Sep 01, 2002, 06:59 AM
USA, KY, Verona
Joined Nov 2001
Eindecker..
Great plane...
Previous advice about gluing the tires on applies, but wheels and gear are weak. The wheels will break and the gear will bend (but not break) on every marginal landing.
Flys great on everything stock, and is very well built. I thought it would not hold up like a foam plane, but it is every bit as strong (or more). Repair is easy too if you crack it up.
As I found out, make sure the prop is balanced. My prop adapter was a bit off after a rough (crash) landing, and it would barely fly until I replaced it.
It turns like crazy, but drops a lot of elevation in the process.
My previous (first) plane was a TM, and it flys in about twice the envelop - Twice as big, fast, and lands twice as fast too!
Stalls are flat with instant recovery.
Indicated balance point on my plane put the battery further back and partially out of the battery box (not a big deal).
Flew inverted for the first time yesterday. Did an outside loop, then flew out upside down. Full rudder rolled it right back over as if it had alerons...
