getting really close
Hey All
Went to the LHS today and picked up a series of props, on another thread (a non topic) We have Glow and electric guys and none of us seem to know that the performance difference is between the APC E props and the Glow rated props.
This first test was to compare the 2 15X10 glow rated prop then a 15X10 E rated prop, the E prop drew more power and according to the online calculators I have my minimum goal to fly this plane 10 lb 13 Oz of thrust and a pitch speed of 68 Mph
http://www.rcuvideos.com/view_video....d2a20c3ecf56d7
I will still test the other props too 16, 17, 18, 19, and 20X10
OOHH and so far every thing is performing well (motor and ESC), once the testing resumes ( after wife wakes up from nap) I'll also check the various timing settings on the ESC using this 15X10E prop
Brent
Old Oct 28, 2006, 03:24 PM
Impact is offline
Impact's Avatar
Londonderry NH
Joined Mar 2005
Jump right to the 20x10 and see what you get with that. Looks good so far....Impact
Old Oct 28, 2006, 03:26 PM
Impact is offline
Impact's Avatar
Londonderry NH
Joined Mar 2005
Watching the video I saw a bit over 1000 watts, yee ha ......Impact
Discussion BP Welgard C6362-10 & HXT 100 A ESC staggerwing Power Systems 14 Feb 27, 2007 11:13 AM
New Product 100 amp ESC bob2005 Power Systems 0 Jan 27, 2007 12:43 PM
FS CC B/L 45 amp esc low time termite Aircraft - Electric - Airplanes (FS/W) 2 May 31, 2004 10:22 PM
WTB 24 cell 100 amp esc... soholingo Aircraft - Electric - Airplanes (FS/W) 9 Aug 19, 2003 04:34 PM
Hacker B-50 18s & esc speed1013 Aircraft - Electric - Airplanes (FS/W) 1 Jul 07, 2002 01:36 PM
