Boss |
Livermore, CA
Joined Sep 2004
Hi Steve,
The Boomer came from a Flying Wing, modified to be more pitch stable and fly slower and in tighter areas. So any Flying Wing will do! The airfoil will determine the best speed range and the final weight per wing area will determine the slow flight range. We used the WildWings because they were cheap and had a good lifting airfoil. A 24g outrunner on a WW, could glide 40ft+ on a hard hand launch, before power had to be added! There are some fuselage and tail dimensions on this thread, but they are mostly for the 31.5" WW Boomer. If you can't figure something out, post here and I'll help. I have folks in the Philippines, Parañaque City and Camiguin Island. I got to get back for a visit some day soon. Butch |
If you do get back over here then PM me. I'm in Bohol and I don't get to Luzon much, in fact almost never, but if you're ever near Cebu maybe we could arrange an eyeball. I'm right across the channel on Bohol's west coast I'm uploading 2 pictures. One shows a screen capture from cmEi with the stats for my effort. It's a 32" span flying wing with vertical stabs on the wingtips and at either side of the prop slot. I'm shooting for a Wing Loading around 5 oz/sq ft. It should have about 380 sq in for wing area. The second picture is a mock up of the parts that are cut to get an idea of what it will probably look like. Elevator will be a bit larger and differently shaped than the one shown and they will be higher between the vert stabs too. Nose, center-line top and bottom reinforcement, (2" wide) and all vertical stabs will be EPP type foam and the rest will be the light crumbly white Styrofoam. That's what's available to me, locally. I plan to reinforce where needed with tape but not use any spars in order to keep it light. 10A SS ESC, Corona 4ch synthesized RX, 500 to 800 3s Lipo, and BW motor turning an 8x4.3 prop. I hope to work on it tomorrow, Saturday, and I'll upload any pix I take that might be of interest. I'll video the maiden and put it on Youtube then post a link when available. I'm also posting about the plane here because it has a KFm4 wing. http://www.rcgroups.com/forums/showt...6#post11691430 Take care and Mabuhay, Steve. Edit: Here are a few more pictures. The thing is glued up with stabs and control surfaces done. I need to use Fiberglas tape to stiffen the wing, and install the gear slots and popsicle sticks for servo screws. Then it's add the EPP foam in the center for landing skid, nose protection and ESC/RX enclosure. It's still windy as all get-out! Not been able to fly for about a week or more. this may be ready to maiden tomorrow but the Southwest Monsoon is creating strong onshore winds. Edit 2: Tuesday morning; been windy all night and is still blowing a gale. Time for coffee then out to the garage to finish the Thistle..
Pagan moded with Boomer tail.
Wow there's no activity here.
Title says it all. Here's the maiden:
Pic here, undergoing electrical repairs. http://www.rcgroups.com/forums/attac...1&d=1260425263 Steve. |
Livermore, CA
Joined Sep 2004
Looks like it flew ok to me!
The chickens in the background remindes me of our stay on my Wife's Island. Once the cheap WildWing was discontinued, the Boomers died off, plus most people seem to want everything yesterday and cheap and want it RTF. |
We live in a disposable society, I'm afraid. For me building and changing things around is a big part of the fun. Foam n' Hot-Glue makes that so easy.
I could re-nose the thing but not sure what I want to do. I have the original Vesper design that I'm thinking of turning into a boomer. Was going to Canard it but I'm re-thinking that now. With the broad wing it rolls beautifully but the pitch moment is so short it may be a good candidate for the Boomer mod. Might eliminate those pesky "Plank" pitch problems. ![]() Flying the boomered Pagan I was really impressed with how well-behaved it seemed to be. That is up until the brain fart. The intellect said just pull it up inverted but the thumbs apparently didn't get the memo. ![]() Steve. |
Livermore, CA
Joined Sep 2004
Hey Steve,
Looks like it needs a EPP nose! The later design WildWing Boomer had a wider EPP fuselage and built standard(not heavy) at cruse speed, it could be flown into a wall without damage! And even in a high speed impact, the nose would just snap off and it was easy to glue back on. Butch |
Livermore, CA
Joined Sep 2004
Thanks Guys,
Out of the 20 or so diferent Boomers I designed/built, I still have about a dozen flying. There still my standard take along plane. I've designed several different EPP planes for smaller parkflyers, but the Boomer design seems to take the most abuse and is still alot of fun to fly, plus does a windy day no problem. Butch |
Here are 3 pics of what I have with the Vesper mod.
It's heavy, the nose is too long and the balance is probably too far forward. I don't like the fins shape. I changed the BW motor to a BP21 to get more weight at the back. Balance point should be on the spar and with the heavier motor it's still about an inch to far forward. I'll weight it at the back a bit and try it out. May add a small canard to carry some of the forward weight or pull out the gear and move the ESC, RX and Battery farther back. Cg should be around 25% MAC which is 4.75". It's probably 3.5" at the moment with the BW motor. BP21 probably moved that to under an inch off. By the time I'm finished it'll be 600g plus. ![]() Steve. Edit: Dec 14, 2009 5:32am Butch, No EPP here in PI. You should know that. I use plastic soda-pop bottles with a wooden form and heat shape the plastic to make a nose shell. It adds a lot of strength but nothing is bullet proof. I have made the canopies the same way. I like clear for the shells and blue or green for canopies.I will re-do the ESC, RX and Battery location today and go back to the BW motor. It's raining and windy so it's a good project for me to keep me out of the Karioke bars. Hee Hee. Siince I quit drinking, almost two years ago, RC is my main time filler and it's been a good two years! ![]() Edit: Dec 15, 2009 8:04am Got it up in the air but it's not an easy flier in the wind. I think boomers need some sweep for stability. (35 deg)
Here's a few pics with the nose shortened. It was way nose heavy so I shortened the nose by about 5.5". Looks OK to me. I want to try it in calm weather. Winds in the vid were about 5mph+ at ground level. Wind right now is a bit stronger than yesterday when the video was taken... ![]() Trimmed the tail a bit. Not sure I like it this way. Never mind, the way it flies it probably won't last long anyway!!! ![]() ![]() ![]() Edit: Dec 16, 2009 1:08am Still up surfing. I have a new version of the Pagan Boomer ready for gear. See pic. think this will do better than the "Plank" type wing specially in the wind.
| Thread Tools | |
| jetset44 Parkflyers jets for beginners | pstoehr1964 | Electric Ducted Fan Jet Talk | 5 | Dec 13, 2004 03:18 PM |
| Bluecor for beginners? | ArcherAce | Foamies (Kits) | 4 | May 10, 2002 11:48 AM |
| help web site, for beginners | Patrick Plawner | Beginner Training Area (Aircraft-Electric) | 6 | Apr 07, 2002 05:14 PM |
| Is the EZ-400G good for beginners? | FX1SUB | Parkflyers | 7 | Apr 03, 2002 09:20 AM |
| Wattage F-22...For Beginners? | breadboy | Electric Plane Talk | 6 | Oct 03, 2001 03:08 PM |
