Old Oct 25, 2006, 10:44 PM
Sled Driver is offline
Find More Posts by Sled Driver
Knowledge increases life's FOV
Sled Driver's Avatar
Third Stone from the Sun
Joined Nov 2003
Help!
Request for twisty wing plane span and aspect ratio (or wing area) data
Sleedo's "Twisty wing aspect ratio" thread got me thinking that it would be nice to have a comparison of span to aspect ratio just to see where everthing falls. So, I started the figure attached using data that I had available for the following planes:
Rotor (VS Sailplanes)
Xica (VS Sailplanes)
Xingu (VS Sailplanes)
V-max (VS Sailplanes)
Vector (Brian McLean)
Ultron (Brian Courtice)
If you have data for any wingeron or pitcheron plane not listed above, would you please PM me with the data. Specifically, I need the wing span, and aspect ratio or wing area (I can calculate aspect ratio with wing span and wing area).
As you can see in the attached figure, the relationship of span to aspect ratio for these planes is quite strong. It would be great to get more data for other designs, like the Shrike, Mach-1, Sig Samurai, etc.
Jay Decker
Kennewick, WA
Sled Driver is offline Find More Posts by Sled Driver
Old Oct 25, 2006, 10:51 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Makes you wonder what's magic about a 6" mean aero chord
Nauga,
the constant variable
nauga is offline Find More Posts by nauga
Old Oct 25, 2006, 11:18 PM
Dale Thompson is online now
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
United States, CA, Truckee
Joined Aug 2005
Can we add the CR Turbo and Contender?
Sorry I don't have the data but just got the fuse's!
Dale Thompson is online now Find More Posts by Dale Thompson
Old Oct 26, 2006, 01:17 AM
gorgeflyer is offline
Find More Posts by gorgeflyer
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
Where's the Mach1 fall out in this chart? Curious minds want to know.
gorgeflyer is offline Find More Posts by gorgeflyer
Old Oct 26, 2006, 01:42 AM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Turbo and Contender info sent.
slopemeno is offline Find More Posts by slopemeno
Old Oct 26, 2006, 07:06 AM
Joined Aug 2005
Thanks Tony!
Old Oct 26, 2006, 08:19 AM
Joined Nov 2003
Received data for the following planes:
Mach-1 (Joe Comier)
Dorita Wingeron (Hutch's design)
Sushi Pitcheron (Hutch's design)
Shredder Pitcheron (Mark Grand)
Minnow Pitcheron (Hutch's design)
Snipe (NSP Version)
Orca (Harley Michaelis)
Contender (woody version, CR)
Turbo FG (CR)
Still looking for data on the Shrike, Sig Samurai, Kestrel, and any others...
Old Oct 26, 2006, 08:41 PM
Joined Nov 2003
Done...
Thanks to those who provide additional data. Here are the results...
Old Oct 26, 2006, 10:43 PM
El Diablo is offline
Find More Posts by El Diablo
El Diablo's Avatar
Joined Mar 2006
Nauga,
Isn't 6" the mean aero chord for American men?
El Diablo is offline Find More Posts by El Diablo
Old Oct 26, 2006, 11:35 PM
Joined Aug 2005
Jay, Is it time to enlighten us with some insight about the plots?
Is there anything that stands out?
Old Oct 27, 2006, 09:03 AM
Utahrd is offline
Find More Posts by Utahrd
Flounder
Utahrd's Avatar
Three turns into Eddie’s High Nowhere
Joined Aug 2006
Axle (Sailplanes Intl):
- Span: 76"
- A/R: 14.5
Utahrd is offline Find More Posts by Utahrd
Old Oct 27, 2006, 09:24 AM
sl33pdirt is offline
Find More Posts by sl33pdirt
Guest
Oceanside
Joined Nov 2002
Anyone have a picture of the Xigu? 16-1 AR and 100" span sounds like an extreme machine to be sure!
sl33pdirt is offline Find More Posts by sl33pdirt
Old Oct 27, 2006, 10:34 AM
Joined Nov 2003
The Xingu...
Old Oct 27, 2006, 10:42 AM
Guest
Oceanside
Joined Nov 2002
Ahhh...Xingu. Nice planform and another beauty from VS. You slap on the Eppler wings for your light lift and TD the 6060's tearing up the slope...amazing.
Thanks!
Old Oct 27, 2006, 01:54 PM
Joined Nov 2003
This exercise was intended to confirm a premise that I have been operating under while developing a new wingeron design that is intended to be the fastest plane on the hill while being very agile… a next step from the Xica and Kestrel, if you will. The result is confirmation that the same basic span and aspect ratio correlation that makes conventional slope airplanes fast and/or agile is applicable to wingeron and pitcheron designs. I’ll spare you a bunch of techno-babble and just say that when you overlay data for conventional slope airplanes, e.g., the Prodij, Viking, Hypnosis, JART, etc., you get a very similar distribution of aspect ratio with span for similar types of airplane performance.
This result might sound like it should be self-evident; however, a number of folks I respect have expressed at least a suspicion that wingeron and pitcheron designs are fundamentally different and have (or should have) a higher aspect ratio for a given span than a conventional slope plane. While wingeron and pitcheron planes tend to be slightly bias toward the higher end of the aspect range for a given span, they are within the conventional slope plane distribution. I think that practical factors such as wingeron drive mechanics and a general experienced pilot preference for higher speed probably drive the slight bias toward the higher end of the aspect ratio range.
Jay Decker
Kennewick, WA
Question Twisty wing aspect ratio Sleedo Slope 27 Oct 26, 2006 01:20 AM
Wanted Trade this for you RTF plane/wing or gear--->>in>> johnnybronco Aircraft - Electric - Airplanes (FS/W) 0 Oct 10, 2006 08:39 PM
Good airfoil for a low aspect ratio wing tolladay Electric Sailplanes 4 Jun 04, 2003 08:10 AM
MEGA ACn 22/10/5 for a zagi type wing plane? Scar13 Foamies (Kits) 2 Apr 03, 2003 12:25 AM
help! How do I shape the front wing for the "and now' plane Richard Hayes Foamies (Kits) 9 Feb 01, 2002 05:07 PM
