Old Jun 12, 2007, 03:19 PM
Scott_S. is offline
Find More Posts by Scott_S.
Joined Feb 2007
Butch, will these planes do any kind of high alpha flight? Or it that a whole other design to achieve HA flight?
Scott
Scott_S. is offline Find More Posts by Scott_S.
Old Jun 12, 2007, 03:45 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Some of the Guys who have flown and or watched the Boomers fly, commented on the high alpha being more than they thought it would do, but to get the max, you'd have to set it up to do that using the right power to weight ratio and the right size control surfaces and a C/G to match.
But it may make it harder for a beginner or less experianced to fly. Butch
Butch777 is offline Find More Posts by Butch777
Old Jun 12, 2007, 04:59 PM
Scott_S. is offline
Joined Feb 2007
No biggie Butch, I bought it to learn on. I think it'll be great!
I'll PM you the paypal info. I want an extra lipo with it.
Old Jun 13, 2007, 05:22 AM
NoThreat is offline
Find More Posts by NoThreat
NoThreat's Avatar
Genesee Valley WNY
Joined Apr 2006
GWS 1AXC-4A w/Spinner
GWS stock number---IPS-DX2BB-AXCS
that the closest I could find, it was about 14 bucks
Ball bearing supported gearbox
"A" ratio gearbox
IPS Motor
Black plastic one-piece spinner
Great Planes LiPo 7.4V 350mAh 2S 20C Discharge 2-Pin
GWS ICS50E/F Speed Control 2A 3.6-9.6V Futaba
I did my best! plus I had a 20 dollar off coupon I couldn't resist
I don' know what GWS propellers to get though..do they have an equivilent to the 80xx ones?
I am still fuzzy on how the propellers work, Im reading but I still don't have it mezmorized
all the props on tower hobbies are 10x6 or 8x whatever..which of these are for the boomer?
NoThreat is offline Find More Posts by NoThreat
Old Jun 13, 2007, 09:10 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
If you want to go with a brushless motor and Lipo batteries, you can't beat the deals atUH. Although, be sure your item is well-stocked or it could take over 2 months to receive the parts.
warhead_71 is offline Find More Posts by warhead_71
Old Jun 13, 2007, 05:08 PM
NoThreat is offline
NoThreat's Avatar
Genesee Valley WNY
Joined Apr 2006
Like a kid in the candy store I opened the tower hobbies and I think I got the right stuff.
the ESC is tiny tiny....and all the plugs are the same.
if I totally Bork this build, I may be sending Butch 45 bucks.....
Old Jun 13, 2007, 05:43 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
If you click on the GWS propellers (listed under nylon propellers), you will see such a list. If you click on each item, they will give you an alternative set of numbers.
For example, the 8x4.3 propeller has a manufacturer stock number of "EP8043/6P", which means 6 propellers of type 8043.
Similarly, 10x6 is of type 1060.
There is one caveat. Sometimes a slow flyer and a direct drive propeller will have the same numbers. For example, there are two 12x8 propeller listings,
one for slow flyer (type 1280) and one for direct drive (type 1280DD).
flying-llama is offline Find More Posts by flying-llama
Old Jun 14, 2007, 05:38 AM
NoThreat is offline
NoThreat's Avatar
Genesee Valley WNY
Joined Apr 2006
excellant...thanks!
well the wildwing now has 4 inches cut out of it, next is trying to glue it back together..my cut was not the best...not vertical, so some sanding is in order
Old Jun 14, 2007, 01:30 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
No Threat,
Looks like you got the right motor.
Just remember, the WildWing was designed to use a speed 400 motor. It looks about 10 times bigger than the IPS motor.
If you don't follow the thread and build it light, it may not fly at all!!
Early in this thread I built a WildWing-Lite, (not a Boomer), to compair flying to the WildWing Boomer. I used a IPS-A motor in both and basicly built both the Wing and Boomer the same. The Boomer flew alot better!
But, One of the other members built his WildWing with a IPS and PMed me that he couldn't understand why his had no power and wouldn't fly.
His ended up almost twice the weight. He'd used all the heavy parts, large lipo and bigger servos, etc.
Every bit of extra weight reduces power, so be careful.
When sanding the wing halves to reglue them, I use 120-150 grit, on a block of wood.
Sand in one direction only, then put the halves together and hold up to a light to see where they don't fit good. Butch
Old Jun 14, 2007, 05:38 PM
NoThreat is offline
NoThreat's Avatar
Genesee Valley WNY
Joined Apr 2006
Thanks butch, I am also trying to build lite....basically going with exactly what you have, my servos though are futaba minis I beleive they are lite enough
3010 and 3011 and the rx is the 156f....all small for parkflyers.
the rx is bigger then the berg but very lite
I didint want to buy a new rx and servos, they fit fine with room to spare in the servo holes.
My worrie is lining everythin up and hooking up the pushrods...
Old Jun 14, 2007, 09:51 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Every time I build one, I worry about lining everything up.
I'm building a Faster version and when I set in the second boom, I got distracted and lined up the boom level with the first boom up and down, but realized just as the epoxy set, that it was pointing outboard too much. So I had to rip it out, scrape off the epoxy and quickly reset it, before the epoxy that was still in the slot set up!!
Aileron pushrods are easy if you use the the mini connectors. But the elevator pushrod can be tricky. I have had to bend up a new one, when I got the first one too short.
You could always use a mini connector on it also. Butch
Old Jun 15, 2007, 12:43 AM
Joined Mar 2006
A question, when I read that the wing span was shortened by 3.5" to 4",
I thought that the wing tips were cut off.
But it sounds like you shorten the wing span by cutting out
the middle of the wing and then regluing the shortened wing halves
back together? Thanks.
Old Jun 15, 2007, 01:22 AM
Butch777 is offline
Livermore, CA
Joined Sep 2004
The WildWing has some nice wing tips on it, but the biggest problem is the huge rc and batt bay holes in it. Plus for our purpose, around 30-31" wing span is about right.
I did a 4" cut at first, but the rx bay was a bit too small, although not bad. Then a 3" cut, a little too big, so the 3.5" cut seems to be about right if your using micro gear.
Plus, most Flying Wings come with 2 wing cores to glue together anyways. Butch
Old Jun 15, 2007, 05:41 AM
NoThreat is offline
NoThreat's Avatar
Genesee Valley WNY
Joined Apr 2006
mine is already cut so I may need to do some creative cutting
did you use the hardware from the WW for the pushrods etc..?
Old Jun 15, 2007, 12:15 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Most of the WW hardware I don't use, such as the pushrods, horns, connectors, fins, rx/batt bay cover, skid and the motor mount. The pushrods are heavy and made out of cheap soft metal, so I use regular the piano wire type found in hobby shops.
The horns could be used, but there too heavy-duty, with larger holes in them than we need.
Even the balsa ailerons get sanded thinner and tapered or traced onto depron for a real lite Boomer. Butch
jetset44 Parkflyers jets for beginners pstoehr1964 Electric Ducted Fan Jet Talk 5 Dec 13, 2004 03:18 PM
Bluecor for beginners? ArcherAce Foamies (Kits) 4 May 10, 2002 11:48 AM
help web site, for beginners Patrick Plawner Beginner Training Area (Aircraft-Electric) 6 Apr 07, 2002 05:14 PM
Is the EZ-400G good for beginners? FX1SUB Parkflyers 7 Apr 03, 2002 09:20 AM
Wattage F-22...For Beginners? breadboy Electric Plane Talk 6 Oct 03, 2001 03:08 PM
