Old Oct 26, 2006, 04:57 AM
aspoon is offline
Find More Posts by aspoon
Artiste Spontané
aspoon's Avatar
Hong Kong
Joined Sep 2006
How to deliberately crash a coaxial heli? (a.k.a. don't try this with a coaxial heli)
Without running it into a wall or a tree, shutting down the throttle, turning off the Tx, etc., how can you deliberately crash a coaxial heli (such as a Lama, a Vortex, or a Blade CX) in mid air?
I have done it once by shaking the cyclic control vigorously and the flybar flew off in mid-air, causing my Vortex to crash. I believe the flybar may have hit the lower blades in the process.
- Alvin
aspoon is offline Find More Posts by aspoon
Old Oct 26, 2006, 05:34 AM
quickster47 is offline
Find More Posts by quickster47
Everyone crashes sometime
quickster47's Avatar
Orlando, FL and Washington D.C.
Joined May 2006
The real underlying question that your questions begs, is why? Why would you purposefully want to crash your helicopter? Seems like it happens often enough without having to try.
quickster47 is offline Find More Posts by quickster47
Old Oct 26, 2006, 07:03 AM
101gazza101 is offline
Find More Posts by 101gazza101
Joined Oct 2006
You could throw rocks at it ?
101gazza101 is offline Find More Posts by 101gazza101
Old Oct 26, 2006, 05:41 PM
aeronuts is offline
Find More Posts by aeronuts
aeronuts's Avatar
USA, WV, Charles Town
Joined Mar 2005
Try picking up a little speed in FFF, then abruptly reverse pitch and give a little roll (either direction). I accidentally did this once or twice, and it dropped like a shot duck.
aeronuts is offline Find More Posts by aeronuts
Old Oct 26, 2006, 06:01 PM
moosemanty is offline
Find More Posts by moosemanty
Rcer field rep.
yucca valley, CA/// RCG
Joined May 2006
this works well, i have done this many times with my 5-4 by acciedent once those blades hit each other that thing will flip around in the air then go to greet the ground........................
P.S.......a simple question, what exactly dose FFF or FF stand for (just thought i would ask while i am here)
moosemanty is offline Find More Posts by moosemanty
Old Oct 26, 2006, 06:50 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
FFF= Fast Forward Flight, FF= Forward Flight
heligrom is offline Find More Posts by heligrom
Old Oct 26, 2006, 07:02 PM
Dan_H is offline
Find More Posts by Dan_H
Joined Sep 2006
Yeah, all I need to do is fly my CX aggressively and the blade will clack against each other eventualy and down it goes....
Dan_H is offline Find More Posts by Dan_H
Old Nov 04, 2006, 09:18 PM
aspoon is offline
Artiste Spontané
aspoon's Avatar
Hong Kong
Joined Sep 2006
The thing is that I have been flying my Vortex for a while, and have been doing fine hovering and "sliding" all over. I was trying to discover the capability of the heli and started vigorously shaking the controls to see how fast it responses, and obviously that resulted in a crash.
As I thought that you could only crash a heli by hitting it against something, I was so surprised that I could crash the flybar with the blades. And that's why this topic came up, to see what else not to try if I don't want to do anymore fixing.
- Alvin
Old Nov 04, 2006, 11:52 PM
cyclonite is offline
Find More Posts by cyclonite
United Kingdom, England, Egham
Joined Sep 2006
to crash your co-axial heli, give your batteries full charge and let it fly upwards on full throttle with the trim all the way up FULL THROTTLE... let it go as high as it can and then shut off the TX
cyclonite is offline Find More Posts by cyclonite
Old Nov 05, 2006, 09:57 AM
aspoon is offline
Artiste Spontané
aspoon's Avatar
Hong Kong
Joined Sep 2006
Meaning... don't turn off the Tx.
Old Nov 05, 2006, 11:11 AM
Joined Sep 2006
nah... if you don't turn off the TX there's a possibility the heli will loose altitude due to weak battery
Old Nov 06, 2006, 02:49 PM
Helivadude is offline
Find More Posts by Helivadude
Joined Oct 2006
Don't forget to set fire to it first, that would be cool.
Helivadude is offline Find More Posts by Helivadude
Oh my gosh - don't try this at home! Jurgen Heilig Scratchbuilt Indoor and Micro Models 27 Jan 15, 2004 11:20 AM
Overload Test - don't try this at home (or anywhere else) Neil Stainton Castle Creations 4 Jan 14, 2004 05:35 PM
Don't try this at home. wolfance Humor 5 Jun 10, 2003 05:24 PM
Don't Try This at Home DNA Humor 1 Apr 14, 2003 01:44 AM
Corsair project half completed -- don't try this at home! Neil Morse Electric Plane Talk 2 Sep 10, 2001 04:43 PM
