| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Thread Tools |
| This thread is privately moderated by fly_boy99, who may elect to delete unwanted replies. |
#1 |
Flying motor mount master
Motor formulas
I thought it would be a good idea to have a sticky around motor formulas we constantly use here in the EMD&C section. If there is an error please PM me instead of posting here.
Please add new formulas as you see fit but please do not clutter this stickey with commentary. If you wish to do that start your own thread. Thank you. ======= Efficiency Motor Efficiency = Pout/Pin Pout = (Vin - Iin * Rm) * (Iin - Io) ======= Motor Kv Kv = RPM / (Vin - Vloss) Vloss = Iin * Rm ======= Motor RPM RPM = Kv * (V - Vloss) Vloss = Iin * Rm ======= Watts Watts = V * Iin Alternately P=I²R (P = I x I x Rm) ======= Stalled Motor Istall = Vin / Rm ======= Torque constant Torque constant: Kt=Kb x 1.345 Kb = Voltage constant (Volt/1000 RPM) ======= Torque Loss Torque = Kt * (Iin - Io) ======= Termination Wye = the number of winds you have performed Delta = divide the number of turns by 1.73 ======= Watts per Horsepower 1 horsepower = 746 watts ======= Acronyms ======= Rm = Resistance value of the motor, derived from the guage of wire used Pout = Power Out of the Motor expressed in Watts Pin = Power In of the Motor expressed in Watts Vin = Voltage Into the Motor Iin = Current Into the Motor Io = Noload Current of the Motor, derived from running a motor WOT without a prop at varying voltages. Io can be expressed with an associated Voltage and should be. Kv = K value or voltage constant, the expressed value where the rpm can be surmised by a given voltage. For a 2000 Kv motor an input voltage of 10V would net 20000RPM. Istall = The load current of a motor which is purposely stalled, hence not turning Kt = Torque constant (oz-In/A) Kb = Voltage constant (Volt/1000 RPM) Note: Data has been gathered and utilized from various sources such as the aveox site as well as others. Last edited by fly_boy99; Mar 26, 2007 at 02:31 PM. Reason: Thanks Jeremey |
#2 |
homo ludens modellisticus
Not exactly formulas:
Doubling the number of winds halves Kv (rpm/volt) and doubles Kt (torque/Ampere) Doubling statorheight halves Kv, doubles Kt and (roughly) doubles maximum power. |
#3 |
Max power (with akceptable efficiency) of the motor is about
Pin[W]=1600*Vmagnet[inch^3] Pin[W]=0.1*Vmagnet[mm^3] This formula is based on practice, and work well on neodym magnet. It is very usefull to calculate an appropriate max. supply voltage, rpm, proppeler etc. (based on the motor resistance and expecting efficiency or simply optimal motor current) Last edited by tomekr; Apr 13, 2007 at 02:45 PM. |
#4 |
About termination
Kv ratio = 1.732 is a controversy A lot of testers found a ratio between 1.78 and 1.9 Louis |
#5 |
huh?
#6 |
logicman
magnets and poles
How does one calculate how many magnets to use against the number of poles, and what decides the winding direction? Anyone please?
Thanks Brian |
#7 |
Squematic Circuit Z3007-26 HypÉrion
PLEASE SOMEBODY HAVE AN ELECTRIC CIRCUIT OF ELECTRIC MOTOR BRUSHLESS 12 POLES 14 MAGNETOS? THE MOTOR IS Z3007-26 HYPERION
the bindings betweem wires are delta or star? TKS Hélio Vaitsman Last edited by heliovaitsman; Oct 29, 2007 at 06:49 PM. Reason: complete information |
#8 | |
Poles and magnets
try this one! I found it on a German site three years ago http://www.rclineforum.de/forum/thre...did=60302&sid= Copy the program below (in dark red starting with <HTML> and ends with </HTML>) in Notes and save it as Poles and magnets.html and run it as a Java program. <html> <head> <title>Schematic for electric motor windings</title> <style type="text/css"> <!-- body { font-family: arial; font-size: 14px} td { font-family: arial; font-size: 14px} .result { background-color: #d0c0c0 } --> </style> <script language="JavaScript"> <!-- function SymError() { return true; } window.onerror = SymError; var SymRealWinOpen = window.open; function SymWinOpen(url, name, attributes) { return (new Object()); } window.open = SymWinOpen; //--> </script> <script language="JavaScript"> // Lizenz: // Verwendung und/oder Modifikation für eigene Homepage // nur mit folgendem Verweis auf das Original: // http://www.maltemedia.de/brushless/wicklungsschema/ // (C) 2004 overclocker_2001 alias oc2k1 & DrM (drmalte@maltemedia.de) // // Modifikation nur mit dem Einverständnis, daß die Modifikationen // auch in das Original eingebaut werden dürfen. function init() { document.Windungsrechner.Nuten.focus(); document.Windungsrechner.Nuten.value = ""; document.Windungsrechner.Pole.value = ""; document.Windungsrechner.Ergebnis.value = ""; } function berechnen( form ) { Nuten = eval( form.Nuten.value ); Pole = eval( form.Pole.value ); if( Nuten % 3 != 0 || Nuten < 3 ) { document.Windungsrechner.Ergebnis.value = "Pole number must be divisable with 3!"; document.Windungsrechner.Nuten.focus(); document.Windungsrechner.Nuten.select(); return; } if( Pole % 2 != 0 || Pole < 2 ) { document.Windungsrechner.Ergebnis.value = "Magnet number must be an even number!"; document.Windungsrechner.Pole.focus(); document.Windungsrechner.Pole.select(); return; } if( Pole == Nuten ) { document.Windungsrechner.Ergebnis.value = "Pole number must be different from magnet number!"; document.Windungsrechner.Pole.focus(); document.Windungsrechner.Pole.select(); return; } Winkel = 180 * Pole / Nuten; a = 0; b = 0; c = 0; A = 0; B = 0; C = 0; schema = "" summe = 0; for( i = 0; i < Nuten; i++ ){ if( summe >= 330 || summe < 30 ) { schema += "A"; A++; } if( summe >= 30 && summe < 90 ) { schema += "b"; b++; } if( summe >= 90 && summe < 150 ) { schema += "C"; C++; } if( summe >= 150 && summe < 210 ) { schema += "a"; a++; } if( summe >= 210 && summe < 270 ) { schema += "B"; B++; } if( summe >= 270 && summe < 330 ) { schema += "c"; c++; } summe = ( summe + Winkel ) % 360; } if( a == b && a == c && A == B && A == C ) { while( schema.charAt(schema.length-1) == 'a' || schema.charAt(schema.length-1) == 'A' ) { schema = schema.charAt(schema.length-1) + schema.slice( 0, -1 ); } if( schema.charAt( 0 ) == "a" ) { schema = schema.replace( /a/g, 'x' ); schema = schema.replace( /b/g, 'y' ); schema = schema.replace( /c/g, 'z' ); schema = schema.replace( /A/g, 'a' ); schema = schema.replace( /B/g, 'b' ); schema = schema.replace( /C/g, 'c' ); schema = schema.replace( /x/g, 'A' ); schema = schema.replace( /y/g, 'B' ); schema = schema.replace( /z/g, 'C' ); } if( schema.search( /[bB]/ ) > schema.search( /[cC]/ ) ) { schema = schema.replace( /b/g, 'x' ); schema = schema.replace( /c/g, 'y' ); schema = schema.replace( /x/g, 'c' ); schema = schema.replace( /y/g, 'b' ); schema = schema.replace( /B/g, 'x' ); schema = schema.replace( /C/g, 'y' ); schema = schema.replace( /x/g, 'C' ); schema = schema.replace( /y/g, 'B' ); } document.Windungsrechner.Ergebnis.value = schema; } else { document.Windungsrechner.Ergebnis.value = "Invalid combination! ("+schema+")"; } } </script> </head> <body bgcolor=white onload="var SymTmpWinOpen = window.open; window.open = SymWinOpen; init(); window.open = SymTmpWinOpen;"> <form name="Windungsrechner"> <BR><BR> <div align="center"><center> <!-- <B>Scrift is still working, please be patient </B><BR> --><B>Motor winding schema V1.0</B><BR><BR> Dial in pole and magnet numbers and press = or press ENTER. <BR><BR> <table border="1" cellpadding=5 CELLSPACING=0> <tr> <td>Poler:</td> <td><input type="text" size="3" name="Nuten" maxlength="3"></td> <td>Magneter:</td> <td><input type="text" size="3" maxlength="3" name="Pole"></td> <td><input type="submit" name="Berechnen" value="=" onclick="berechnen(this.form);return false;"></td> <td><input type="text" size="64" name="Ergebnis" readonly class=result></td> </tr> </table> <BR> <!-- Number of poles must be a multiple of 3 and the number of magnet must be amuliple of 2.<BR> Valid answers are given if there are equal numbers of A/a, B/b and C/c. 12P18M or 15P12M do not work. --> <BR><BR> <A HREF="http://www.rclineforum.de/forum/thread.php?threadid=60302&sid=">Source: http://www.maltemedia.de/brushless/wicklungsschema/ <BR> (C) 2004 overclocker_2001 alias oc2k1 & DrM (drmalte@maltemedia.de)</A> <BR>Translated from German into English by Björn Hammarskjöld, Mora, Sweden, 2007 </center> </div> </form> <p></p> <noscript> Please activate Javascript </noscript> <a href="http://www.maltemedia.de/brushless/wicklungsschema/source.txt">Source</a> </body> <script language="JavaScript"> <!-- window.open = SymRealWinOpen; //--> </script> </html> |
#9 | |
![]() http://www.southernsoaringclub.org.za/ -> Articles by SouthEasterners. -> Electric Motors - part 1-5 -> Table in chapter 3 Or www.powercroco.de -> konstruktion -> kombinationstabelle Do-it-yourself motor homepages, manuals/tutorials, checks and tests in this motor builders tips and tricks thread. The checks and tests may save you from frying your controller or motor. Thread is active, bookmark it for future reference and subscribe to it: http://www.rcgroups.com/forums/showthread.php?t=240993 (sticky thread, at top of subforum) Vriendelijke groeten Ron van Sommeren• diy brushless motor discussion group • Drive Calculator download & discussion group • int.electric fly-in & diy outrunner meet, Nijmegen, the Netherlands |
#10 | |
Fast, faster & fast again
Motor knowledge...
Jim |
#11 |
I cannot help you with motor size, winding numbers etc. for your plane, for that you need input from people who have experience with those planes.
Excellent motor building articles by Brian Mulder, a must read: http://www.southernsoaringclub.org.za/ -> Articles by SouthEasterners. -> Electric Motors - part 1-5 Do-it-yourself motor homepages, manuals/tutorials, checks and tests in this motor builders tips and tricks thread. The checks and tests may save you from frying your controller or motor. Thread is active, bookmark it for future reference and subscribe to it: http://www.rcgroups.com/forums/showthread.php?t=240993 (sticky thread, at top of subforum) Vriendelijke groeten Ron van Sommeren• brushless motor building tips & tricks • diy brushless motor discussion group • Drive Calculator download & discussion group |
#12 | |
Thanks Ron
Jim |
#13 | |
Hi , if i want to "convert" my BLM ( wich is 2S configured ) in a 1S configuration , is it the good way if i give it ( my BLM ) the 1/4 of the original 2S config resistance ? If it is made with 0.5 Ohms , does i give it 0.125 Ohms ( 2S => 1S ) ? -------- Thanks to try to understand my translation
#14 |
Motors are not resistors, they behave differently. You have to halve the number of winds. That will gave you the same rpm. No you have room for thicker wire, that's nice because motorcurrent has doubled.
#15 |
Ok , thanks ........ the wire will give me a very low resistance but i must not "think to much" about the resistance .
I must "think only" about KV ( halve the number of turns and give the stator the "maximum of copper" , maximum thickness to the wire ) , and "to say to me" that the maximum thicker wire does not want to say bad efficiency for the motor . It is true ??? |
| Thread Tools | |
| motor formulas | qwe123 | Power Systems | 6 | Mar 23, 2004 02:52 AM |
