Old Jul 19, 2007, 12:57 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Flyin C,
The funny thing about most brushless motors is there are no pos or neg wires!
You just hook them up anyways, and if its not turning the right direction, change 2 of the wires. Butch
Butch777 is offline Find More Posts by Butch777
Old Jul 19, 2007, 11:18 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Originally Posted by aman_74
So which 20 gram motor?
I build my own from parts bought from Don,not sure on the weight of his super 20 kit but by all means ask for his advise by email ,he has a great tutorial on building ,cheers http://www.strongrcmotors.com/Kits.htm
olmod is offline Find More Posts by olmod
Old Jul 20, 2007, 03:25 AM
aman_74 is offline
Find More Posts by aman_74
Cleveland, Oh
Joined Feb 2005
Ok, thanks, but you said that the motor wouldn't need to be built to obtain those numbers so I was looking to find out what pre-built version you were referrring to.
aman_74 is offline Find More Posts by aman_74
Old Jul 20, 2007, 04:16 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Oh i see a missinterpretation,what i meant was thats what can be acheived but by no means a max performance ,just a close comparison to what Butch was using,i have a lot of wind data records using GB stators and a few others
here is one that's popular.
New construction type motor.
12 off mcs 20 n50 mags from strongrcmotors.com
15t of .5mm connected y
no load 15100 rpm@7.8 volts @ .6amp = 1935 KV
GWShd 7035 @7.4v @5amps =11200 rpm =273.27g = 9.65 oz thrust.
GWSHD 8040 @7.1v @ 8.6 amps = 8750 rpm = 372.90g = 13.16 oz thrust.
13t of .5mm connected y
no load 16800 rpm@7.2 volts @ 1amp = 2333 KV
GWShd 6030 @7.2v @ 13000 rpm @ 5 amps = 250.7g =8.85 oz thrust.
GWShd 7035 @7.2v @ 12000rpm @6.5 amps = 318.9 g= 11.62 oz thrust.
Old Jul 20, 2007, 03:58 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
I was wondering if there is anything that I should watch out for if I were to try to build a Wildcat-Boomer with the following heavier motor and battery:
- 300-size geared brushless in-runner (~2.5oz.) swinging a 13" x6.5" slow flyer prop (17-19 oz. static thrust on paper)
- 8.4 or 9.6V NiCAD (~3-4oz.) battery
Perhaps I need stronger servos or not shorten the wing by 3.5 inches
or really lengthen the fuse to get the CG correct?
Thanks.
flying-llama is offline Find More Posts by flying-llama
Old Jul 20, 2007, 08:19 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Most of us are using 8" or 9" props and the booms are glued in to match.
With that big of a prop and using nicads, you would not need to cut down the wing.
I would use a 9 gram servo, like the GWS Naro for the ailerons and a 6g servo for the elevator.
The fuselage will just be a guess!
Just build it, keep the tail light and see where the C/G ends up. Let us know how it goes! Butch
Old Jul 20, 2007, 11:54 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Flying llama,
You could always just use the inrunner direct drive and build a fast Boomer.
Heres one with a 180 Walkera, 3200kv. Using a 2 cell 1450mah lipo. It weighs 11.5ozs and is reasonably fast. Butch
Old Jul 21, 2007, 04:06 PM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Sorta Boomer
Butch, I was going to make your boomer, but got sidetracked into what you see here. It's still a boomer, but a tractor boomer. I didn't cut the wing, and am using a Esskay 400xt on the nose.
I'm going to make it along the lines of the F&L pictured below. It's a great flyer, smae motor.
Should I try for the balance point suggested in the WW directions since the wing is original size? Or because it's not a pure wing (has booms and a tail) do you think the CG will be different?
I was trying to put on the gear and see where it will balance before I mounted the tail group, just hanging blucor on the booms to simulate the tail weight.
Since you've used so many of these WW's i thought you'd have a much better feel for where to start a CG point.
Thanks. paul
praymond is offline Find More Posts by praymond
Old Jul 21, 2007, 05:55 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Most flying wings are about 15-22% back on the C/G.
So the WW's C/G will be forward of the conventional 30% back.
So try about 1/2" back more and maybe do a glide test in a nice plush grass field.
Butch
Old Jul 21, 2007, 07:57 PM
praymond is offline
praymond's Avatar
Joined Jun 2005
Thanks for the reply Butch. If you look at the left hand picture you'll see a line with 2 circles on it just behind the equipment bay. that's where the WW directions says to balance it as a wing. As a boomer, should I try for 1/2" rear of that mark to start?
Also what would be too much boom length, LE of elevator to TE of wing?? The spars are extra long, I was thinking of 6", and a tail group similar to the pic on the right.
Sorry for being a pesk, I appreciate your expertise!
Paul
Old Jul 21, 2007, 09:02 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Hey Paul,
In general, the leading edge of the elevator should be behind the rear most trailing edge of the ailerons.
Yup, I'd start about 1/2" rear of the recomended C/G, but If I remember right, the guys that build the WW stock said the recomended C/G was off a bit.
To be safe, try putting in the wing size into a C/G calculator and select 30%.
Heres a online calculator.
Because the leading edge moves forward at the nose, draw a invisable line to see where the leading edges would meet if they were stright and measure from that point. Butch
http://nasascale.org/howtos.htm
Old Jul 21, 2007, 10:48 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Hi Butch and friends,
i bought some of these https://www.unitedhobbies.com/UNITED...idProduct=5358 Lovely
and some 6g 4amp esc's some 3.3g servo's and i have a 24g 380 2sp pack and some 6m epp sheet.
Starting to look good for tlar mini boomer in the queue
Old Jul 21, 2007, 11:28 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Hey Lez,
I'm right there with you. I ordered 3 of them, the ESC's and some small servos, a week ago.
I've got some EPP Flying Wings that are about 27"s, so they may be a good test plane to build a smaller Boomer from. They were designed for the IPS motor.
Or I may cut a WW down even farther, but the WW is not on sale at this time. Butch
Old Jul 22, 2007, 12:09 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
On small stuff i like flat foam reinforced with bamboo shashlick sticks
i havent found a scource for that soft flexble hot melt glue that some are using available here in Oz yet, spose ill have to import that too
Old Jul 22, 2007, 01:18 AM
Joined Mar 2006
Originally Posted by Butch777
Flying llama,
Thanks for the suggestion, but I am a near-sighted beginner flying in a small yard.
My interest in the Boomer is that it is a pusher (survive head-ons) that can fly slow (have a large prop and prop wash over the elevator).
jetset44 Parkflyers jets for beginners pstoehr1964 Electric Ducted Fan Jet Talk 5 Dec 13, 2004 03:18 PM
Bluecor for beginners? ArcherAce Foamies (Kits) 4 May 10, 2002 11:48 AM
help web site, for beginners Patrick Plawner Beginner Training Area (Aircraft-Electric) 6 Apr 07, 2002 05:14 PM
Is the EZ-400G good for beginners? FX1SUB Parkflyers 7 Apr 03, 2002 09:20 AM
Wattage F-22...For Beginners? breadboy Electric Plane Talk 6 Oct 03, 2001 03:08 PM
