Old May 05, 2007, 08:51 PM
frenchfry1 is offline
Find More Posts by frenchfry1
Joined Aug 2006
Thank you for the help. I was going to use a small tower pro out runner with a 3 cell and turning a 8 by 4 HD prop. I also was going to mount the motor using a carbon rod and cut the wing to make it as close to the cord line as possible. Thanks again I will post some pics when I get it done. I am using your suggested modifications to the wild wing and I am very excited to get her in the air. I will be helping my wife build her own once I figure out if it will fit her building and flying skills/desire.
frenchfry1 is offline Find More Posts by frenchfry1
Old May 05, 2007, 09:36 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
If you take the time to read this whole Thread carefully, you should be able to build one no problem. Butch
Butch777 is offline Find More Posts by Butch777
Old May 06, 2007, 07:27 PM
tomcor is offline
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Originally Posted by Butch777
Hum, My Yahoo wouldn't let me post pics, so I had to go over to AOL.
What is that Boomer in the first picture made from? Is it a Wild Wing core? Looks like a nice plane. Did you cut the nose piece yourself?
Or maybe that is just a Stryker core..
tomcor is offline Find More Posts by tomcor
Old May 06, 2007, 10:35 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
That's a Stryker Boomer.The side scoops are sanded off as well as anything else that could reduce the weight or drag.
The nose is just sanded a bit.
I set up a Stryker-Lite with a Esskay motor and this Stryker-Cat with a 24gram outrunner. They both weigh about the same.
The Stryker-Cat flys a whole lot smoother than the Stryker-Lite.
And as a 10.5oz plane, it will fly in 20mph wind no problems and slow way down, plus go vertical! Not so bad for a second plane or aileron trainer. A lot less sensitive than a Flying Wing, with the benifits of windy day flying. Butch
Old May 07, 2007, 04:50 AM
Butch777 is offline
Livermore, CA
Joined Sep 2004
One of the guys I fly with took a video of the outrunner Boomer, on a windy day.
It was windy and cloudy, but it will give you a idea of how well it flys in the wind and how slow and aerobatic it flys. Butch
http://vids.myspace.com/index.cfm?fu...oID=2027601254
Theres video of my PC-9 as well on this site.
http://vids.myspace.com/index.cfm?fu...ideoID=8806582
Old May 07, 2007, 03:35 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
I think we may have a Stryker-Cat Boomer video soon as well.
The Stryker is a bit larger, but does real well in the wind and at 10.5 ozs, and it floats real well.
The primary difference in the Wild-Cat and the Stryker-Cat besides the weight/size, is the foam. The Epp will take a lot more abuse than the hi-bred foam on the Stryker. Butch
Old May 07, 2007, 05:04 PM
flyin C is offline
Find More Posts by flyin C
No Guts, No Glory
flyin C's Avatar
Simi Valley, CA
Joined Feb 2007
Great video!! I am very impressed with it handling the wind, slow flight characteristics, and being acrobatic-just like you siad. The next video would be nice if you showed it flying slow, like in you street, and it flying fast. Great job
So what are you using in the RTF Boomers?
flyin C is offline Find More Posts by flyin C
Old May 07, 2007, 05:06 PM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Butch, clear up my confusion please!! The stryker boomer has the 2g blue motor and is the better one in the wind, AND will slow down well too???? Am I reading your comments correctly?? If so I need to get a stryker body
This is the one? http://www.rcgroups.com/forums/attac...mentid=1295252
What battery and prop is on the blue?
Paul
praymond is offline Find More Posts by praymond
Old May 07, 2007, 05:22 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
The Stryker Boomer flys very well. The airfoil is a faster one than the WildWing, so it cuts the wind a bit better. Its cheap like the WW, but the foam dosen't hold up in a crash as well as the WW( pics later).
Also it weighs more so it takes more power to fly, but it has more wing area so it still floats nice, but not quite as good as the WW Boomer.
I want to do a compairason between the Boomers and Stryker-Lite, but the wind has been steady and when it calms, I'm usually too busy.
Flyin C,
The RTF's are built per order. Some with rx, batts and test flown, some Rx ready, with the tails and ailerons out of EPP Depron and or balsa or a combo of all thee and some just partly built. Butch
Old May 07, 2007, 05:32 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Paul, the motor is the 24gram 1300kv motor that UnitedHobbies sells. I use either there cheap/light ESC or a Castle Phoenix 10a. On a 8060 prop it pulls 7+ amps, but I sometimes run a cut down 9070, which draws almost 10 amps, but use the extra power in bursts. So far it works good.
On the 8060 prop I use a TP 730mah, 3 cell, as well as a generic 700mah 3 cell 20C and the TP 910mah 3 cell. Mostly trying to keep the weight down. On the cutdown 9070, I use a 910mah 3 cell or better. A 1320mah 3 cell would be ok if you wern't worried about going real slow. Butch
Old May 07, 2007, 09:54 PM
Fearless Flight is online now
Find More Posts by Fearless Flight
Joined Mar 2005
That thing flies beautifully. This is when I hate being a newby because that even looks like more than I can handle right now.
Fearless Flight is online now Find More Posts by Fearless Flight
Old May 11, 2007, 10:10 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
I am looking for something that can fly in tight spaces, handle wind and is durable, so a Boomer looks quite interesting.
I am wondering if somebody has tried putting an (inverted) V-tail
(like on a Poly Pusher: http://www.acesim.com/rc/polly/polly.html)
on a Wild Wing Boomer?
Having both an elevator and a rudder effectively in the prop wash
might enable some really tight turns at very low speeds.
flying-llama is offline Find More Posts by flying-llama
Old May 11, 2007, 12:36 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
That would be a simple build with the WildWing. The WW's still on sale for $19.99 at HobbyPeople. Let us know if you try it! Butch
Old May 12, 2007, 04:27 AM
Joined Mar 2006
Possible source of black EPP
I have seen some interest in a source of black EPP on this thread.
For those who do not already know, one possible source is:
http://www.slofly.com/cart/
But I also know that this place seems to be mostly out of 9mm white EPP.
Old May 12, 2007, 04:42 AM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Thanks for the info, but I've got 2 big boxes full of EPP sheet, both colors, from Slofly.com. and several of his other planes and wings.
What I'd like to find is some 1LB EPP or less. I have some small white pieces, but thats it.
The 1LB EPP would be better for beginners Boomer fuselage's, because they'd bounce better. Butch
jetset44 Parkflyers jets for beginners pstoehr1964 Electric Ducted Fan Jet Talk 5 Dec 13, 2004 03:18 PM
Bluecor for beginners? ArcherAce Foamies (Kits) 4 May 10, 2002 11:48 AM
help web site, for beginners Patrick Plawner Beginner Training Area (Aircraft-Electric) 6 Apr 07, 2002 05:14 PM
Is the EZ-400G good for beginners? FX1SUB Parkflyers 7 Apr 03, 2002 09:20 AM
Wattage F-22...For Beginners? breadboy Electric Plane Talk 6 Oct 03, 2001 03:08 PM
