Old Oct 23, 2006, 09:44 AM
albireo is offline
Find More Posts by albireo
From Earth to the Moon!
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
How to cut prop down in size?
I've read for YEARS that people take larger props and cut them down to use with different motors. I see this and wonder how it's to be done... I have a box full of 10x4.7 props and could use some 8x4 sizes. Do I just cut an inch off each end? What about the shape at the end? I see the shape is a specific curve...
Any suggestions would help!
Joe
albireo is offline Find More Posts by albireo
Old Oct 23, 2006, 11:01 AM
foxabilo is offline
Find More Posts by foxabilo
foxabilo's Avatar
United Kingdom, England, Redditch
Joined Jul 2006
Ok first things first, I dont advise anyone to cut props down as they are made and modeled/shaped etc to be a set size and the flow over the surface is calculated to be most efficent over the area of the actual prop and not some reduced version of itself.
The dangers include the prop flying into many shards of pin sharp plasic/glass/other bits, unbalenced vibration destroying motors and mounts and inifficent thrust.
OK.. that said IF you still want to cut them down then you use a litttle physics to get this as good as they can be, One method is to mount the prop to a motor and that to a lowerable platform and place abrasive material under it so you can slowly lower the blades onto the surface as they spin this will ensure that an even amount is removed from each end, usualy this method is used at the end of a prop cut down to smooth the ends off, you should make detailed notes/take pictures of the prop ends before the cut and try to tool the ends to be the same.
Also for the major cut down you can take a peice of marking wax chalk/marker pen to spin the prop slowly, again fixed into position and mark the blades as they spin with a thin white line to make your initial cuts.
Ensure the blades are then smoothed and balenced and stand well clear when you open the tap to WOT.
I still advise against it though
foxabilo is offline Find More Posts by foxabilo
Old Oct 23, 2006, 11:11 AM
albireo is offline
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
Well, I didn't realize it could be as hazardous, I'm glad you warned me. Don't need to save few bucks and ruin my eyes/models/garage...
Thanks!
Joe
Old Oct 23, 2006, 11:16 AM
maverick06 is offline
Find More Posts by maverick06
Go Navy!
maverick06's Avatar
USA, PA, Media
Joined Apr 2005
I've done it once, it works fine... just make sure the balance is perfect...
On a few 8x4 props I have been known to glue a broken blade back on... yeah its stupid... but when you dont have any other props at the field, it seems like a good solution... not had any problems yet!
My suggestion is not to do that either... haha
Rick
maverick06 is offline Find More Posts by maverick06
Old Oct 23, 2006, 04:27 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
It can work for low powered planes, but the prop won't be as efficient as a proper 8x4.
The tip shape isn't that important, but if the balance is wrong you'll get a lot of vibration.
RobinBennett is offline Find More Posts by RobinBennett
Old Oct 25, 2006, 08:56 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Prop cutting article with photos
This is an article I did for our club newsletter a few months back. I've done lots of props, and they work great!
aerolite is offline Find More Posts by aerolite
Old Oct 26, 2006, 09:31 AM
albireo is offline
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
Thanks! Great article! Especially timely since I was needing it for my JAR, and you've helped me there too!
Joe
Old Oct 26, 2006, 10:10 AM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Albireo, glad I could help. It's always nice to know someone actually reads these articles.
Keep us informed on the JAR progress. I should have a new one with photos in the near future.
Dennis
Discussion Cut a prop down? hayabusa Power Systems 4 May 13, 2007 07:26 AM
How to Cut a 3D modle in Cad. F-111Nut The Builders Workshop 3 Feb 24, 2005 10:39 PM
How to slow aircraft down in flight? KOMET 44 Power Systems 19 May 10, 2002 05:18 PM
How To cut Lager Holes In Balsa?? MrPeabody Power Systems 15 May 09, 2001 04:52 PM
How To cut Lager Holes In Balsa?? MrPeabody Foamies (Kits) 4 Apr 24, 2001 08:46 PM
